Results 1 to 20 of 31
Thread: 32 bit and 64 bit oprtating system
    • MuntZ's Gadgets
      • Gigabyte H170 HD3
      • Intel Core i5 6500 Quad Coer 3.2 GHz
      • Corsair Vengence 2 X 8 GB 2133 MHz
      • Samsung 850 EVO 250 GB, WD 3 TB, Hitachi 1 TB
      • ASUS STRIX GTX 970 DC II 4 GB OC
      • Benq RL2755HM 27" Full HD LED 1 ms response time
      • Razer Leviathan, Audio Technica ATH M50x, GX Gaming Cavimanus
      • Steerseries Sensei RAW
      • Corsair CX 600
      • Samsung USB DVD Writer
      • Windows 7 64 Bit
      • 7.6
      • Love It
      • TPG
      • 3.36 Mbps
      • 0.23 Mbps
    Sydney
    Question 32 bit and 64 bit oprtating system
    Guys can anyone clear me up on the difference between 32 bit and 64 bit OS. What is the advantage of having a 64 bit OS and what are the hardware requirements for a 64 bit OS?
    My config is
    Processor: Intel Core 2 duo E4500 2.2 Ghz
    Ram: 2 GB
    GPU: Ati hd 4850 Toxic 512 mb
    PSU: Asus 500 watt
    So is this sufficient to run 64 bit vista? Most importantly will I be benefited?
    Default Re: 32 bit and 64 bit oprtating system
    unless you have 4gb ram 64bit OS is worthless, install 32bit.
    Difference between x86 & 64
    http://www.mydigitallife.info/2008/0...windows-vista/
    Differences and Advantages Between 32-bit (x86) VS 64-bit (x64) Windows Vista
    Each editions of Windows Vista operating system is available in both 32-bit and 64-bit versions (x86 anx x64 are terms used by Microsoft), making 64-bit OS option now a widely available choice. And with almost all CPU processor and motherboard nowadays is x64 based which capable of running 64-bit OS, it presents hard decision to consumers to decide and pick whether 32-bit or 64-bit versions of Windows Vista is suitable choice.
    Microsoft publishes KB946765 which details the main differences between 32-bit and 64-bit Windows Vista, which mainly relate to memory accessibility, memory management, and enhanced security features, as listed in table below.
    Architecture Windows Vista, 32-bit versions Windows Vista, 64-bit versions System requirements 1-gigahertz (GHz) 32-bit (x86) processor or 64-bit (x64) processor,
    512 MB of RAM 1-GHz 64-bit (x64) processor, 1 GB of RAM (4 GB recommended) Memory access A 32-bit version of Windows Vista can access up to 4 GB of RAM. A 64-bit version of Windows Vista can access from 1 GB of RAM to more than 128 GB of RAM. Memory access per edition All 32-bit versions of Windows Vista can access up to 4 GB of RAM. Windows Vista Home Basic – 8 GB of RAM
    Windows Vista Home Premium – 16 GB of RAM
    Windows Vista Business – 128 GB of RAM or more
    Windows Vista Enterprise – 128 GB of RAM or more
    Windows Vista Ultimate – 128 GB of RAM or more DEP 32-bit versions of Windows Vista use a software-based version of DEP. 64-bit versions of Windows Vista support hardware-backed DEP. Kernel Patch Protection (PatchGuard) This feature is not available in 32-bit versions of Windows Vista. This feature is available in 64-bit versions of Windows Vista. Kernel Patch Protection helps prevent a malicious program from updating the Windows Vista kernel. This feature works by helping to prevent a kernel-mode driver from extending or replacing other kernel services. Also, this feature helps prevent third-party programs from updating (patching) any part of the kernel. Driver signing Unsigned drivers may be used with 32-bit versions of Windows Vista. 64-bit versions of Windows Vista require that all device drivers be digitally signed by the developer. 32-bit driver support 32-bit versions of Windows Vista support 32-bit drivers that are designed for Windows Vista. 64-bit versions of Windows Vista do not support 32-bit device drivers. 16-bit program support 32-bit versions of Windows Vista support 16-bit programs, in part. 64-bit versions of Windows Vista do not support 16-bit programs. If you value the benefits and advantages of switching and embracing 64-bit Windows Vista, here’s a few considerations to ponder before making the move to install x64 Windows Vista:
    • 64-bit device drivers may not be available for one or more devices in the computer.
