Results 1 to 16 of 16
Thread: Help regarding Hard Disk Enclosure
    • Menace Slinger's Gadgets
      • Gigabyte B75
      • Intel Core i5 3470
      • Twinmos 2 X 4GB 1600 mhz
      • WD 2 X 1 TB + Hitachi 1 TB + Samsung 320 GB
      • Nvidia GeForce GTX 650
      • Samsung LED 18.5 Inch X 2
      • M-Audio Fast track
      • Just Beats ( Beats by Dr. Dre)
      • A4 Tech KD 800L
      • Logitech B100
      • Generic USB Gamepad
      • Thermaltake Litepower 450 WT
      • SAMSUNG
      • Audio technica AT 2020 Microphone
      • Ideal 5308B 800VA 7Ah
      • Windows 7 Ultimate
      • Casing : InWin MANA 136
      • Earth Telecommunication
      • 4 MB
      • 4 MB
    Menace Slinger's Avatar
    Jan 2013
    Default Help regarding Hard Disk Enclosure
    hello
    I am planning to buy a hard disk enclosure for my 3.5 inch internal hard drive. Are those available on IDB bhaban? How much would it cost for USB 2.0 and usb 3.0 ones.
    bought a USB 2.0 non brand one, shitty stuff cost me around 700
    Member Shoaib's Avatar
    Khulna
    Does it work?
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Why is that?
    Quote Originally Posted by Shoaib View Post
    Does it work?
    yes it did... for about a month.
    Quote Originally Posted by Menace Slinger View Post
    Why is that?
    the power supply unit that came with this was pretty low end, it got busted after a month. i opened it up later and found out it came with lower rated stuffs, like the IN4007 diode(I don't even use this diodes for high current purpose), and the heatsink was pretty small.
    one more thing is it didn't support all hard drives.
    and the 160GB Samsung SATA2 7200rpm drive that i used died after a month, either it was samsung's fault or maybe this one's fault(it may have helped the drive to reach load unload cycle real quick)
    anyway I heard Transcend enclosures are available at around 2.5k. that should be good.
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    how good are those encloser? where did you buy that? Is it an encloser or a sata to usb converter?
    • Ghost Riley's Gadgets
      • ASRock Z370 Extreme 4 [Case: Thermaltake Commander GS-II black]
      • Intel core i5 8400 @ 3.9Ghz
      • Corsair Vengeance LPX 16GB @3600Mhz (Dual Channel)
      • Toshiba 2TB
      • Sapphire RX480 Nitro+ 4GB
      • Dell S2216H IPS panel (1920X1080)
      • Creative X Fi Titanium
      • Edifier R2000DB
      • A4 TECH KR-85
      • Havit-MS736
      • Antec Neo ECO 650M [80 PLUS BRONZE Certified]
      • Samsung SH-S223
      • Transcend 32GB USB 3, Adata C906 32GB USB 3, Adata UV120 32GB USB 3
      • https://valid.x86.fr/bench/5bqlvf/1
      • ochcham
      • Alpha Broadway
      • 130-150 KBps
      • 100-150 KBps
    Ghost Riley's Avatar
    Narayangonj
    Quote Originally Posted by Arka karlos View Post
    ECS, elephant road maybe level 3 or 4.
    metal enclosure which converts has SATA to USB converter.
    its a 2.5" enclosure not a 3.5" one.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    did you ever used those one which comes with sata to usb converter with separate power brick which powers the hdd. Are those good.
    yes I'm talking about the similar one. a case for the 3.5" HDD, inside it has a small circuit for converting usb to sata. You will get an adapter that converts 220V AC to 12V and 5V DC for powering up the hard drive.
    atleast i can say, the one that costs 700BDT is not good.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    i am actuall talking about this one
    http://m.bikroy.com/ads/sataide-to-usb-converter-for-sale-dhaka
    Khulna
    At least your enclosure was 700tk I almost bought one for 400tk. I guess that one wouldn't even work for a week.
    the one is used has just an metal enclosure for the HDD, you wont see that sata and power cable. the rest is same.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    i thought those were just like portable hdd without adapter. Anyway my bad.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Saw a thermaltake for 2.8k at UCC, how will those work ?
    i have faith in TT. guess they will be good.
  1. Sale (Used) Western Digital Scorpio Blue 640 GB Portable Hard disk with enclosure
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: December 5th, 2013, 11:53
  2. Want to Buy Want to buy RAM and Hard Disk
    By Mr. Orange in forum Shop - Gadgets
    Last Post: May 25th, 2013, 03:12
  3. Want to Buy Want to buy IDE Hard disk....
    By akk in forum Shop - Gadgets
    Last Post: February 3rd, 2013, 01:41
  4. Disk Manager does not detect Hard Disk
    By Flame in forum Technical Support
    Last Post: March 11th, 2011, 11:31
  5. Want to Buy need 160 GB hard disk
    By ĘŁєčŦЯŐй Shajal in forum Shop - Gadgets
    Last Post: May 20th, 2009, 17:45
Page generated in 0.26122 seconds with 14 queries.
