Results 1 to 20 of 21
Thread: Gears of war problem
    • Necray's Gadgets
      • Gigabyte EP43-DSEL
      • Intel Pentium Core 2 Duo 2.8 Ghz
      • Transcend 4GB DDR2
      • Samsung 500GB SATA
      • ATI Radeon HD 4850 1GB DDR3
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • ASUS DVD Rewritable drive
      • Windows 7 Ultimate 32 bit
      • Smile Silver Package
      • 18
    Necray's Avatar
    Greenroad
    Default Gears of war problem
    It says - "You can not run the game with modified executable code. Please reinstall the game"
    First of all, I don't think it's a problem with the DVD since my friend could play it fine in Win XP(he says the game doesn't work in Vista). He did have a little problem- his save file would disappear if he didn't play the game for a few days He had the same problem with Assasin's creed but it worked fine in my PC(installed from the same DVD), so I'm not worried about it.
    Secondly, I googled the problem and downloaded the latest patches from Microsoft's games for windows website and Gamespot. When I run the patches, this shows up:-
    "Old file not found. However a file of the same name was found.No update done since file content does not match"
    What to do?
    • pollob.codename13's Gadgets
      • Gigabyte G31
      • Intel Pentium Duel Core E5200 2.5GHz
      • 1+1 GB DDR2 667 MHz
      • Hitachi 500GB
      • Sapphire ATI Radeon HD 4770 GDDR5 512 MB
      • Samsung SyncMaster B2030
      • Realtek built-in
      • csm
      • A4 Tech
      • Toshiba
      • Sonic Dual Shock
      • Normal
      • I always feel my pc
    pollob.codename13's Avatar
    Sep 2008
    Lalbag
    Default Re: Gears of war problem
    it may help .. sorry if u saw it before
    #5. Problem: “When I try to install the title update I get an error: ‘Old file not found. However, a file of the same name was found. No update done since file contents do not match.’"
    Information: It is likely that you are attempting to install the update on a Russian or Eastern European version of Gears of War for Windows. The information regarding the compatibility of this update with those language versions was inadvertently not posted along with the patch. While the error message is a little unclear when it appears it means that the patch did not get applied and your Gears of War for Windows installation should continue to operate correctly.
    Resolution:
    1) Do not attempt to install the update on a Russian or an Eastern European language version of Gears of War for Windows. The game will continue to operate properly and there is no impact on the ability to play with any other Gears of War PC player from any region. The Eastern European versions of the game include the Polish, Czechoslovakian, and Hungarian language versions of Gears of War for Windows.
    2) If you are getting this error message on a version of the game other than Russian or Eastern European it means the patch found some inconsistencies in the files that it is supposed to update so, rather than overwriting them it chooses to not install. It is possible your installation has become corrupted. A reinstall of the game should allow the update.
    NOTE: Remember, you do not need to uninstall the Games for Windows – LIVE redistributable if you uninstall the game prior to a reinstallation. Doing so may cause you to lose your saved game data.
    http://gearsforums.epicgames.com/sho...d.php?t=607234
    amar onek game e ei jater problem hoi. problem ta hochche, kisudin 1-2 din game ta cholar por ar chole na, kono luv hoi na reinstall kore. ei problem ta amar hoi ei sob game e -
    1. Gears of War
    2. Hellgate London
    3. Trine (A very attactive platformer game, pollob vai mone hoi khelsen, even better than Bionic Commando Rearmed)
    4. Lara Croft Tomb Raider Anniversary
    5. Thief - Deadly Shadows
    aro kisu kisu game e hoi may be. :S but, eigulo te je hoi, eita sure. windows reinstall or format kora chara hoi na. ei jonno ami eigulo game khelar jonno eigulo ke emon somoy install kori jokhon haate gaming er jonno prochur somoy thake. erpor ek dhakkai dhore ekta sesh kore delai. ei bhabe Gears of War ar Trine sesh korsi. amar OS holo Win XP SP2 (turned to SP3 by registry editing).
    • Necray's Gadgets
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • 18
    Necray's Avatar
    Greenroad
    Quote Originally Posted by pollob.codename13 View Post
    I don't think my one has a different language pack since like I said, my friend played it. I also reinstalled the game at least 3 times and it still shows the same error, so something else might be the problem.
