Results 1 to 11 of 11
Thread: what is standard cpu fan speed?
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    Default what is standard cpu fan speed?
    may be a bit weird question, buts ur cpu fan speed?
    need to know.
    mine shows only 1400-1500rpm
    I bleed red, Man Utd 4ever..
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • 3TB Samsung (3 HDDs)
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • Generic Headset | Microlab FC550
      • A4Tech Generic
      • Logitech MX 518
      • Genius Speed Wheel 3 Vibration & MaxFighter F-23U
      • Thermaltake Toughpower 650W
      • Samsung
      • Transcend 16GiB USB3
      • None atm
      • Windows 7 | Arch Linux
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    Default Re: what is standard cpu fan speed?
    that's normal for a cpu at idle.....mine's around the same RPM
    edit: i guess i mixed up with my old p4, on my i7 the RPM stays around 900ish @ idle...that's with a stock cooler fyi
    ur cpu fan rpm is totally normal tho
    unless they introduce PoP/Mirror Edge styles with lara croft in bikini (gfx on par or better than AniMatrix), this game is hopeless =,='
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    Quote Originally Posted by abir View Post
    need to know.
    CPU fan rpm can be variable depending on the cpu fan size & model.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    for intel own HS it is 2900-3300RPM.
    and for aftermarket cooler it is 600-1800RPM.
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    How can I see cpu's fan speed?
    Quote Originally Posted by ►Sy3D|^|SuNnY• View Post
    Use Speed Fan
    http://www.almico.com/sfdownload.php
    u can use it to check RPMs of the fans if it is connected to the motherboard headers(4pin) which reports the via the mobo itself...afaik it can report the CPU temps...HDD temps(if it is a SMART enabled one) & also mobo(system) temps
    it can also report voltages across the mobo(but somewhat incorrect at times)
    u can also use it to control RPMs of FANs using the software but it is not recommended
    My DuoOrb runs at full blast at 2300 rpm after i disabled my cpu fan speed controlling
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    My problem is the cpu fan doesnt start at the first time, it starts and stops for 3 times then finally starts and pc boots on.
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    hmm.amar pc tey first e ups charley on hoy.then off.then power button press korley choltey thakey.keu er reason/solution janley diyen.
    on topic:mine stays1176~1196 @ idle
    abir bhaiya...I think that problem is associated with the PSU rather than the CPU Fan...but I can be wrong
    first I u'd suggest u to boot the PC with the 4770 using the built-in gfx...if the FAN doesnt act up...then I think it is the PSU
    btw how many HDs & ODDs are u running & did u recently installed any new ones
    & as for the RPM it is fine...the mobo has a built-in algorith set for the CPU's RPM control...if the temps increases when under load...the RPM rises & when the CPU cools down at idle...the RPM decreases to become more silent
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Quote Originally Posted by ЯV●Speed View Post
    Its quite normal. Nothing to be worried.
    Depending on the motherboards Fan control system, normally it doesn't spin up the fan until the external CPU temp sensor detects a certain level of heat energy that needs dissipating.
  1. Sale (New) XFX 8800 GS Standard
    By Cyber_Shot in forum Shop - Gadgets
    Last Post: May 30th, 2009, 23:11
  2. Replies: 0
    Last Post: May 13th, 2009, 19:03
  3. Closed Thermaltake Toughpower Standard 600W PSU
    By Hexagon in forum Shop - Gadgets
    Last Post: March 15th, 2009, 12:39
  4. Replies: 6
    Last Post: February 20th, 2009, 11:12
  5. GeForce® 6200 256MB DDR2 Standard (PV-T44A-WAN7) for sale
    By plasma_brain in forum Shop - Gadgets
    Last Post: September 24th, 2008, 01:01
Page generated in 0.23429 seconds with 14 queries.
