Results 1 to 12 of 12
Thread: Torrent Problem
    • MWApocalypse's Gadgets
      • GIGABYTE G31M-ES2C
      • Intel Pentium Dual Core E5200 @ 3 GHz
      • Apacer 3 GB (2 GB+ 1 GB @800 BUS)
      • Samsung 320 GB
      • XFX HD4850 512 MB Standard
      • Samsung 20" widescreen LCD
      • Microlab 2:1
      • A4 Tech Multimedia
      • A4 tech
      • Thermaltake Litepower 400W
      • ASUS 24X DVD-RW
      • Windows 7 Ultimate 32-bit edition Build 7600
      • I fell in love with it...
      • Deltasoft
      • 20-35 KB/s
      • 35
    MWApocalypse's Avatar
    Shewraphara, Dhaka
    Default Torrent Problem
    Dui din holo ami Bittorrent speed kom pacchi.....ami niche ekta screenshot diyechi BitTorrent er...nicher dike ekta lal jinish mark kore diyechi.....oita ashar por theke ami usual speed pacchi na.....agei oita green chilo, tokon shomossha hoto na.....keo pls kindly ektu help koren.........
    • Red Devil's Gadgets
      • Gigabyte Z68X-UD5-B3
      • Intel Core i5-2500K Sandy Bridge @4.00 GHz with Corsair H75 LC
      • AVEXIR - Core Series 8GB(4GBX2) 1600MHz @9-9-9-24
      • Samsung 850 Evo 250GB SSD + Seagate Barracuda (4TB+3TB) HDD
      • MSI GTX 960 2GB
      • ASUS VX229H IPS Panel Monitor
      • Creative Sound Blaster X-FI Titanium
      • Altec Lansing expressionist ultra MX6021
      • Corsair Vengeance K70 Mechanical Keyboard
      • A4tech Bloody V9C/Razer Goliathus Fragged Control Edition
      • XBOX One Wireless Controller
      • Thermaltake Smart SE 630M || Cooler Master HAF 912 Advance Mid Tower Case
      • Pioneer DVD RW
      • Transcend V60 8GB, Apacer 2GB pen drive
      • RahimAfroz 800VA
      • Windows 10™ Pro 64 Bit
      • My PC is my life......
      • ICC
      • 8mbps
    Red Devil's Avatar
    Default Re: Torrent Problem
    Quote Originally Posted by MWApocalypse View Post
    it mean's all of port of ur connection is not open. & coz of this u r not getting full speed.
    btw....as i see.......ur isp name is delta......r they provide real ip...??
    usually....real ip na hole ai prob hoy.......
    Publisher
    • anik_lc's Gadgets
      • MSI B250M Bazooka
      • Intel Core i7-7700 Kaby Lake 3.6-4.20GHz 8MG Cache 7th Gen
      • 2x Corsair Vengeance 8GB DDR4 2400 BUS
      • Toshiba DT01ACA200 2TB SATA + 1TB Western Digital Blue
      • Sapphire Nitro + AMD RX 480 8GB GDDR5 OC
      • Samsung 21.5 inch Curved LED
      • Logitech H110 Headphone
      • Perfect CS-556 USB Keyboard
      • Delux DLM-137BU Optical USB Mouse
      • N/A
      • Thermaltake PS-TR2 600W 80Plus Bronze Power Supply
      • Power Guard 1200 VA
      • Windows 10 Pro
      • Very Satisfied
      • ICC
      • 300kbps
      • 400kbps
    anik_lc's Avatar
    Apr 2009
    ami to ajke onekkhon dhore download diye rakhsi. but kono download hochche na. ami uTorrent ar Bit Commet use kore dekhlam, same problem. some one help.
    Like my Facebook page Gaming Newz for new gaming news updates.
    My Facebook Twitter YouTube Steam
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    What do the Network Status lights mean (, , )?
