Results 1 to 20 of 23
Thread: Need Help
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Default Need Help
    Today I bought a Bravia W670A . Now I want to Connect My Pc With Tv Via HDMI to HDMI cable . Right Now I dont have any GPU installed In my Setup and My Motherboard dont have any DVI port . Only Hdmi and VGA . And TV has only HDMI output . Now When I connect Tv and Pc Via HDMI cable nothing Showed up (Onboard Display driver installed) . Then I Uninstalled The Onboard VGA driver and Display Showed Up . I can also Max out the resolution upto 1080p. So now Here I want to Know this thing :
    Is there Any settings in my PC I need to Change after Installing the Display driver ? or Any settings I need to change in my TV ?
    Any Sound settings I need to Change ?
    BTW here is the Pic of TV :
ID:	31089Click image for larger version.
    বাট রিমেমবার, জলিল নেভার ডাই, আর মরলেও ডাই এনাদার ডে।
    Congs! (Y)
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Congs! (Y)
    Congrats diya ki korbo . PC er sathe proper way te setup korbo kivabe oitai help koren :/ .
    Quote Originally Posted by Dustfinger View Post
    ur gadget says u have a 660Ti
    and btw u can disconnect any other connected monitor.
    or connect one monitor then forcefully search for other connected device. ( as far as i remember there was an option like this in intel HD graphics driver)
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    I sold it 1months ago . Updated The Gadget List . I changed/sold Some of my components In last few months .
    BTW right now There is Now Other Monitor Connected in PC , Only just The TV . I Connected Only one device at a time (I still HAve The Ml239H for backup reason , But I disconnected it ).
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    @Dustfinger : koto porse ?
    As for your problem, install your onboard drivers and see what happens. As far as I know TV should have any settings that you need to change its just plug and play. I have already connected my PC to 2 different Bravias with HDMI cable (the one that you sold), and I didn't face such problem. If possible try to get a HDMI supported monitor, hook it up with onboard connector and see if problem persists. If yes then sth wrong with your drivers, if no well its better if we could see the options that your driver gives, not very familiar with intel drivers.
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    @Rawkill 65K porse . Sony Showroom theke kina .
    Ami Onboard Display driver Install koreo try korsi , TV te kisui show kore na . But ami HDMI supported Monitor (Ml239h) e use korsi . Sob kisui Thik ase . Display Driver Install kore TV te connect korle dakhai je HDMI device connected , But Settings er kono problem er karone maybe display ashtese na .
    Display driver's Options :
ID:	31093Click image for larger version.
ID:	31094Click image for larger version.
ID:	31095Click image for larger version.
ID:	31096Click image for larger version.
ID:	31097Click image for larger version.
ID:	31098Click image for larger version.
ID:	31099Click image for larger version.
ID:	31100Click image for larger version.
ID:	31101Click image for larger version.
ID:	31102Click image for larger version.
ID:	31103Click image for larger version.
ID:	31104Click image for larger version.
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    @Dustfinger : Connect your TV with a VGA cable and see if it works and have a look at this:
    http://www.tomshardware.com/forum/36...ng-bravia-hdmi
    The guy has a similar problem as yours but he is using a GPU.
    Bravias should have more than one HDMI port. Did you select the correct port using the remote ? There should options like HDMI 1, HDMI 2, PC, Analogue, etc.
    monitor and tv settings e display ektai dekhay?
    cable length koto?
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    TV te kono VGA port nai .. Only HDMI .. and Correctly Select kora hoyeche .. Graphics driver uninstall korar por TV thik e use kora jaitese .
    BTW Ami devices Check korar por aita pailam :
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Frankly speaking now I don't have any idea about how to help you with this. I connected my Bravia to my PC before and never had any problems. Try your best and google it, and either get yourself a GPU or trade your TV with my monitor if the problem persists.
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    @Rawkill .. problem fixed ... Thanks For ur help(jodio konotai kaje lage nai ) .
    the w67 has wifi built-in. Now is it possible to stream movie/song to the TV from a laptop over wifi?
    What If I connect it with a cross-over cable? any help on this?
    Sure, assuming your laptop is powerful enough to run a DLNA server, and convert on the go.
    Tried xbmc and Homestream. Couldn't get it to work over wifi. couldn't figure how to configure. The TV won't detect any DLNA server no matter what I do. Converting part should come later.
    will try over cross-over cable tomorrow.
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Kemne thik hoilo ? Solution ta dia rakhen.
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Direct 1080p diye try korle TV detect kore na .1st e onno arekta monitor diye resolution 720p set korte hoise Then TV te connect korar por auto resolution 1080p te change hoye gase . Horizontal Frequency Related Issue chilo . jaitar concept akhono amar clear hoi nai .
    hmm .. Laptop diye wifi use kore TV te Video stream akhono try kore dakhi nai . BUT TV manual e process ta describe kora ase . Ami mirror Screering use kore Mobile(xperia V) diye TV use korsi (Mobile er Exact display tai TV te show korbe) .
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    IPS er sathe TV(67W) connect korbo just 1-2 minutes er backup er jonno .. chinta kortesi Belkin er surge protector / multiplug use korbo better protection er jonno . aita ki thik hobe ?? any suggestion ? @Rawkill @dipanzan
Page generated in 0.31161 seconds with 14 queries.
