Results 1 to 20 of 35
Thread: Case Airflow/Cooling
    • ScS :: XTR's Gadgets
      • abit IP35-E [P35 Chipset+ICH9]
      • Intel Core 2 Duo E6550 2.33GHz
      • Transcend Jetram 2x2GB DDR2 800MHz
      • Samsung Spinpoint F3 HD502HJ 500GB 7200RPM
      • XFX Radeon HD6870 (GPU/Mem clock 900/1050 MHz)
      • Samsung SA300 LED 18.5" 1366x768 16:9
      • Creative Sound Blaster Play! USB 5.1 High Definition Audio
      • Creative Inspire 2500 2.1 / Sony MDR-EX082 Walkman IEMs / Shure SRH440
      • X5 Tech Multimedia Keyboard
      • Delux Dragon T6 M615 2000 DPI / SteelSeries Kinzu V2 Pro / SteelSeries QcK Mass Mousepad
      • Logitech Rumblepad 2
      • Antec Basiq Plus 550W
      • Samsung Super Writemaster DVD-RW
      • Transcend JetFlash 700 16GB USB 3.0
      • Windows 7 Ultimate x64
      • Finally time to GAME!!
      • Smile Broadband
    ScS :: XTR's Avatar
    Question Case Airflow/Cooling
    I know that for maximum performance, a CPU Case needs good airflow and cooling. Now i want to know how you have managed a good airflow in your case. Do you keep one of your side panel open (like me) all the time? Or do you have fans for airflow? I need some tips. I'm not facing heat issue atm, but i had thought about it for a while and want to know what it takes for good airflow. Actually, the insides of my case gets dusty as i leave one side panel open. The reason i keep one side open is tht my casing is 11 years old and i cant buy a new case. I dont have any intake fans on front/side (my front side has a 80mm fan vent but the plastic front panel is blocking airflow). Dont have rear exhaust case fans either. I have a 120mm exhaust in my TR2-420W. i keep my passive 8500GT cooled with a P4 Intel Stock cooler. And now i want to know what i need to do so tht i can keep my case enclosed with the side panel. I havent tried re-attaching the side panel tho atm, im afraid tht i dont get enough cool air coming with the side panel attached... :/
    Thanks gladly for advice.
    P.S. i will try reattaching tonight tho, and if i face temp issues i will inform.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Default Re: Case Airflow/Cooling
    Well u got a cooler on ur passive 8500 n ur psu is also helping to outflow. For ur system grade no more cooling is that much necessary so u can close ur case without any fear (dust is much more dangerous than a little hot air)! If u need more mental satisfaction then put two 80 mm fan at front n rear (place carefully so front works as a inlet n rear do outlet) even ur case is blocking front fan, it will work good enough. 2 fan wont cost than 100. But trust me, u r good to go without the fans, but to be safer .... Do the extra fans if u feel.
      • Smile Broadband
    ScS :: XTR's Avatar
    thanks. i closed my case. im gonna run some games. If i get more temps than usual i will inform. Temps may vary tonight.. cuz its cold here. Thanks again tho
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • 3TB Samsung (3 HDDs)
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • Generic Headset | Microlab FC550
      • A4Tech Generic
      • Logitech MX 518
      • Genius Speed Wheel 3 Vibration & MaxFighter F-23U
      • Thermaltake Toughpower 650W
      • Samsung
      • Transcend 16GiB USB3
      • None atm
      • Windows 7 | Arch Linux
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    I agree with @marex, dust is deadlier than hot air (I learned that the hard way too). My old P4 (+8600GT) is housed in a case that has only an exhaust fan, and I kept the side-panel attached all the time. Never faced any heat issues. Mind you the p4 is a very hot cpu.
    On my current rig I have an intake and an exhaust fan plus vents on both sides and at the top. CPU idle temps are around 45-47C as I type now, and 48-49C during a very hot day. Pretty normal for a 130W CPU.
    unless they introduce PoP/Mirror Edge styles with lara croft in bikini (gfx on par or better than AniMatrix), this game is hopeless =,='
      • Smile Broadband
    ScS :: XTR's Avatar
    wow, thnx!
    yeah i just played some HAWX / CSS / Hitman blood money, temps are okay, i checked with RealTemp. But to be safe, i will add an intake front fan and an exhaust rear fan.
    thnx again for helping. but i want to know how the others are keeping their PCs cooled as this thread is about Airflow and cooling.
    • TAHMID's Gadgets
      • Gigabyte 946
      • Intel Pentium D @ 3.2 GHz
      • 4 GB [2GB+2GB] 800MHz
      • 240 GB [80 GB+140 GB]
      • *busted
      • 40" SAMSUNG LED
      • 5.1 surround sound
      • Chicony
      • MSD cosy multimedia mouse
      • XBOX 360 CNTRLR \m/
      • Thermaltake TR2-500W
      • Asus Quietrack 22x
      • SanDisk CRUZER micro 4GB
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • X360+ 40" LED, wh8 more do u need ?
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    Always keep in mind that proper air circulation depends on a properly placed case.
