Results 1 to 20 of 25
Thread: NFS: SHIFT -- Settings Guide
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    Default NFS: SHIFT -- Settings Guide
    "SHIFT has introduced one of Need for Speed's more complex controller options. This is intended to provide more configurability to the simulation players, deepening the level of control they have with the game's controller & wheel intelligence.
    A quick definition is provided below to help determine what's good to touch or best-left unaltered. Don't forget to use the DEFAULTS option if settings get tweaked too far.
    Steering Deadzone - The smaller the value the smaller the deadzone. For steering wheels it is recommended to have this value at 0%. | NOTE: These next few deadzone settings for a gamepad are best-left unaltered.
    Accelerator Deadzone - The basic description for all the deadzones are the same. For the initial range of motion no input is reported, and then starts when the end of he deadzone has been reached. On top of these additionl recommendations can be added.
    Brake Deadzone - As above - For the initial range of motion no input is reported, and then starts when the end of he deadzone has been reached. On top of these additionl recommendations can be added.
    Steering Sensitivity - This setting adjusts how sensitive the steering across the input span. With 50% sensitivity it is equally as sensitive at the beginning of the range as at the end of the range. This can make the steering feel twitchy on a game pad, thus it is recommended to have a lower sensitivy setting which makes the steering a bit less sensitive for small inputs. For a steering wheel it is recommended to have this setting at 50%.
    Acceleration Sensitivity - Same as above, a value lower than 50% means the input is less sensitive in the beginning of the input span.
    Braking Sensitivity - As defined above. If the default setting is not responsive enough (may well become car & performance specific), it's recommended to make slight adjustments & test.
    Speed Steering Sensitivity - This setting reduces the sensitivity of steering at speed. A high value applies maximum effect to make the car stable to drive down straights with a gamepad. Lowering the value will make the car feel sensitive and twitchy at higher speeds. For a multiturn steering wheel it is recommended to set this value to 0%, for other wheels a value around 50% is recommended.
    Inverse Shifting - Reverses the default controller shift buttons.
    Camera Y Axis - Inverts the R-stick camera movement in game.
    Wheel Lock - This determines how much of the available turn to turn lock to use for the steering wheel. On consoles this is set in degrees measured from lock to lock. On PC it is set as a percentage of the steerings wheels available lock. This can be fine tuned to suit the players preference, with less lock giving more sensitive steering, with too much lock the car will feel unresponsive.
    FF Strength - Determines the strength of the force feedback effects, 0 means effects are muted, 10 gives the strongest effects.
    • ЯV●@spret's Gadgets
      • Asus 970 pro
      • AMD FX-6100 @ 3.5ghz
      • Kingstone Hyper-X 1600mhz 8GB DDR3
      • Samsung Spinpoint 1TB 7200rpm
      • XFX HD 6870 @ 910mhz
      • Viewsonic 17'' LCD @ 1440x900
      • Creative Tactic 3d Alpha USB sound card
      • Thermaltake TT Shock
      • A4 Tech Normal
      • A4 Tech 2x Office
      • Xbox 360 controller
      • Gigabyte Superb 720W
      • WD Ext. 2TB 7200 rpm HDD
      • RahimAfrooz 100VA Premium
      • Windows 7 home premium 64 bit
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    Default Re: NFS: SHIFT -- Settings Guide
    KB r settings keu dao
    Speed is like ADDICTION.....
