Thread: Permanent Diskpart settings help
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Default Permanent Diskpart settings help
    Guys i really need help, cause this partition order i keep getting from after booting in Win XP CD is annoying. I tried to find ways even in diskpart from Win 7 System Recovery to sort it out. It doesn't change somehow, the partition letters and sequence. I really need a quick solution, if there is a good Partition softwares that fixes this forever then am all hears.
    You can try, MiniTool partition wizard home edition, it is a very good partition softwere, also check - Parttion Guru HD free
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    I need to be sure they fully change settings of the volumes.
  1. Replies: 30
    Last Post: October 22nd, 2011, 10:44
  2. FIFA 08 which control settings do u use?????
    By tanim in forum Older FIFA Games
    Last Post: October 1st, 2008, 11:00
Page generated in 0.15070 seconds with 14 queries.
