Thread: Monitor buying help !!
    • Mahtab's Gadgets
      • BIOSTAR TA990FXE
      • AMD FX 8350 BE
      • 8gb corsair vengeance
      • 1TB
      • MSI GTX 670 POWER EDITION
      • SAMSUNG SYNCMASTER 22"
      • CREATIVE AUDIGY 4
      • CREATIVE INSPIRE AND MICROLAB TMN
      • A4TECH A SHAPED
      • GENERIC
      • XBOX 360 CONTROLLER
      • COOLERMASTER VS 650 WATT
      • ASUS
      • WINDOWS 8.1
    Jan 2012
    Default Monitor buying help !!
    Hi every one currently um using a 22inch samsung and was thinking of getting a bigger monitor for my pc my GFX card is Gtx 670 and
    I was wanting to buy 27inch monitor or 24 .... which one should I go for ??? 27'' or 24''
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Monitor er size boro hoilei je resolution boro hobe ta kono kotha na. Apnar 22', 23", 24" ba 27" jei tai kinen shob gular max resolution 1920 x 1080 (1080p). Apni jodi 22" currently use koren tahole IMO oitai jothesto. Ei size ar range monitor kinte gele apnar dekhte hobe input lag, color and contrast ratio ei dhoroner jinish. Personally ami 23" upore jaite chai na karon boro monitor e FPS type er game (call of duty) khelte onek jhamela lage.
    P.S.: Akta bhul korsi. 1080p er theke boro resolution er monitor paowa jai but onek dam.
    fps type game khelte je prob hoy sheta valo gpu thakle hobe??keno 27" porjonto shob gula res same??
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Quote Originally Posted by newgamer View Post
    Ki problem ta thik bujhlam na. Ektu elaborate koren. Amar ja problem hocche sheta holo je boro screen e kach theke boshe khelle left to right takai te jhamela hoi. Ami jodi screen er bam dik e takai thaki, screen er dan dike ki hoitese bujhte pari na, choto monitor-e ei shomossha hoi na.
    Eta ektu bhul bolsi. 1080p theke boro resolution er monitor paowa jai but onek price. Newegg e check korlam, $600 niche kono bhalo brand er monitor paowa jai na.
  1. Monitor buying help ;)
    By QuadStorm in forum Help - PC Buying
    Last Post: March 21st, 2013, 02:36
  2. Monitor Buying Help with in 20k
    By imn01 in forum Help - PC Buying
    Last Post: March 3rd, 2013, 21:44
  3. monitor buying help
    By terrygr8_007 in forum Help - PC Buying
    Last Post: October 16th, 2012, 14:10
  4. Buying monitor help
    By Artion33 in forum Help - PC Buying
    Last Post: September 18th, 2011, 14:56
  5. Monitor buying help
    By Aziz37 in forum Help - PC Buying
    Last Post: June 16th, 2011, 14:23
Page generated in 0.17015 seconds with 14 queries.