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Quote Originally Posted by ЯV●@spret View Post
    KB er kono setting nai
      • Asus 970 pro
      • A4 Tech Normal
      • A4 Tech 2x Office
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    ken nai tomare ai jonno pitamu...........disum disum
    • mr_08's Gadgets
      • Asus B75M+ || Gigabyte G41m combo
      • Intel core i5 2500k @3.3ghz cooled by the CM V6GT || Intel dual core e5500 @4ghz with TT V1AX cooler
      • Gskill RIPJAWS X SERIES 4gbx2 @ 1600mhz || adata xpg 2x2gb @1333mhz 7-7-7-20
      • samsung f3 500gb || wd 1tb , samsung 250gb
      • Sapphire 7970 OC 3GB w/ BOOST || Gigabyte 8800gts 512mb
      • Sony Bravia KDL42W700B || Samsung P2350, Samsung T190
      • integrated
      • Genius G500v || cosonic headphone
      • cm devastator mb24 , a4tech x7 g800 , logitech k260|| a4tech x7 g500,a4tech KB 28g
      • cm devastator ms2k , a4tech x7 X710 || a4tech office mouse, logitech m210
      • logitech g13,logitech rp2,xbox 360 wireless controller,generic usb x 3
      • xfx pro series 650w || delux 450w
      • liteon 24x w/ LT || asus dvd rw
      • Transcend 16gb USB 3.0 || Transcend 16gb usb 2.0
      • Apollo 1200va || Powerguard 650va
      • win7 ultimate sp1 || xp sp3
      • alhamdulillah!duitai chole,kharap na :D
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    haha,are kb er setting post korbo age shift khele nei,ami ekhono tier 1 ei...keno jani ekhon ar kono game par korte moja lagena ager moto,ami goto 2 yrs e naholeo 30 ta dvd kinsi but ekta game o game over korinai,eita start hoise mone hoi baal marka pro street khelar por theke!!!!!the only game i have played properly is fifa 08 and fifa 09...
    ami chhoto amake marbenna.-_- shob _ buira_gamer_
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Quote Originally Posted by mr_08 View Post
    lol.ei jey choley ehsechen KB bosssssss.vai amadero kintu KB er baap asey.oi shala kemney jey chalaitesey allah e janey.chino tou money hoy mr.08 orey tai na???
    • TAHMID's Gadgets
      • Gigabyte 946
      • Intel Pentium D @ 3.2 GHz
      • 4 GB [2GB+2GB] 800MHz
      • 240 GB [80 GB+140 GB]
      • *busted
      • 40" SAMSUNG LED
      • 5.1 surround sound
      • Chicony
      • MSD cosy multimedia mouse
      • XBOX 360 CNTRLR \m/
      • Thermaltake TR2-500W
      • Asus Quietrack 22x
      • SanDisk CRUZER micro 4GB
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • X360+ 40" LED, wh8 more do u need ?
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    Ami tier-3 te.Kin2 tier-3 te 1st er event gula[time ase J gulay]Ki shob corner master korte hoy naki ??ami to kissu bujhtesi na..shudu race korei jacchi...
    • mr_08's Gadgets
      • integrated
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    ya know him,ore baba pro street e or laptime dekhe amar lojja lagtasilo!!!or bg nick ki ekhon??
    ---------- Post added at 18:13 ---------- Previous post was at 18:08 ----------
    dekhi ajkal ura dhura khelum shift,but fifa 10 ana hoise ajke ,but fifa 10 bhalo lagenai so abar nfs khelbo ,ar dekhi chame dia ekta momo anabo bhabtesi...tomader shathe khelte hobe na online!!!!4.5k jodi hoi momo i surely can buy one now...
    ---------- Post added at 18:14 ---------- Previous post was at 18:13 ----------
    oi tousif amare yahoo te ad koro,my mail id is [email protected],dekhi ajke rate khelbone tomar shathe but tumi tier 1 stock car dia chalaiba!!!!
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    ha ha ha.lol.lmao.ami yahoo tey boshi na.add me in msn.post er right e msn er icon e id dewa asey.yahoo thekei add mairen.problem hobey na.ar ooor id holo ЯV●FireBaLL.tobey oo forum e khub kom ashey.& tier 1 er stock car.impossible.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя's Avatar
    Apr 2009
    +23 45' 10.07", +90 23' 5.39"
    what'd be a good setting for drifting?
