Thread: Help.! Pc not starting..
    Default Help.! Pc not starting..
    nothing!
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    Get a new CMOS battery? -_-
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Get a battery quick. IDB will be closed from tomorrow.
    Also check the RAM. Reset the RAM module.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by Asif 11 View Post
    ram ok. Ram thik na thakle amr motherboard 3ta beep dei. Cmos battery change korlei prob solve hobe?
    Then try with the CMOS battery. It has to be same, so bring the existing battery.
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    kisukhon age ekta same battery kine ansi(newsun 3v cr2032) ekhon eita laganor por ki cmos jumper o reset korte hobe? Jumper ta 1-2 kora ase, oita k ki 2-3 kore abar 1-2 kore dite hobe? Battery ta ami ekhon o lagai nai.
    see your motherboard's manual
    apne ki sure onno component gula sob thik ase?
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    CMOS battery kiccukhon khule rakhley Bios reset hoye jay.....apni just, ager battery khule nutun ta lagan,arpor dakhen ki hoy.....asha kori atey kaj hobe.......
    Pura sob kisu khule felan then again lagan and akta new psu dia test koren may be start hobe
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Psu koi pabo? Tmn kew nai jar kas theke psu ana jabe. Eid porjonto wait kore ডাক্¤তার খানায় nia jaite hobe. So sad.
    Pc er ki je holo kisu bujtesi na. Ektu age abar start marlam. On holo but black screen. Case fan,cpu fan, dvd rom, sob choltese, mobo e green light ase. Kintu hdd ta ektu kach kach ar psu ta presser cooker er moto sound kortese. Jeta age silo na. Taile kar pet kharap hoilo?
    Try resetting everything. I m saying again check your RAM. Pull out each n every plug and re-insert.
  1. GS2 not starting
    By CvP in forum Technical Support
    Last Post: August 14th, 2013, 12:29
  2. PC isn't starting
    By anik_lc in forum Technical Support
    Last Post: November 8th, 2012, 01:37
  3. pc isn't starting
    By wasi006 in forum CPU
    Last Post: July 5th, 2011, 19:53
  4. pc not starting
    By LIV Gaming in forum Technical Support
    Last Post: June 12th, 2011, 14:01
  5. Closed HDD starting from 120 GB
    By AmareX in forum Shop - Gadgets
    Last Post: October 20th, 2009, 03:20
Page generated in 0.19689 seconds with 14 queries.
