Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 43
Thread: Stock Intel Cooler VS Aftermarket CPU cooler :Temp. Comparison
    • Extreme Noob's Gadgets
      • Gigabyte P67A-UD3R-B3
      • Intel Core i5 2500k @4.3Ghz with CM Hyper212+
      • G-Skill Ripjaws X 4GBX2 1600Mhz @8-8-8-20
      • Mushkin Callisto Deluxe 40GB SSD; WD Caviar Black 1TB SATA3; Samsung Spinpoint F3 500 GB
      • Sapphire Radeon HD6950 2GB unlocked to HD6970; XFX GT240 as a dedicated Physx Card
      • Viewsonic VX2260WM 22 inch Full HD LCD Monitor
      • Creative Sound Blaster X-fi Titanium PCI-E
      • Microlab Solo 7c 2.0 Full Range Stereo Speakers
      • A4 Tech Slim Normal Keyboard
      • A4 Tech X7 Laser 3600DPI gaming mouse with Razer Goliathus Speed Edition
      • Xbox 360 Controller ; DIGI USB Joystick
      • Corsair TX650w V2
      • Asus SATA 24x DVD R/W Dual Layer
      • Twinmos USB Flash Disk 4 GB
      • Micro 1000VA
      • Windows 7 Ultimate 64Bit
      • 3D Mark Vantage- P24529; 3D Mark 11- P5642
      • Housed in a Cooler Master HAF 912 Advanced
      • IsPros
      • 30KBPS
      • Do not Know
    Extreme Noob's Avatar
    Sep 2009
    Mohammadpur, Dhaka, Bangladesh,
    Default Stock Intel Cooler VS Aftermarket CPU cooler :Temp. Comparison
    Hey brothers,recentlyI have bought a aftermarket cpu cooler which is Tt V1AX.I have installed the cooler myself by replacing the stock one.now about 1 thing I am confused.I am not sure if I have installed it correctly or not.because there is only 10*c load temp difference with the stock cooler after installing the cooler.(60*c=stock cooler & 50*c=v1ax)is it normal 4 that aftermarket cooler?Or should the cpu be more cooler with that v1ax?please help me brothers.
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Default Re: Stock Intel Cooler VS Aftermarket CPU cooler :Temp. Comparison
    Please someone help me about that.I am really confused.
    ভাই তুমি রাত ৩ তার সময় থ্রেদ কুলছ তাই একটু অপেক্ষা কর. আর আমার ও কাস্টম কুলার আমিও এরকম ই ডিফারেন্স পাইচি ১০-১৫ .
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Bhai aftermarket cooler gular main difference bujha jai OC korle. Noile eirokom diff e thake.... Ar Tt V1AX koto nilo? ektu janan to....
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Ami amar Q8200 cpu ta ke OC korchi @2.8Ghz porjonto and oi clock speed ei akhon chalaitechi.er age stock cooler diye ei clock speed e load temp thakto 60-61*c ar akhon V1ax diya thake 50-51*c.eijonnoi ami confused.ar V1AX er price niche 3750 tk.ami goto 7th december kinchi
    আমি এখন আর গেম খেলি না...
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Ki obostha!keu nai naki forum e?amar confusion ta clear koren keu.plz
    @dramaviewer
    the temps seem fine too me, you also need to give it a 2week burn-in period for the TIM compound to settle & then the temps should decrease a lil bit more
    & also it is fine for a quad, try OCing up to 3.6GHz & report the temps & did you buy the cooler from UCC & where there any more models present from TT???
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    I am a safe ocer.I have overclocked my cpu @2.8 ghz by keeping the ram frequency at default 800mhz by tweaking ram multiplier.I don't want to overclock my rams because it is from transcend those are not very durable like ocz,corsair etc.you know that Q8200 has low multiplier(7x).for this low multiplier it is not possible to reach over 2.8ghz without overclocking the rams.if I would have 1066mhz ram then it would be possible to hit over 3ghz without overclocking the rams. Yes I have bought the cooler from ucc.on that time there was duo-orb,max-orb,V1 also available.
    Quote Originally Posted by dramaviewer View Post
    mmm good
    Transcend eh? thet will do fine until 850MHz or more mayb, but yeah you are in a big bottleneck there:
    Transcend RAM & low multi
    & what were the prices of the other coolers???
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    mmm good
    If you buy your pc from bd then there isn't any other better choice 4 rams rather than transcend,apacer,adata which are pretty much similar in terms of quality & durability.another nasty thing is that greater than 800mhz ddr2 memory modules are not available in bd computer market.so the unlucky fact is you will must be bottlenecked even with your Q9550([email protected],12mb L2 cache) 4 this sucking 800mhz ddr2 rams.anyway other cpu cooler's price:max-orb=3700tk,V1=4200tk,duo-orb=4750tk This price was applicable on 7th december,2009
    :O, but I own a E8400 & not a Q9550
    & I can get my CPU to 3.6GHz with messing with the DRAM & that is set a 400MHz(800MHz effective) with a 1:1 ratio with a 9multi
    but I my current settings are with a 8multi so that gives 3.2GHz with 400 FSB with a 1:1, I just need a better cooler & yes I have tested this myself, the transcend modules are fairly cabable at 850-870Mhz...so hitting 4GHz with my E8400 aint a biggie
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Intel's core 2 duo series processors are the most energy saving & power efficient cpus ever made by Intel.Comparing a Qxxxx series quad with a Exxxx series duo shows a day/night difference in terms of power eating.similar to that, overclocking 4 cores is much more difficult than overclocking 2 cores.my bad luck is that my Q8200 has got lower multi so it is even more difficult to oc it with 800mhz rams.yours one is duo & got 8x multi so that you can do more% overclock than me even with 800mhz transcend rams.
