Results 1 to 11 of 11
Thread: Get 5.55 and 6.00 games running on lower firmware.
      • MSI Z68-A GD65
      • Intel 3770K @4.5GHz (Cooled by Kuhler 620)
      • Corsair Vengeance 4x4GB 1600MHz
      • SanDisk SSDX 120GB + HyperX 3k 120GB + 1TB WD Black
      • 2x670 ASUS DC2 TOP
      • Dell U2312HM
      • ASUS Essence STX
      • KRK KNS 8400
      • CM QuickFire Pro (Red)
      • Zowie AM
      • 360 Wireless Controller
      • ASUS External Drive
      • CyberPower 1350VA
      • Windows 8 x64
      • Proc- 8.0, GPU 8.3
      • いいING AWESOME!
      • Comcast
      • 146
    where I rightfully belong.
    Default Get 5.55 and 6.00 games running on lower firmware.
    I wrote this guide for pspscene.net. Maybe some of you here will find it useful as well.
    Hey guys,
    you can now finally play the new games on your PSP.
    For this to work, you need:
    1)PSP 1000/2000/3000 (Yes that's right, even 3000s)
    2)USB Cable
    3)Original untouched ISO of the game
    4)Ability to read and just a little and mean very little common sense.
    So let's get started:
    1)Download-
    UMDGEN 4 - http://www.megaupload.com/?d=F7Y7RNMF
    Game Decryptor - http://www.megaupload.com/?d=JQFUIF8V
    Why games didn't work before?
    From firmware 5.55 and onwards, Sony decided to up their game against PSP piracy and finally increased its security. UMD's have eboot files contained in them, and from 5.55+, the eboots used a new form of encryption method which lower firmwares couldn't read.
    Hence the only way to play these new games was by releasing a new firmware OR by decrypting the eboot file itself. Its the latter that you'll be doing. I'm pretty sure from now on, you'll see the games prepatched, but for the current games which you already have downloaded but can't run, you should just use this instead of downloading it again.
    If you haven't downloaded the files yet, I suggest you do as the process is very simple, and you can just do it at one go.
    2)After you have extracted both UMDGEN and Game Decryptor(GD), copy the GD folder to X:\PSP\GAME. (X being you PSP drive letter)
    3)Run UMDGEN and open the ISO file.
    4)The UMD will now be opened and you can see its contents on the right pane.
    5)Then browse to PSP_GAME\SYSDIR and right click and select 'Extract Selected' on the EBOOT.BIN file
    6)Save the EBOOT file somewhere in the PC and then copy it to the root of the PSP's memory stick. Don't close UMDGEN yet.
    7)Disconnect the PSP and run GD.
    8)You'll see some info, press O to continue. Wait for it to be decrypted and patched. The app to shutdown by itself.
    9)Connect the PSP again, you will now see a new folder in the root named 'DECRYPTOR' and inside it you'll have the decrypted EBOOT file. The one on the root is the original one, you can delete it now.
    10)Remember I asked you not to close UMDGEN, well, now just drag and drop the decrypted EBOOT from the 'DECRYPTOR' on the right pane of UMDGEN. The files will be overwritten.
    11)Now click 'Save' on UMDGEN and give a name to the new ISO.
    12)Copy that new ISO to the PSP and enjoy the game.
    The new ISO will run on firmwares 5.00m33 and above.
    Note: If you press X instead in GD, then the game will only work on 5.50GEN-B
    I already tested this with GTP and GTA, and its running fine. Dev did mention that this might not work for all games, so lets just enjoy the ones which it does on.
      • MSI Z68-A GD65
      • Dell U2312HM
      • ASUS Essence STX
      • KRK KNS 8400
      • Zowie AM
      • CyberPower 1350VA
      • Windows 8 x64
      • いいING AWESOME!
      • Comcast
      • 146
    Default Re: Get 5.55 and 6.00 games running on lower firmware.
    Guide updated with pics and links to latest versions of the apps.
