Thread: Matlab problem
    • saadbillah's Gadgets
      • Intel D945GCNL | Intel GL40
      • Core 2 Duo E6300 1.86 GHz | Pentium Dual Core T4200 2.0 GHz
      • 2 GB | 2 GB
      • 120 GB | 320 GB
      • ASUS EN8600GT 512MB Silent Edition | Intel GMA4500
      • F&D F3000U 5:1
      • Generic Crap
      • Windows XP | Windows 7
      • 64
      • 18
    saadbillah's Avatar
    Default Matlab problem
    Aj k win 7 install korlam, ekhn matlab 2007a install korte giye bipode porsi.
    Jokhn name,org & serial no. Diye nxt dei, tokhn kisui hoy na... Oi page ta tei atkae thake...
    Vous n'avez pas vraiment connaître quelqu'un qu'en le combattant.
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    Default Re: Matlab problem
    I found this somewhere, seems like the problem is with the new windows 7 theme.....
    To install Matlab 2007 on windows 7
    1-Change Windows 7 Theme to the classic one (windows classic)
    2-now the Matlab install will work correctly
    To use Matlab with other windows 7 themes you have to change java used by matlab.
    1- download latest java version and install it.
    2- go to C:\Program Files\MATLAB\R2007a\sys\java\jre\win32 you will find a file named jer1.5.0_07 rename it to Original_jer1.5.0_07
    3- go to C:\Program Files\Java you will find file named jet6 (jetX for Xversion) copie it to C:\Program Files\MATLAB\R2007a\sys\java\jre\win32
    and rename it to jer1.5.0_07
    Now you can use matlab with all themes.
      • 2 GB | 2 GB
      • 120 GB | 320 GB
      • F&D F3000U 5:1
      • Generic Crap
      • 64
      • 18
    saadbillah's Avatar
    yeah... i also found this post & solved the prob .....
    thanx anyway
Page generated in 0.15212 seconds with 13 queries.