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Transcend 800MHz ram can go sometimes even higher than 900MHz....I have OCed some to that point. But if you dont overvolt they become unstable...
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    I know that.I myself overclocked my ones @884mhz and kept it for one night.thats not the problematic issue.the bad thing about 800mhz ram is it will die very soon if you oc it without proper ram cooling.ram temps reach to very high level for overclocking which is not generally noticeable.this high temp will kill your ram day by day very slowly.I have am experience about this.
    • ScS :: XTR's Gadgets
      • abit IP35-E [P35 Chipset+ICH9]
      • Intel Core 2 Duo E6550 2.33GHz
      • Transcend Jetram 2x2GB DDR2 800MHz
      • Samsung Spinpoint F3 HD502HJ 500GB 7200RPM
      • XFX Radeon HD6870 (GPU/Mem clock 900/1050 MHz)
      • Samsung SA300 LED 18.5" 1366x768 16:9
      • Creative Sound Blaster Play! USB 5.1 High Definition Audio
      • Creative Inspire 2500 2.1 / Sony MDR-EX082 Walkman IEMs / Shure SRH440
      • X5 Tech Multimedia Keyboard
      • Delux Dragon T6 M615 2000 DPI / SteelSeries Kinzu V2 Pro / SteelSeries QcK Mass Mousepad
      • Logitech Rumblepad 2
      • Antec Basiq Plus 550W
      • Samsung Super Writemaster DVD-RW
      • Transcend JetFlash 700 16GB USB 3.0
      • Windows 7 Ultimate x64
      • Finally time to GAME!!
      • Smile Broadband
    ScS :: XTR's Avatar
    my 2GB JetRAM JM800QLU module is at 460MHz (920MHz effective)
    ekta new cooler kinbo bhabtesi... konta bhalo hobe ? ei gulo kemon hobe ar price koto porbe brand new kinle ? -
    1. ASUS Silent Square Cooler
    2. Arctic Cooling Freezer 7 Pro
    3. Thermaltake V1AX
    kisu advice den keu.
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Go for Arctic Cooling freezer 7 pro. Its a great performer in its class.
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    Thanks. Ar, kontar price koto ?
    Ami oc korbo na, bhalo ekta cooler(+price) bolen non-oc'r der jonno.
    1k er kasakasi ache konota ?
    Ok, the situation is.... Something more than bad.
    Pc: pd 930 3ghz @ stock, gigabyte g965 mobo, 2 x 1gb ddr2 667 ram, geforce 9600gt 512mb ddr3 @stock, fake value-top 500w costed 1350/-
    facing immediate reset often now-a-days. Thought it must be psu so, getting a tt tr2 420w saturday. But, another problem existing for many days, and that is- my cpu cooler is creating too much sound... Rpm increases much, and remains around 4,600 even in normal times, saw in the bios. i'm not gaming for about 4 months. Pc runs around or more than 10 hours a day. And, temperature ? Forget it. :zz: its 90-92 degrees even in normal times, saw in bios. still using the stock pd 930 cooler, bought the cpu in april 2007. So, the stock cooler is running around 3 years. I think it's cooler's problem, and want to buy a new one for about 1k.
    Now, i can't open the pc, and posting from mobile.
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • 3TB Samsung (3 HDDs)
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • Generic Headset | Microlab FC550
      • A4Tech Generic
      • Logitech MX 518
      • Genius Speed Wheel 3 Vibration & MaxFighter F-23U
      • Thermaltake Toughpower 650W
      • Samsung
      • Transcend 16GiB USB3
      • None atm
      • Windows 7 | Arch Linux
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    Try cleaning the fansink with a good blower, used to work well for my P4 fan which had the same problem you're facing now.
    unless they introduce PoP/Mirror Edge styles with lara croft in bikini (gfx on par or better than AniMatrix), this game is hopeless =,='
  1. HDD Cooler Mod
    By ScS :: XTR in forum Hardware Modding
    Last Post: August 16th, 2011, 05:04
  2. Tower CPU cooler for Intel Gulftown
    By shaikh_imtiaj in forum CPU
    Last Post: September 29th, 2009, 23:45
  3. Want to Buy Processor Cooler
    By SK in forum Shop - Gadgets
    Last Post: May 15th, 2009, 13:05
  4. Replies: 15
    Last Post: October 16th, 2008, 11:37
  5. where can i buy a cpu air cooler in BD?
    By Evil Ryu in forum Technical Support
    Last Post: September 28th, 2008, 18:03
Page generated in 0.31581 seconds with 14 queries.