    Emonvabe place korba jate case er rear e air circulation er jonno space thakey.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Since I cant afford a liquid cooler (not available in bd) I placed four 120 cm case fan and Toughpower er fan to asei. It works for me (lot of noise though, but I dont mind)
      • Smile Broadband
    ScS :: XTR's Avatar
    ok, here are some pics
    My Case Click image for larger version.
    Inside Click image for larger version.
    GPU cooled by P4 Intel Stock Cooler Click image for larger version.
    CPU & PSU Click image for larger version.
    Front Fan Vent Click image for larger version.
    the P4 fan is pushing air towards the GPU HS. and the PSU 120mm is working as an exhaust... So is it good? i have checked my CPU temps with RealTemp.
    Idle : 38 C-42 C
    Load (gamin) : 42 C-53 C
    GPU temps are okay as usual.
    • WoH[AMON]~Lord SMS's Gadgets
      • Gigabyte EP45DSELR
      • Intel Core 2 Duo E8600
      • 2 GB Transcend DDR 2 800 (for the time being)
      • Samsung 500 GB
      • Sapphire HD 4870 1 GB
      • 17" CRT Samsung
      • XBOX 360 Controller for Windows, PS2 controller with adapter
      • Thermaltake ToughPower 600 W
      • Good Enough for DotA and FIFA
      • Bracnet
    WoH[AMON]~Lord SMS's Avatar
    Buet, Dhaka, Bangladesh
    accha. amar hall er room a onek dust hoe. kichu korar nai. and amar ager processor er cooling ei dust khaise. dust protection er kono way keo bolte parba?
    sounds funny, i know.
    Some qoutes that have helped me passing the 'moments' of my life:
    1. Accept your limitations, then go beyond them.
    2. Dont think old man. Sail on this course and take it when it comes
    3. I am who i am, not what i am.
    4. Life is too short to be pissed of all the time.
    5. Theists and atheists think alike while they face the real BAD of life
    6. You can never really know a man unless you walk in his shoes.
    7. Forgive thee, who bring upon hatred on you.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    blower machine kine nen.
    1-1.5 month por por blow korben taholei hobe.
      • Samsung 500 GB
      • 17" CRT Samsung
      • Bracnet
    Quote Originally Posted by @mrX View Post
    really??
    ---------- Post added at 22:43 ---------- Previous post was at 22:42 ----------
    Quote Originally Posted by Sumon Datta View Post
    actually.....
    ami eitai kori
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    Quote Originally Posted by WoH[AMON]~Lord SMS View Post
    really??
    actually.....
    ami eitai kori
    na mane apni bollen to tai bollam ar ki.:blush:
    ar marex bhai er- SLIP OF PEN.
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    Not Pen, it's finger :closedeyes:
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Amar slip of pen what? At lord sms apnar casing e joto fan slot ase sob gulate jodi outlet hisabe fan bosan tahole ektuo dust dhukte parbe na but all outlet config doesnt work as well as half inlet half outlet config but still its a good way for zero dust standard cooling.
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    apni je post korsen oikhane lekhsilen 120cm FAN.
    oto boro fan to shudu siling e tangano hoi.
    computer e kamne lagailen seitai boltesilam ar ki.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Ops slip of keyboard i guess XD
      • Smile Broadband
    ScS :: XTR's Avatar
    @marex bhai, apni amar front fan vent ta dekhsen? kibhabe eita diye cool air case e ashbe? shamne to plastic, tao abar hole nai.. :/
    • TAHMID's Gadgets
      • Gigabyte 946
      • *busted
      • 40" SAMSUNG LED
      • Chicony
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    Quote Originally Posted by ScS :: XTR View Post
    Idle : 38 C-42 C
    man,thats the same case i used back in 2002.
    LOLz
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    sadharonoto ei dhoroner casing e front cover er niche (I mean tolay) faka thake air pass korar jonno. Casing ulta kore dekhen eitar ase kina.
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    tt & antec both have separate accessories of dust protector asey....but,oigula bd porjonto poichai na......cost o kom.....money hoy 5~10$ korey per piece.....
    ---------- Post added at 02:15 ---------- Previous post was at 02:14 ----------
    amar 3x120mm,2x80mm asey.....ar antec 1200 jokhon pabo(insha allah next year e) tokhon 8 ta 120 mm hobey
    tokhon dekhabo cooling er new definition
  1. Advice in buying a pc case
    By craNIUM in forum Others PC Hardware
    Last Post: August 6th, 2009, 11:46
  2. Searching Case Fans
    Last Post: July 3rd, 2009, 11:02
  3. Replies: 5
    Last Post: May 1st, 2009, 03:46
  4. Water Cooling Pump (not Pedrollo ones u dummy!)
    By minitt in forum Others PC Hardware
    Last Post: February 22nd, 2009, 01:23
  5. Thermaltake's New CPU with Nice cooling
    By darkcrunk in forum Others PC Hardware
    Last Post: January 4th, 2009, 10:27
Page generated in 0.33605 seconds with 15 queries.
