Thread: Need help on rooting an ancient phone.
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    Default Need help on rooting an ancient phone.
    first i should declare that i am total noob in this rooting business. i have an ancient phone Galaxy S I9000 (2010 era) which was with orange. but later i unlocked it by requesting orange. it has android 2.3.5 os. now there are plenty of guides in web about rooting android os. but none of them are simple. i am requesting if someone can share a easy method. thanks in advance.
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Framaroot. The easiest method.
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    ^^This
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    thank you all
    one question, will it enable me to uninstall unnecessary softwares that came with the phone and will there be problem with my existing software and games?
    • ShouravBR's Gadgets
      • Gigabyte B150M-D3H
      • Intel i3-6100
      • 2x DDR4 4GB
      • Transcend 128GB; Toshiba 1TB
      • Sapphire R7 260x 2GB
      • Samsung SyncMaster (1920x1080)
      • A4Tech Wireless
      • A4Tech Wireless
      • Gigabyte Hercules x580
      • Minecraftable.
      • ICC 2Mbps
    ShouravBR's Avatar
    Apr 2013
    Yes, I think so.
    You should do some kind of backup before rooting & flashing new ROM.
    Maybe Helium could help.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    thank you all
    for backup...titanium backup....or full existing ROM ta backup dawar jonno Twrp er recovery mode er theke better kichu dekhtesi na...ei backup ta computer er system restore er moto onekta
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    use rom manager to install cwm or twrp recovery after rooting.and take a backup.now!!ur ready to play with ur phone safely
  1. Xperia Neo V rooting/flashing
    By Badhon_raj in forum Technical Support
    Last Post: May 20th, 2013, 10:43
  2. Raw: Realms Of Ancient War
    By arefinzz in forum Upcoming PC Titles
    Last Post: September 5th, 2012, 05:24
  3. rooting xperia mini pro
    By Rajmi in forum Technical Support
    Last Post: April 9th, 2012, 00:04
  4. An Ancient GPU
    By Uchiha Obito in forum GPU
    Last Post: May 30th, 2009, 14:10
Page generated in 0.18990 seconds with 14 queries.
