Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
Thread: Some Questions Regarding Sound Quality!!!
    • ATypicalAssasin's Gadgets
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • AMD HD7770 GHZ OC 1gb ddr5
      • Samsung Magic Eco 22 inch Full Hd
      • Beats by DR.DRE PRO
      • Lexma
      • LogitechB100
      • Thermaltake Litepower v3 500watt
      • Samsung DVD writer
      • Racing Car pendrive 2gb
      • Prolink
      • Windows7 Ultimate 64bit
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    ATypicalAssasin's Avatar
    Venezia
    Post Some Questions Regarding Sound Quality!!!
    [FORGIVE MY NOOBNESS.STILL LEANING THE ROPES]I use Beats PRO headphones.Some Says they are いい but they are Good for music and for gaming it's OKAY.I did not buy it,got this as a gift.
    So,I wanna get the best sound quality out of my pc.I use a Realtek HD sound card.When I bought my pc,the shop said that sound cards are Expensive for windows 7.And also they could not manage a single sound card for me.They said my pc sound will come from motherboards built in sound facillity or some いい like that.
    When i came home i found that my pc has a Application REALKTEK HD AUDIO MANEGER.I also can plugin sound devices like headphones,speakers,in the back 3.5mm ports.So That defines that I have a sound card.
    There my sound environment settings are at ROOM.
    I have my own Equalizer settigs.
    My default format is @24bits,192000Hz Studio Quality.
    When i changes this eq,environment,bitrate settings,my main sound settings @control panel changes according to that.So Realtek HD audio maneger controls my pc's main sound settings.
    What is Bitrate quality,like CD,DVD bitrates,hz.Please Explain.I wanna get the best outta my PC.
    Again,sound quality is something that not everybody understands.
    1) you use beats by dre????????????????
    2) u use built in soundcard????
    dude what would be ur budget for sound card?
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    ur q no 1 YES i use beats by dre!
    2nd one I am not sure.
    What would you suggest if budget is 4k?
    @Taher furious
    Quote Originally Posted by *,....,* View Post
    @Taher furious
    nothing.
    You should increase your budget to at-least 7-8k for a decent sound card. or you should search for a second hand one.
    1. first of all for driving headphone u will need a good headphone amplifier. Built-in sound cards do not(most of the time) come with headphone amplifier so the sound quality wont be that great. so you will need another sound card, one with a separate headphone amplifier section.
    your motherboard has a ALC892 Realtek audio codec which is not bad either. but if u need real audio quality buy any Asus/Creative soundcard.
    2. bit rate is the number of bits carried in a certain time. and bits mean data. so more bits per second more data per second which will result in better quality.
    3. if u even have everything, u wont get good sound if u dont have better source. most mp3 files are 16bit 128-320Kbps so setting the sound card to 24 bit wont do much difference.
    but if u work on audio software, like when i work with audition i use 32bit audio for intermediate level. then when finalized, i set it down to 16bit mp3 for saving space.
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    Headphone amp ar dam koto.And If i install a new sound card do i need to re-install my windows???Cause it's nothing like or gpu....
    Thanks for the great explanation @redwan hasan
    je sound card er kotha bolsi ogular sathe built in headphone amp deya thake. so just sound card kinlei hobe.
    and no u dont have to reinstall windows. just plug in the card in proper slot(PCIEX1, PCIEX16, PCI)
    install the driver. you are good to go!
    anyway i have found this one in ryans page
    http://www.ryanscomputers.com/Creative-Bla-888
    it has built in audio amp. http://asia.creative.com/p/sound-bla...fi-titanium-hd
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    Thanks for your help.
    one more thing. your gadget says u have Intel DH61WW board. If u buy a sound card of x1 slot and install it, it will prevent u from installing a dual slot graphics card.
    and if u have a dual slot card right now, u wont be able to use the x1 slot.
    so u better look for a card which uses PCI16X slot.
    anytime
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    But hey,on the back of the card there is white red and red and white.Where do i connect my headphone or Speakers to,Should it be green and pink coloured?Dekhe to 3.5mm mone hocche na. @redwan hasan
    this card has only two 3.5mm jack.rest are RCA jacks. color coding is not mandatory.
    anyway spending this much money on this card is not worthy i guess(as ur target is only getting better quality audio from the headphone), better get something that will cost 7-8K.
    but i knew that mini pci er sound card boro pci support kore and vice versa?