    The green light means all is OK (ports are forwarded and you are receiving incoming connections)
    The yellow light means that you have no current incoming connections. If this never turns green, this means that your port is not forwarded. The best way to check is with the µTorrent port checker, found in the Speed Guide. If the port checker says your port is open, then everything is most likely fine.
    The red light means that µTorrent was unable to bind a listening socket. Most likely, this means a firewall is blocking it. It's also possible that another torrent client is using this port, which will require you to change ports, or not run both clients at the same time.
    It's what it says when you hover you mouse over it ;/
    A firewall or blocked ports are limiting your bandwidth.
      • Samsung 320 GB
      • Microlab 2:1
      • A4 tech
      • ASUS 24X DVD-RW
      • Deltasoft
      • 20-35 KB/s
      • 35
    Shewraphara, Dhaka
    @red devil....na, deltasoft ora real IP provide kore na
    @[TH7][coldfire7]....thnx bro.....wat do i need to do yo get rid of this problem?
    Last edited by MWApocalypse; November 29th, 2009 at 18:01. Reason: mistake in spelling
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    First go to preferences>Bittorrent and set "Protocol encryption" in outgoing to forced and check "Allow legacy incoming connections".
    Than Change your port.
    1. Click on the red icon. A dialogue box will appear.
    2. Change the port to any of these 21,22,23,25,80,8080,139,5555 etc. Now be careful these ports are primarily used in some applications. Like web servers usually use 80. If you use any service which conflict with any of these ports than dont use that one.
    3. Click test port. It will connect to a server and check for incoming connections. Keep checking until you get green sign from any of the above port.
    And finally if you are running any firewall or antivirus. Pls allow bittorent on it. Or allow it to connect to the internet.
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    I'm guessing it's your internet provider, they might be blocking BitTorrent (p2p) protocol by using a firewall (like my current internet provider deos ). So my advice would be 1st check your computer's firewall if it's blocking BitTorrent or not. If not then call your internet provider and talk to them.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    :S
    i have a weird problem here.
    I can download torrents through FDM but i can't download them through any torrent client.:S
    can't understand the problem.
    yeah.
    my lower bar also stays trigon.:zz:
    • cRush's Gadgets
      • Abit IP35P
      • Core 2 Quad Q6600 2.4Ghz (Oc @ 3.11Ghz ) 2*4MB Cache
      • 2*2GB Transcend DDR2 Ram @800Mhz (Oc @840 Mhz)
      • 320GB Hitachi HDD + 500 GB Samsung F3 HDD
      • Palit GTX560 Ti Sonic 1GB
      • Samsung SyncMaster932B 19" LCD Monitor
      • RealTek HD 7.1 Soundcard
      • A4Tech Headphones+ Creative 5:1 Surround Sound
      • A4Tech Anti-RSI Keyboard
      • Genius G500 Laser 2500dpi
      • Sony Sixaxis
      • ThermalTek 420W
      • Asus SATA DVDRW drive + Asus IDE DVD-combo Drive
      • Windows 7 RTM 64Bit
      • IT RAWKS :D
      • Local (STAR ISP)
      • 32 - 40
      • 40 - 60
      • 144
    cRush's Avatar
    my line is firewalled. but still get full speed
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    how can you get?
    please help all.
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    By protocol encryption. Which i explained in my previous post. Do that toi get full speed even when firewalled.
  1. BDCOM Torrent
    By dipanzan in forum Smile/BDCom
    Last Post: February 1st, 2013, 23:23
  2. Giving away 3 IP Torrent invites...
    By Reon in forum File Sharing and Torrents
    Last Post: September 4th, 2009, 04:10
  3. Torrent Download Problem
    By Speed in forum Technical Support
    Last Post: August 31st, 2009, 17:13
  4. torrent problem
    By saadbillah in forum File Sharing and Torrents
    Last Post: May 6th, 2009, 13:49
  5. !Torrent!
    By kabir_sharif2000 in forum Software
    Last Post: April 5th, 2009, 00:29
Page generated in 0.24415 seconds with 14 queries.
