Results 1 to 2 of 2
Thread: System Properties Problem
    • saadbillah's Gadgets
      • Intel D945GCNL | Intel GL40
      • Core 2 Duo E6300 1.86 GHz | Pentium Dual Core T4200 2.0 GHz
      • 2 GB | 2 GB
      • 120 GB | 320 GB
      • ASUS EN8600GT 512MB Silent Edition | Intel GMA4500
      • F&D F3000U 5:1
      • Generic Crap
      • Windows XP | Windows 7
      • 64
      • 18
    saadbillah's Avatar
    Default System Properties Problem
    amar laptop er processor dual core 2.0 GHz....
    BIOS eo 2.0 Ghz e dekhae, but system properties r CPU-Z diye check korle 1.20 GHz dekhae...
    er karon ki?? Click image for larger version.
ID:	1624Click image for larger version.
    Vous n'avez pas vraiment connaître quelqu'un qu'en le combattant.
    Default Re: System Properties Problem
    INTEL SPEEDSTEP...a power saving feature used by Intel CPUs to clock down their speeds to reduce power consumption when it is sitting idle
    launch up an heavy app...like a game/anti irus & u should see CPU-Z reporting 2.00GHz(default) when running those apps...the cpu u'd jump up to full speed & then again clock down when it will be idle
    there is nothing to worry about...it is a good approach since u r using a laptop...the speedstep also reduces heat emission since the CPU is now using less power compared to what it u'd have been using under full speed
  1. Which Operating System Are You Using??
    By Deep -xCross- in forum Software
    Last Post: December 23rd, 2009, 17:14
  2. 32 bit and 64 bit oprtating system
    By MuntZ in forum CPU
    Last Post: December 18th, 2009, 09:43
  3. Security Tab in File Properties???
    By ScS :: XTR in forum Technical Support
    Last Post: April 10th, 2009, 17:45
  4. Trade REF system
    By TAW_LegendaryHero in forum Feedback
    Last Post: June 4th, 2008, 13:50
  5. Chatting system
    By ЯV●@spret in forum Feedback
    Last Post: May 30th, 2008, 12:53
Page generated in 0.15890 seconds with 15 queries.