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    Yeah..Those are RCA jacks.What good card can I get within 7k-8k?With heapphone amp..
    yes u can put a x1 card in a x4/x8/16 port. but you cant put any pci express card in pci slot or vice versa.
    u can put a pci express card in other pci express port but not in pci port.
    first two white slots(marked in red) are PCI Express x1
    three green marked slots are PCI Express X16, x4,x8.
    you can interchange between them. like u can put a x1 card in any of these slots.
    but but lower white slots are PCI 16X slot. u cant put pci express cards there.
    onk din sound card er market dekhi na. tai surely bolte parlam na. Asus/Creative er kisu pawa gelei hobe.
    it seems like i knew it all wrong from ma childhood
    as far i knew i can put a mini pci sound card or big pci sound card in any red circle mini pci port u marked, or the last 2 black marked pci port.
    and the 3 green circled pci express port u marked are only for pci express cards i mean gpu. as far i know those green pci express ports dont support sound/lan cards! correct me if i'm wrong :'(
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    Yeah maybe.A further explanation would be fine @redwan hasan
    I Just buy a Sound card with 7k or 8k and Turn my pc on and uninstall the old card driver,software etc.Then turn my pc off.plug off the old card and put the new card where the old one was plugged.Then turn on the pc and install the new driver for the new card.Now this is what I think.If i have missed any important point please correct me.Please also state what i need to be aware of about PCI Express. বেশি টেক নি কাল হয়েন না।আমি এসব আবার ভাল বুঝি না। @redwan hasan
    Ar.Ami jani na if my GPU uses dual slot.My gpu is sapphire HD7770.Does it use Dual slot?
    First 5 slots are PCI Express Slot.
    And two lower slots are PCI slot. not PCI Express.
    GPU is not only the PCI Express supported card. you can use Sound card, 10Gb Ethernet card and anything that supports PCI Express.
    You cant put a x16 card in a x1 slot though they use the same technology but x16 cards wont fit in x1.
    you can put a x16 card in x8/x4 they will run accordingly.
    this is a PCI E x8 LAN card. u can put it in x4 and x16 too.
    http://www.ebay.com/itm/Intel-NetEff...item1e7b3aaad4
    lower white ports supports all kind of PCI cards. but wont support PCI Express card. u can simply tell that from their position. u cant push a pci e card on this coz this port starts from a bit different place.
    uninstalling old drivers is not must,
    just turn off ur machine, plug in the new card, install driver, restart, that would be all.
    I believe that's ur board. u r already using the blue x16 slot. and 7770 is a dual slot card so i guess it has already covered the black PCI E x1 slot. so the only slot that is usable for u is the lower PCI 16X slot.
    that means i knew wrong info all along.
    correct me if i'm wrong about the following statements>>
    1. Buying a sound/lan/sata/fata card, I always have to double check whether it has pci or pciE (even if it has big port i cant be sure its pci).
    2. If it has a mini port then i can be absolutely sure its pciE x1 card. Which i can connect in either mini pciE slot or pciE x16 slot (also known as grafix card slot).
    1. yes. check the bus compatibility of this following products.
    http://www.asus.com/Sound_Cards_and_...specifications
    http://www.asus.com/us/Sound_Cards_a...specifications
    2. yes. if it is the smallest one, its the x1slot. x4 is slightly bigger than that one.
    one more thing is, PCI runs at 33MHz where PCI Express runs at 100MHz so interchanging is not possible.
    though the smallest one is x1 dont mix it up with mSATA slot
    plus check the "notch position" "length" "starting and ending point"
    you will clearly see x1 is compatible with x16 but none of them is compatible with PCI ports.
    'Name:  slot-types2.jpg
      • Intel WWh61
      • Core i3 2120
      • Crossair 2X3=6gb
      • 500gb
      • Lexma
      • LogitechB100
      • Prolink
      • Alhamdulillah
      • 270kb/s
      • 20kb/s
      • 10
    Venezia
    Thanks teacher.I believe There's the old sound card plugged some where.If the GPU uses dual slot,and the sound card uses one slot,where is another empty slot?Or I will be able to uninstall the old sound card and install the existing one there depending on what slot it requires PCI E or PCI only etc.
  1. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    By areek in forum Shop - Gadgets
    Last Post: August 23rd, 2013, 23:34
  2. Where to get quality movies?
    By [email protected]$t3rz3r0 in forum Movies & TV
    Last Post: February 13th, 2013, 18:02
  3. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    Last Post: December 30th, 2012, 17:27
  4. Sale (Used) Creative Sound Blaster AUDIGY Value 7:1 Sound Card
    By Reventon in forum Shop - Gadgets
    Last Post: February 10th, 2011, 17:22
  5. UT 3 Performance VS Quality
    By Walking Death in forum Unreal Tournament
    Last Post: May 4th, 2009, 01:19
Page generated in 0.32924 seconds with 15 queries.