    i can't make a good one
      • Asus 970 pro
      • A4 Tech Normal
      • A4 Tech 2x Office
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    bujsi ai game r dhora jabe na....aj theke khelai stop....gear na kena porjonto khele lav nai....time loss r matha nosto
    • pollob.codename13's Gadgets
      • Gigabyte G31
      • Intel Pentium Duel Core E5200 2.5GHz
      • 1+1 GB DDR2 667 MHz
      • Hitachi 500GB
      • Sapphire ATI Radeon HD 4770 GDDR5 512 MB
      • Samsung SyncMaster B2030
      • Realtek built-in
      • csm
      • A4 Tech
      • Toshiba
      • Sonic Dual Shock
      • Normal
      • I always feel my pc
    pollob.codename13's Avatar
    Sep 2008
    Lalbag
    oh man .. impossible .. kb te ar beshi dur jaite partesina .. tier 3 te atke gesi .. drifting is just simply impossible
    kb setting nia googling korsilam .. ea forum-eo eita nia alochona hoitese .. customer asking for patch for kb issue
    http://forum.ea.com/eaforum/posts/list/304296.page
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя's Avatar
    Apr 2009
    'kb' mane ki?
      • 16GB DDR3 1600hz
      • Roccat Arvo
      • 500GB
      • Windows 7/ Linux
      • Smile, BD.COM
      • 75KBPS(Variable)
    Hamilton's Avatar
    Quote Originally Posted by йЦммєя View Post
    'kb' mane ki?
    keyboard
      • Asus 970 pro
      • A4 Tech Normal
      • A4 Tech 2x Office
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    ami tao 1ta setting iktu age korlam....hmmmm not bad at all.....age gari rastay thakte chaito na...r akon gari kothin corner sara rastar baire jay na.......
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Steering is way to tricky -_-"
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    U have wheel u have solution.
    U have KB u have demolition.:S
    • warriorfist's Gadgets
      • Intel DG35EC
      • Intel Core 2 Duo E7300 2.66 GHZ
      • 8 GB DDR2(Twin MOS DDR2+A data)*2
      • 560 GB SATA (320+160 GB+80 GB)
      • Sapphire HD 6770 1 GB
      • LG Flatron E700SH
      • Microlab FC661
      • Windows 7 Professional X64
      • 15-19.5 Kbps
      • 10-12 kbps
    warriorfist's Avatar
    Sep 2009
    Gulshan,Dhaka
    bapre shift a keyboard re ki banaise!first e experienced nia khelte jaya por por 6th ar 7th hoisi! tar por normal a medium AI diaw 2 race laglo 1st hoite........a dekhi NINTENDO hard banaise! at least for keyboard anyways
    Pro te 6th howar jonno koto bar khela lagbe Allah e jaane,,,,,,,,:mellow:
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя's Avatar
    Apr 2009
    bhai setting ta aktu bolen
    amar controller
    drift akta fota korte parina
    • ЯV●shafiee007's Gadgets
      • eVGA X58 SLI Micro
      • Intel Core i7 920 Nehalem 2.66GHz L3 8MB cache Quad Core
      • 3x2GB Corsair XMS3 DDR3-1600 Tripple channel (8-8-8-24)
      • 1.5TB WD Caviar Black + 250GB Samsung HDD
      • Sapphire ATI 5870 1GB GDDR5 256-bit PCI-e
      • ASUS 21.5" VH222H HDMI
      • Steelseries Siberia with 7.1 USB sound card, Altec Lansing 2.1
      • Steelseries MERC Stealth
      • Razer - DeathAdder
      • Logitech G25 Racing Wheel, Xbox360 controller, Genius Maxfire G-12U, Creative Cobra 2, XFX Xgear
      • Corsair TX750
      • Lite-on SATA DVD writer
      • iNeat 1200VA
      • Windows 7 64-bit
      • It's great... but my consoles are much better !
      • 170KBps
      • 100KBps
      • 18
    ЯV●shafiee007's Avatar
    Pit Stop
    Keyboard houk.... Gamepad houk... aar Wheel-e houk.... DRIFT mode in NFS SHIFT SUXXXXXXXXXXXXXXXX....
    Red ViperZ---ЯV●shafiee007
  1. Replies: 6
    Last Post: June 20th, 2009, 14:38
  2. Replies: 5
    Last Post: April 28th, 2009, 19:47
  3. FIFA 08 which control settings do u use?????
    By tanim in forum Older FIFA Games
    Last Post: October 1st, 2008, 11:00
  4. Mouse and Settings
    By Z in forum CS: Source
    Last Post: May 19th, 2008, 03:16
Page generated in 0.31832 seconds with 14 queries.
