Thread: Help!!how to make a wifi conn.with laptop and phone for file sharing
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default Help!!how to make a wifi conn.with laptop and phone for file sharing
    i've tried wifi file explorer/transfer app to do this.but it only helps me to explore and uploading data to my phone.it converts the phone into a server
    i want to explore the laptop and dling+uloding files from the phone.which means i convert the phone into a server.
    i read in some forum that es file manager can do the job.but how to configure the pc to do that????pls,help
    Connectify pro has something like that, not sure though
    • conFuSeD's Gadgets
      • Asus H61M-A
      • Core i5 3470
      • 8GB
      • Toshiba 2TB
      • Sapphire r9 270
      • AOC F22
      • Creative Sound Blaster 2
      • Steelseries Siberia v1
      • A4tech
      • Steelseries Rival 100/Steelseries Kinzu v2
      • TT LitePower 600W
      • Win 8.1 64bit
      • 500
      • 500
    yes u should use ES File Explorer.
    Access SD card from PC: Turn on ES..go to tools and then remote manager..an IP will be given to you..use this ip in your Windows(My computer) location bar..you can access your files then
    Access PC from ES File Explorer: You need to create a homegroup in Windows. Go to LAN tab in ES and tap on Scan. It will find your pc..
    I prefer x-plore as file manager. Connect your phone to your pc/laptop. Then in x-plore go to lan>add new>scan
    it should find your pc. Enter your windows username/password.
    To share a folder/drive, in your pc, go to properties>sharing and allow sharing. You should see that folder now in xplore.
    You can also use ftp server. Download and install filezilla server, then add user/share folder.
    Add ftp in xplore.
    I usually get better speed in ftp than lan. Though you can not stream movies/songs in MXPlayer in ftp.
    Btw, you can do this in ES File explorer too.
    Member Shoaib's Avatar
    Khulna
    +1 for ES Explorer.
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    +1 for the ES File Explorer. It is the best android file manager. You can use it to explore shared files from your laptops and desktops over wifi home network.
    To make your phone files accessible over wifi to download and upload, you should use Samba File Sharing Pro. It will allow you to password protect the access to your phone.
    If your Wireless Network card supports creating ad-hoc network, that should do it.
    Quote Originally Posted by bayoy View Post
    android doesn't support ad-hoc.
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    you can use 'Wifi file transfer' for exploring and moderation. only drawback is the lite version doesn't support transferring file >5mb
  1. Any File Sharing Network?
    By totallynew in forum Smile/BDCom
    Last Post: January 28th, 2013, 14:28
  2. Sharing Wimax connection to a Wifi router
    By Kruger in forum Technical Support
    Last Post: April 23rd, 2012, 13:47
  3. Cant make wifi hotspot in laptop !!
    By ronycmc in forum Technical Support
    Last Post: April 3rd, 2012, 22:09
  4. File Sharing across two different ip ranges
    By optimus prime in forum Technical Support
    Last Post: March 7th, 2012, 11:23
  5. File Sharing With BTCL?
    By shakhawat in forum BTCL
    Last Post: June 5th, 2011, 15:33
Page generated in 0.20439 seconds with 14 queries.