    Thanks anyway
    Ami porsilam oder ki naki ekta DRM er bepar asey. Ekta particular date er porey ei game r cholbey na. Ei DRM er faandey ashol GOW owner rao porey gesilo. Ami nije onek asha korey GOW kinsilam. Kintu choley nai.
    Ektu thread hijack hochhey - onno gamer bhai ra kemney khelsen? Kon release ta kinsen?
    I wud really love to play this game. Apnader input chai pls.
    Win 7 32 bit.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Actually prob ta onno...ami sure na tobe ei gam e ekta built in timer ase...tai eita ekhonkar amole ar khela jai na...ami khelsilam amar computer er date change kore....jotodur mone pore april 01, 2008 dile perfectly kaaj korbe...eita try koren...
    • ЯV●FireBaLL's Gadgets
      • DFI LANPARTY UT x45
      • Core 2 quad q6600 3.1 Ghz
      • 4 GB ddr2 800 mhz
      • 250 GB hitachi 7200 rpm SATA
      • Sapphire HD 7850 OC 2 GB
      • 21.5" 2ms SAMSUNG LCD
      • Built-in-5.1CH HD
      • 800 W Pioneer 17" speaker (custom)
      • A4 tech (baal)
      • optical
      • LOGITECH RP2
      • 1000 W custom
      • Philips
      • Windows 7 64bit
      • SSC ULTIMATE AERO :)
      • 64
      • 18
    @avas 911 u r actually 100% right...this is the actual problem..aprl 1 2008 works fine...
    Go GET A FIREWALL SOON, I CAN SEE WHAT U R DOING RIGHT NOW IN YOUR PC haha!!
    • Exiled_SouL's Gadgets
      • Asus-p8B75-v
      • i5-3470
      • Corsair vengeance-8gb
      • Wd-1TB,Samsung/Hitachi-500 GB
      • Asus Gtx-670 DirectCU II-2Gb
      • Asus-22"+Samsung ES-5500 40" led smart Tv
      • Creative Sound Blaster-Z
      • Microlab Solo 7c/Skull Candy
      • Logitech G-510
      • Razer-Lachesis,A4tech X-747 with Steelseries QCK mini
      • X-360
      • Asus 750W
      • Asus Dvd Rw
      • Toshiba-500GB
      • General 1200VA
      • Win 7-64 Bit(Sp 1)
      • I am Loving It ;)
      • 60 KB
      • 15-20
      • 146
    Exiled_SouL's Avatar
    Jan 2010
    Earth
    I faced the same problem with gow. but the problem solved with patch 1.02.all u have to do is clean install of gow and then apply the patch and crack it,don't apply the patch with previous install else it won't work. I still have gow on my pc and running without any problem
    Quote Originally Posted by Exiled_SouL View Post
    Me too did the same thing in XP, but even after doing this, the game runs for 3 days maybe, and then it doesn't runs.
    Now, installed in 7 Ulti x64 a few days ago, let's see whether it works or not ?
    • arefinzz's Gadgets
      • MSI B85-G43 Gaming
      • Intel i5 4570
      • G.Skill Ripjaws 2*4GB DDR3 1600MHz
      • WD 2TB+Transcend 500GB external
      • Sapphire NITRO R9 390 8G GDDR5
      • Asus VX229H
      • Creative 2:1 & A4tech HeadPhone
      • Cooler Master
      • Storm Devastator Combo
      • Havit G83
      • Thermaltake Toughpower 650W
      • Asus DVD Writer
      • *Busted
      • Now it's time to game :)
      • BUCT
      • 2mb/s
      • 2mb/s
    arefinzz's Avatar
    May 2010
    ফার্মগেট,ঢাকা
    Can any one can give proper link of Patch and Crack please.
    Rion did GOW work on your win 7 64 bit?
    I have win 7 32 bit.
    I bought yet another copy from IT next. Wanted to play a little over the 15th Aug weekend. I tried twice 2 play but to no avail. The game has no clear instruction 'crack' instructions. Just the shopkeeper told me to reset date to 2007. The game files took hell of a time to extraxt - abt an hour! I was also delayed due to bloody lovely load-shedding!
    I am unsure abt a few things - where do I copy the startup.exe crack file? I pasted it in the program files folder, in the Binaries subfolder. Assuming that is the is exec file, I get the splash screen but the game crashes right after it.
