Results 1 to 10 of 10
Thread: AMD Radeon R9 290X and Radeon R9 290 Specifications Confirmed – Full Hawaii Chip Features 2816 Stream Processors
    • Badhon's Gadgets
      • GIGABYTE GA-G31M-ES2C (Rev. 1.x) (Intel G31 Chipset)
      • Intel Pentium Dual-Core E5200 (2.5 GHz, 800 FSB, 2 MB L2 Cache, 45nm) (Default Clock)
      • 1x Patriot 2GB DDR2 800 Bus (Single Channel) (Crappy Brand)
      • SAMSUNG F1 320GB SATA 7200RPM
      • SAMSUNG SyncMaster 550s 15" (Max. Resolution 1024x768) (White)
      • Onboard (Realtek 8-Channel HD)
      • Microlab M-119 2:1 Amplified Subwoofer System (Black)
      • Perfect
      • Leno Optical
      • USB Network Joystic
      • Value-Top 400w
      • LiteON 16x DVD-ROM
      • Windows 7 Ultimate x86 Genuine
      • My Girlfriend
      • Avg. 30-40 KBps.
      • Slower Than A Turtles
    Badhon's Avatar
    Petaling Jaya
    Lightbulb AMD Radeon R9 290X and Radeon R9 290 Specifications Confirmed – Full Hawaii Chip Features 2816 Stream Processors
    The final specifications for the AMD’s next generation flagship Radeon R9 290X and Radeon R9 290 Hawaii GPU have been confirmed by GDM.or.jp. The specifications which we have been reporting since a while are legit and the Hawaii XT core indeed features 2816 Stream processors.
    There are two cards based on the Hawaii GPU architecture, the AMD Radeon R9 290X which features the Hawaii XT core and the AMD Radeon R9 290 which would launch later featuring the Hawaii Pro core.
    The Radeon R9 290X makes use of the brand new Hawaii GPU architecture which is aimed directly against the top dog from NVIDIA aka the GK110 GPU. The Radeon R9 290X features a full blow Hawaii chip with 2816 Shaders (SPs), 44 ROPs (Raster Operators) and 176 TMUs (Texture mapping units). The Radeon R9 290X GPU is clocked at base clock of 800 MHz and supports GPU boost frequency upto 1000 MHz. The memory is clocked at an effective clock speed of 5 GHz. the GPU has a compute performance of 5.6 TFlops.
    One of the biggest changes made by AMD in their Radeon R9 290X graphics card is the addition of 512-bit bus interface compared to the 384-bit bus on their last generation Radeon HD 7970. The Hawaii GPU comes with a total of 4 GB GDDR5 memory which is lower than the GK110 based Titan but higher than the 3 GB GeForce GTX 780 which falls just around the same price point. The higher 512-bit bus allows for ridiculously higher bandwidth over 300 GB/s which is sufficient enough for the Hawaii GPU. The card uses the latest AMD CrossFireX technology allowing for upto Quad-Way GPU functionality without the need to equip a CrossFire cable since the signals are being sent via the PCIe bus interface.
    The Radeon R9 290 on the other hand features the Hawaii Pro chip with 2560 Stream processors and 40 ROPS. the card has a max clock speed of 947 MHz and has a compute performance of 4.9 TFlops. Power to the card is provided through a 6+8 Pin configuration.
    AMD Radeon R9 290X AMD Radeon R9 290 GeForce GTX 780 GeForce GTX Titan
    GPU Codename Hawaii Hawaii GK110 GK110
    GPU Process 28nm 28nm 28nm 28nm
    Stream Processors 2816 2560 2304/192/48 2668/224/48
    Base Clock 800 MHz 900 MHz 863 MHz 837 MHz
    Turbo Clock 1000 MHz + 947 MHz 902 MHz 876 MHz
    VRAM 4 GB 4 GB 3 GB 6 GB
    Memory Bus 512-Bit 512-Bit 384-Bit 384 Bit
    Memory Clock 5 GHz (effective) 5 GHz
    (effective)
    6 GHz (effective) 6 GHz (effective)
    Power Configuration 8+6 Pin 6+8 Pin 8+6 Pin 8+6 Pin
    PCB VRM 5+1+1 5+1+1 6+2 6+2
    Die Size ~424mm2 ~424mm2 551mm2 551mm2
    Launch Date October 2013 Q4 2013 23rd June May 2013 21st February 2013
    Launch Price $649-599 $499-449 $649 $999
    Both GPUs would feature support for DirectX 11.2, OpenGL 4.3 and the latest Mantle API that would debut in Battlefield 4 in December 2013 and later get featured in more games. Expect retail availability of the Radeon R9 290X and Radeon R9 290 on 15th October 2013. The Radeon R9 290X Battlefiield 4 bundle is currently available through several retailers including Newegg and has been listed for a price of $729.99 US.