    Sad that I didn't get a single 'Thank You'
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    2 weeks??Sry didn't noticed this thread
    Thnks a lot bro.....now my fifa 10 works perfectly.....:-)
      • MSI Z68-A GD65
      • Dell U2312HM
      • ASUS Essence STX
      • KRK KNS 8400
      • Zowie AM
      • CyberPower 1350VA
      • Windows 8 x64
      • いいING AWESOME!
      • Comcast
      • 146
    You dont need to patch games anymore, upgrade to 5.50GEND2 /5.03GEN-D(PSP 3000's only)
    Member GT3600's Avatar
    middle of nowhere
    psp 3000 er jonno o ki ei upgrade kora jabe??...
      • MSI Z68-A GD65
      • Dell U2312HM
      • ASUS Essence STX
      • KRK KNS 8400
      • Zowie AM
      • CyberPower 1350VA
      • Windows 8 x64
      • いいING AWESOME!
      • Comcast
      • 146
    Ha, 5.03GEN-D ta PSP 3000 er
    • ЯV●shafiee007's Gadgets
      • eVGA X58 SLI Micro
      • Intel Core i7 920 Nehalem 2.66GHz L3 8MB cache Quad Core
      • 3x2GB Corsair XMS3 DDR3-1600 Tripple channel (8-8-8-24)
      • 1.5TB WD Caviar Black + 250GB Samsung HDD
      • Sapphire ATI 5870 1GB GDDR5 256-bit PCI-e
      • ASUS 21.5" VH222H HDMI
      • Steelseries Siberia with 7.1 USB sound card, Altec Lansing 2.1
      • Steelseries MERC Stealth
      • Razer - DeathAdder
      • Logitech G25 Racing Wheel, Xbox360 controller, Genius Maxfire G-12U, Creative Cobra 2, XFX Xgear
      • Corsair TX750
      • Lite-on SATA DVD writer
      • iNeat 1200VA
      • Windows 7 64-bit
      • It's great... but my consoles are much better !
      • 170KBps
      • 100KBps
      • 18
    ЯV●shafiee007's Avatar
    Pit Stop
    umm.. ami ekta n00b question ask kori..
    eitar mane ki hoilo.. PSP 3000 er jodi 5.50 firmware hoe.. tao ki game khela jabe? naki shei 5.03-ee lagbe ager moton :S
    PSP kinar ichcha ekhono jae nai... but ei firmware issue er jonno-ee boshe asi
    Red ViperZ---ЯV●shafiee007
    middle of nowhere
    Quote Originally Posted by ЯV●shafiee007 View Post
    PSP 3000 er jonno 5.50 na........ 5.03 gen-D bollo aayman....termane ekhono 5.03 e hoya lagbe PSP3000.....
    naki vul bollam??....
      • MSI Z68-A GD65
      • Dell U2312HM
      • ASUS Essence STX
      • KRK KNS 8400
      • Zowie AM
      • CyberPower 1350VA
      • Windows 8 x64
      • いいING AWESOME!
      • Comcast
      • 146
    Yes you are correct GT. Onno PSP gular jonno 5.50GEND. Firmware restriction akhono ase but PSPGO'r hack er proof of concept mone hoi dekhano hoise, so there might be a hack available in the near future.
      • Corsair TX750
      • iNeat 1200VA
      • Windows 7 64-bit
      • 170KBps
      • 100KBps
      • 18
    Pit Stop
    aah.. good to here that...
    jodi PSP GO hack hoy, taile oita kinbo
  1. Replies: 11
    Last Post: February 22nd, 2010, 14:41
  2. Replies: 0
    Last Post: August 11th, 2009, 21:53
  3. Replies: 4
    Last Post: April 30th, 2009, 09:20
  4. PS3 Firmware 2.60 Live
    By FARHAN-FX in forum PlayStation
    Last Post: January 31st, 2009, 13:01
Page generated in 0.50847 seconds with 14 queries.