    Really need some help guys -- wht else did u guys do?
    Ya, worked in 7 x64.
    And, u gotta paste in Binaries, what u did.
    And, I didn't change the date, I just DLed a patch & maybe a crack... :S
    Can't write any more, sorry, I'm busy... will write later...
    thanks.
    I'm giving a short tutorial. Tried in Windows Se7en Ultimate x86/x64 & in IT NEXT's 2 DVD original copy.
    Download this file: http://www.mediafire.com/?3em44maq0ei7fgp
    1. Extract from both DVD.
    2. Install the game, takes a long time. I installed disconnecting the internet.
    3. Apply the patch.
    4. Apply the crack.
    5. No need to change the date.
    6. Play!
    Thanks.
    Quote Originally Posted by Rion View Post
    3. Apply the patch.
    4. Apply the crack.
    6. Play!
    Thanks.
    Thanks Rion for detailed instructions but I tried twice 2day. Hoi nai. Onek jhamela hoisey.
    Extract kortey gelo 1 hr. Then install. Tomar patch apply korley bollo - INSERT CORRECT DVD AND RESTART APPLICATION. Tao crack merey chalailam -- eki message dilo. Abar try korar r dhoirjo chhilo na. Ramadan timings are very cruel. Abar time niye try marbo ne.
      • Intel i5 4570
      • Asus VX229H
      • Cooler Master
      • Havit G83
      • Asus DVD Writer
      • *Busted
      • BUCT
      • 2mb/s
      • 2mb/s
    arefinzz's Avatar
    May 2010
    ফার্মগেট,ঢাকা
    3. Apply the patch.
    4. Apply the crack.
    6. Play!
    Thanks.
    Rion please re-upload the crack file. i think it's corrupted.
    Quote Originally Posted by Xanadu View Post
    Kaj gulo koren internet disconnect kore.
    Install korar por PC ekbar restart den.
    Erpor patch ta install kore abar restart den.
    erpor crack ta apply koren. btw, 'binaries' folder e paste korte hoi amar jototuku mone ache.
    Hope kaj korbe...
    Quote Originally Posted by arefinzz View Post
    Bhaiya, ami crack ta DL korlam & extract o korlam... kono correuption to dekhacche na... :S
    Amar readme file ta open hochche...
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    ami rion er idea nia game kheila shhesh o koira falaisi...
    Onnoder prob hosse ken?
    I think I may have mis-pasted files. 1 ghonta dhorey game extract hoi. And that is just extract.
    Then install. Shetao onek khon lagey. Ami folder gula-r hishab rakhtey pari nai.
    Dekhbo porey try merey.
    Kin2 ami nijei sesh korte pari nai...
    damn my laziness...
    Rion tomar patch beboahr korley besh paach laagey -- lollz.
    Kintu shesh mesh chailaitey parsi.
    Date pichhaitey hoi. Kintu kheltey kheltey ek porjaye dektesilam je graphics prochondo choppy hoye gesey. Frame khub kattesilo. Action sequence e jodi frame kaatey darun mejaj kharap hoi. Guli korlam, grub akashey urey ektu jhuley thekey maati tey porlo.
    Exit korey dekhi - CPU meter showing a very stressed CPU - over 60%. Game exit korar por o cpu meter naamey na. 1 hr porey abar machine restart diye khelsi and things were smoother.
    And yes - AA off korey khelley game onek smooth hoye jai - tokhon oi lag ta besh komey jai kintu pura puri jai na.
  1. Gears Of War Savegame Problem
    By shaikh_imtiaj in forum Action-Adventure
    Last Post: May 5th, 2016, 15:18
  2. gears of war install problem
    By 61ZONE in forum FPS
    Last Post: August 27th, 2009, 23:56
  3. how to run GEARS OF WAR
    By ЯV●VenDeTTa in forum Action-Adventure
    Last Post: August 26th, 2009, 13:43
  4. Gears Of War 2
    By ЯV●FireBaLL in forum Upcoming PC Titles
    Last Post: October 3rd, 2008, 14:20
  5. Gears of War 2
    By Asif in forum Upcoming PC Titles
    Last Post: July 15th, 2008, 06:18
Page generated in 0.32024 seconds with 14 queries.