    AMD Radeon R9 290X:
    AMD Radeon R9 290:
    WCCF Tech
    A strong man doesn't need to read the future, he makes his own
    • Summitundead's Gadgets
      • GIGABYTE 970-AD3
      • FX 8120 (mild OC'ed to 3.36ghz)
      • 8GB 2x4 GB
      • HITACHI 1TB + TOSHIBA 2 TB
      • 1GB GDDR5 6670
      • SMART POWER 650W
      • AMD IS SMARTER CHOISE AND AWESOME .... I LOVE MY RIG ......... :D
    Aug 2013
    dhaka zigatola
    Talking
    awesomeeeeeeeeeeeeee ..............
    BD te aibo kobe O_o
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    Hawaii HIS Radeon R9 290X reveal
    A Chinese site, by the name Expreview has graciously endowed us some racy(!) pictures of AMD's upcoming power-house, the AMD R9 290X, who is believed to star the upcoming Destroy of The Titan
    The images show the prominent fully fledged 7.08 billion-transistor "Hawaii" chip from AMD, 16 GDDR5 memory chips and a 5+1+1 phase VRM which packs CPL-made chokes, IR-made DirectFETs and a new IR-made VRM controller.
    I like naked first. So,
    Click the link to see the album containing the 14 scandid pics of ecstacy Don't try to read though. *frown* You'll just hurt your eyes
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    That is one beautiful looking card right there ^^
      • Logitech G402
    Nowy Warsaw
    Radeon R9 290X pitted Against GeForce GTX TITAN in Early Review
    Here are results from the first formal review of the Radeon R9 290X, AMD's next-generation single-GPU flagship graphics card. Posted by Chinese publication PCOnline.com.cn, it sees the R9 290X pitted against the GTX TITAN, and the GTX 780. An out of place fourth member in the comparison is the $299 Radeon R9 280X. The tests present some extremely interesting results. Overall, the Radeon R9 290X is faster than the GTX 780, and trades blows, or in some cases, surpasses the GTX TITAN. It fares excellent in 3DMark: Firestrike and beats both NVIDIAs in Metro: Last Light. In others, it's inbetween the NVIDIAs, sandwitched but leaning quite towards GTX TITAN. But the power consumption might sour the pussy.
    Synthetic Benchmark:
    Game Results:
    Power Consumption:
    Original Source
    If those are actual results then the card is going to be disappointing. This late into the generation but higher power requirements for highly similar performance.
      • Logitech G402
    Nowy Warsaw
    Yeah! GCN was disappointing in terms of its power to performance ratio. Looks like it's(GCN 2.0) no better.
    • Ghost Riley's Gadgets
      • ASRock Z370 Extreme 4 [Case: Thermaltake Commander GS-II black]
      • Intel core i5 8400 @ 3.9Ghz
      • Corsair Vengeance LPX 16GB @3600Mhz (Dual Channel)
      • Toshiba 2TB
      • Sapphire RX480 Nitro+ 4GB
      • Dell S2216H IPS panel (1920X1080)
      • Creative X Fi Titanium
      • Edifier R2000DB
      • A4 TECH KR-85
      • Havit-MS736
      • Antec Neo ECO 650M [80 PLUS BRONZE Certified]
      • Samsung SH-S223
      • Transcend 32GB USB 3, Adata C906 32GB USB 3, Adata UV120 32GB USB 3
      • https://valid.x86.fr/bench/5bqlvf/1
      • ochcham
      • Alpha Broadway
      • 130-150 KBps
      • 100-150 KBps
    Ghost Riley's Avatar
    Narayangonj
    ৪০০ ওয়াট পাওয়ার আর ৯৪ ডিগ্রি সেলসিয়াস!!! শীতকালে রুম হিটারের কাম দিবো।
      • Logitech G402
    Nowy Warsaw
    More leaks emerge as we speak.
    Aggregated unofficial pre-benchmark results(or benchmark pre-results ):
    More AMD Radeon R9 290X performance charts emerge | VideoCardz.com
  1. Replies: 0
    Last Post: September 19th, 2013, 17:58
  2. Replies: 12
    Last Post: May 10th, 2013, 17:09
  3. Radeon HD 7850 and HD 7870 Leaked specifications
    By SheikhItBaby in forum Tech News
    Last Post: October 28th, 2012, 00:40
  4. Replies: 11
    Last Post: June 18th, 2009, 04:35
  5. Replies: 10
    Last Post: September 15th, 2008, 13:27
Page generated in 0.24458 seconds with 15 queries.
