Results 1 to 10 of 10
Thread: Problem with keygens and patches
    • Necray's Gadgets
      • Gigabyte EP43-DSEL
      • Intel Pentium Core 2 Duo 2.8 Ghz
      • Transcend 4GB DDR2
      • Samsung 500GB SATA
      • ATI Radeon HD 4850 1GB DDR3
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • ASUS DVD Rewritable drive
      • Windows 7 Ultimate 32 bit
      • Smile Silver Package
      • 18
    Necray's Avatar
    Greenroad
    Default Problem with keygens and patches
    Onekshomoi kono software er keygen or patch open korte gele "you don't have the permissions" type error dekhai. Ekbar ami net connection disable kore click korsilam, dekhlam kaj hoilo. Ei matro ami Daruchini theke PowerDVD 9 namailam, keygen e click korle abaro oi error dekhacche. I use AVG 9, eita disable korar poro problem hocche. What will I do?
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    Default Re: Problem with keygens and patches
    Almost every patch has builtin win32trojan/keylogger which may disable your valuable security.
    and antivirus and Windows firewall sometimes block it to prevent data from being stolen.
    • Necray's Gadgets
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • 18
    Necray's Avatar
    Greenroad
    Quote Originally Posted by Sumon Datta View Post
    But how can I run the keygen?
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Quote Originally Posted by Necray View Post
    windows firewall diseble koren and avg uninstall kore try koren.
    Try in safe mode.Crack the app and reboot
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    That's another right solution.
    Member Valkyrie™'s Avatar
    If you are using SP3 then you may face this problem. What you have to do is, go to add remove programs and uninstall the internet explorer security updates. This may help.
    Bleh.
    Wink Re: Problem with keygens and patches
    Quote Originally Posted by Valkyrie™ View Post
    And why would "it" work?
    The ie kernel never messes with files unless a website or script wants it to.
    Mine will work(seemingly) because safe mode doesn't load the interfearing programs at startup.
    • Necray's Gadgets
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • 18
    Necray's Avatar
    Greenroad
    How to run in safe mode? I forgot
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    When Motherboard BIOS screen appears keep pressing F8 if you don't know the correct time.
    It will make you go to the Safe mode.
  1. CNC RED ALERT 3 Patches.........
    By Red Devil in forum Command & Conquer
    Last Post: October 13th, 2009, 20:00
  2. FIFA 10 Tips FIFA10 demo patches
    By Uchiha Obito in forum Older FIFA Games
    Last Post: September 19th, 2009, 00:46
  3. Need keygens of some softwares
    By Necray in forum Software
    Last Post: March 30th, 2009, 21:17
  4. FIFA 09 Media FIFA 09 Patches
    By abir in forum Older FIFA Games
    Last Post: December 24th, 2008, 15:07
  5. FIFA 09 Tips How to Download & Install Patches
    Last Post: November 5th, 2008, 13:37
Page generated in 0.22051 seconds with 14 queries.
