Thread: Need help with my mobo's Lan Port..!!
    • Forhad666's Gadgets
      • Gigabyte GA-B75M-D3H
      • Intel Core i5-3470 3.20GHz
      • G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600
      • Hitachi 1TB SATA 7200 RPM
      • Sony Bravia R352B 40 inch (1920x1080), LG W2053TQ (1360x768)
      • On-board audio
      • 12 Years Old 2x1 Creative :p
      • A4Tech V3 Bloody Multi-Core Gun3
      • Logitech - Gamepad F310
      • Thermaltake SMART 430W
      • Asus 24xDVD-RW
      • Apollo 800VS
      • Windows 7 64 Bit
      • 100 kbps
      • 100 kbps
    Forhad666's Avatar
    Mar 2013
    Post Need help with my mobo's Lan Port..!!
    Recently my ISP gave me a lot of problems with their severs maintenance and etc...n when they claimed that they fixed d net, maybe my Lan port of my mobo stopped working...bcoz d Internet was ok when I they connected my Brother's laptop..they advised me to get a ext Lan Card and check it.....(btw I rebooted my PC and did everything i was suppose to do and also checked BIOS)
    What should I do?? if my Mobo's lan port is really gone, will i get a RMA??
    If not can anyone suggest me a good lan card??
    Need Help badly
    Being without internet is like having no connection to the outer world
    “I believe… whatever doesn’t kill you simply makes you…stranger.”
    Quote Originally Posted by Forhad666 View Post
    Need Help badly
    try to connect your system with your brother's laptop. if it connects then your lan port is ok.
    if not.
    make sure to install proper driver for lan card.
    then test again.
    still nothing?
    if you have warranty claim it.
    and you can buy any 10/100Mbps lan card for 250 taka. if you plan on using internet only this card will be enough.
      • On-board audio
      • Asus 24xDVD-RW
      • Apollo 800VS
      • Windows 7 64 Bit
      • 100 kbps
      • 100 kbps
    Forhad666's Avatar
    Mar 2013
    if not.
    then test again.
    still nothing?
    I installed d driver for my lan card....checked my IP many times :/ still nothing..
    but I don't know which cable to use to connect my pc with d laptop through Lan port..
    n yes, I've more then 2.5 years warranty left..
    you can see the name of your adapter in network connections right?
    and its enabled?
    you can use any cable you want.
    CAT5
    CAT5E
    CAT6
    you will need RJ 45 male port connected on the both ends.
    if lan card is down
    claim warranty.
    onboard lan is very handy. dont loose it.
      • On-board audio
      • Asus 24xDVD-RW
      • Apollo 800VS
      • Windows 7 64 Bit
      • 100 kbps
      • 100 kbps
    Forhad666's Avatar
    Mar 2013
    and its enabled?
    CAT5
    CAT5E
    CAT6
    you will need RJ 45 male port connected on the both end.
    if lan card is down
    claim warranty.
    yes...local area connection is enabled....but showing a red X...saying no internet but both lights r on..
    Thanx a lot...hopefully will try to claim RMA for my mobo tomorrow...
    btw my ISP"s tech guys spent lot of times trying to figure out d problem...but no luck..
    Do you have ubuntu?
    you can just boot ubuntu straight from pendrive and see if the network is working there. if yes u might have a windows issue.
    but well you have warranty. so claim it. see what happens.
    Your onboard lan is gone, if windows had any problem then it would show you the yellow exclamatory mark, as it comes with red cross-mark the answer is simple
  1. PC Port Of The Year
    By anik_lc in forum Gaming Topics
    Last Post: December 25th, 2012, 04:55
  2. Replies: 19
    Last Post: November 4th, 2012, 21:51
  3. Want to Buy Monitor with dvi port
    By Mohiuddin in forum Shop - Gadgets
    Last Post: September 19th, 2012, 12:49
  4. How to open a port?
    By thanda_batash in forum Internet
    Last Post: November 23rd, 2010, 17:57
  5. Port Scanner
    By Saibal in forum Programming
    Last Post: April 25th, 2008, 09:13
Page generated in 0.19961 seconds with 14 queries.
