Results 1 to 20 of 22
Thread: Suggest me a low watt build for 24/7 torrenting
    Lightbulb Suggest me a low watt build for 24/7 torrenting
    I intend to build/buy a low watt system for 24/7 torrenting and file server for my home.
    Conditions:
    -While torrenting power consumption should be below 50 watt as it will be running with IPS support.
    - Budget is less than 10K.
    - Has to be durable since it will be running 24/7
    Considering below options atm:
    1. Used netbook with Intel atom cpu (Not sure if it can survive 24/7 of torrenting)
    Why?
    -Becaz power consumption is really low
    -Can safely shut itself off if IPS runs out
    2. Used core 2 duo system. (The whole system probably will cost less than 6K but idle power consumption will be too high than option 1.
    3. Buy a new Mini ITX box by Dell. I believe they are available at IDB
    Please feel free to place your suggestions/tips/options keeping in mind that I have to source my system/components from dhaka only.
    Regards.
    Why dont you buy Raspberry Pi ? Those will cost you 5k and very good for ftp and torrent sharing things
    buy a tablet with large SD card? Depends on how much you want to keep on it though.
    Conditions:
    Why?
    Regards.
    Do you have a link for that mini ITX box from Dell?
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    A p4 machine is enough for that...I have a p4 used for torrenting and it also runs as Wingate server running 24/7
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    though you said you cant afford to buy things from abroad, still i suggest you to buy entry level NAS. it is less power consuming and can run continuously. i am personally using one. and it is within your budget if you can import properly
    http://www.amazon.co.uk/ZyXEL-NSA310...s=zyxel+nsa310
    http://www.amazon.co.uk/D-Link-Share...cp_computers_1
    both are very good for torrenting. only negative thing is they are slow. slow like you will get only 10-15 MBps speed when transferring to other devices. otherwise they are damn good for day to day use.
    @sensei I thought about that option initially but then sourcing all the parts is a bit problematic. Besides the learning curve seems a bit stiff for me since I won't be able to allocate req time and effort into it.
    @aayman well could be a really good option yet I have 3 concerns. One is, will it survive? Two, is there any compatible torrent clients that support private tracker such as IPT? I tried installing bittorrent in my Nexus 7 (2013 non LTE) and it didn't work with IPT.
    & 3,(if first 2 issues are resolved) which tablet u have in mind that costs less than 10K?
    Do u think a cheap netbook should be able to serve my purpose?
    @dipanzan at binary logic. ask @Speed pagla. He bought 1 recently.
    @optimus prime I think core2duo would be better as it has better power mgt. Btw r u using wingate to aggregate several internet connection?
    @codename5302 10-15 MBps!! lol onek beshi slow hoye jai bro. + i don't think they r avail. in BD for less than 10K.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    @minitt , do you have any idea whether the dell mini itx case comes with micro atx power supply or adapter?
    and of course NAS is not available here. only handful of companies use it in bd. but i recommended it for less hassle and power consumption. you just have to put your hd in and it is ready to run. if you build a torrenting pc, then you have to install os and configure it properly and yes your custom built pc will be much more powerful than entry level NAS.
    If netbook is an option, then go for it.
    they come with usual power supply feeding on 220 ac
    @aayman I'm on it . let's see if I can get 1 under 10k.
    If any 1 got an old c2d PC pls give me a buzz.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    @Speed How much is the dell itx box and can you provide me a link?
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
    10K mone hoi w/o hdd. powered by intel Atom cpu
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Link?
    Quote Originally Posted by optimus prime View Post
    bhai p4 ki??
    OP apni amare aktu bujaye bolen t aishob jeta kinte chacchen shetar kaj khali download e kora??ogula ki os?ogula khali torrent dl kora jai?dl shudu ki nijer personal kaje e korben?
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • 256
    I am using wingate to segregate 1mbps connection. ... we have a lan in our area.we share this connection
    Quote Originally Posted by newgamer View Post
    bhai p4 ki??
    P4 means pentium 4 processor. ..they are very cheap now in the old market. ..a p4 cpu can be built within 3~4k......and about the 2nd ques they are standard platforms and can be used for various purposes. ..depends on the user really
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    https://www.facebook.com/photo.php?f...type=1&theater
    i bought this one but,configured by my own specification. like i deducted:
    1.HDD
    2.Monitor
    3.Mouse & keyboard
    4.ODD
    & it costed me 11,000 with 1 year warranty.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    it's not dell mini itx. it is inwin casing. i built my htpc with this case.
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    @minitt , i have P4 2.4GHz CPU + Motherboard + 1GB DDR1 RAM... you are welcome to take it from me, free.
    Quote Originally Posted by Syeef View Post
    Thanks for the generous offer but I can't get it for free I'll table my offer inline with mkt price. But I'll take it only if I fail to get something better.
    If you get any offer for this P4 system from any1 pls give me a buzz.
    • Syeef's Gadgets
      • N/A
      • Creative SBS 2.1
      • 650VA
      • ~5 Mbps | 32 KB/s
    No intention of selling it... if you want it, you can have it.
  1. Want to Buy psu 550 watt minimum or above 550 watt
    By zinzhia mahmud in forum Shop - Gadgets
    Last Post: November 30th, 2013, 15:56
  2. How to build a PC: Step-by-step instructions for a custom build
    By emroz_2272 in forum Technical Support
    Last Post: December 19th, 2012, 15:52
  3. Suggest me a Kill-a-watt for our country
    By VANGUARD in forum Help - General Shopping
    Last Post: November 6th, 2012, 20:31
  4. Want to Buy PSU 500/550/600 watt
    By LizZzaRd in forum Shop - Gadgets
    Last Post: October 9th, 2011, 21:19
  5. Sale (New) Delux 450 watt PSU
    By soul soccer in forum Shop - Gadgets
    Last Post: October 9th, 2011, 01:29
Page generated in 0.32419 seconds with 14 queries.