    • Device drivers must be digitally signed.
    • 32-bit device drivers are not supported.
    • 32-bit programs may not be fully compatible with a 64-bit operating system.
    • It may be difficult to locate programs that are written specifically for a 64-bit operating system.
    • Not all hardware devices may be compatible with a 64-bit version of Windows Vista.
    Regards to mydigitallife on this one
    The advantage of x86(32bit) systems
    • Doesnt require a substantial amount of RAM to run it smoothly (eg-1-2GB)
    • all of the softwares are originally x86 made whereas in x64 systems u have to look for x64 softwares & drivers to take advantage of the platform
    • a wide amount of support is available for x86 systems including from drivers to softwares
    The advantage of x64(64bit) systems
    • Supports RAM greater than 4GB & can utilize efficiently
    • Intel Processors both have x86 & x64 instructions built on the CPU...& if a x64 version of an OS is used the CPU can take advantage of greater speed & also use memory efficiently
    • x64 drivers are surfacing fast...x64 drivers are jst as available as x86 ones
    • x64 systems are more secured & more optimized towards speed when coupled with 4GB+ RAM
    Bascially the main difference between x86 & x64 is the amount of RAM it supports
    likewise if u install 4GB TRAM in a x86 system....u will be limited to 3.25GB of usable RAM whereas if the same amount is installed in a x64 system...the total memory will be used aka 4GB & utilized to its maximum
    what I recommend it that...when having 2-3GB RAM...use a x86(32bit) ) OS...eg-Win-7 & Vista x86
    but when having 4GB+ RAM...definitely go for a x64 OS(in this case x64 of Vista or 7)
    hope I explained it all
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    32 bit has 86 binary codes converting into 32 while x64 has no compression.
    • MuntZ's Gadgets
      • Gigabyte H170 HD3
      • Corsair CX 600
      • Windows 7 64 Bit
      • 7.6
      • Love It
      • TPG
      • 3.36 Mbps
      • 0.23 Mbps
    Sydney
    Thanks @ dipanzan and others. its all clear to me now bro. thanx a lot.
    Would go for x64 for future proofing
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    For 2GB RAM, get 32bit
    For >3GB, get 64bit
    Its quite simple
    yes bro...3 gb+ ram is made for 64bit softwares
    • ga56mer's Gadgets
      • GA UD3P & DS3R
      • Intel Q9650
      • Kingston 1066 8GB
      • WD 1 TB
      • 9600GT
      • Samsung 226BW
      • Realtek
      • MS 2000 curve
      • Log G5
      • Corsair HX620
      • Pioneer 216
      • win 7 RTM 7600
      • case: antec p182
      • iiNet
    Oct 2009
    Sydney
    well its nice to have 64bit os with at least 4 GB ram so you can reduce page file size in OS.
    regards
    • Extreme Noob's Gadgets
      • Gigabyte P67A-UD3R-B3
      • Intel Core i5 2500k @4.3Ghz with CM Hyper212+
      • G-Skill Ripjaws X 4GBX2 1600Mhz @8-8-8-20
      • Mushkin Callisto Deluxe 40GB SSD; WD Caviar Black 1TB SATA3; Samsung Spinpoint F3 500 GB
      • Sapphire Radeon HD6950 2GB unlocked to HD6970; XFX GT240 as a dedicated Physx Card
      • Viewsonic VX2260WM 22 inch Full HD LCD Monitor
      • Creative Sound Blaster X-fi Titanium PCI-E
      • Microlab Solo 7c 2.0 Full Range Stereo Speakers
      • A4 Tech Slim Normal Keyboard
      • A4 Tech X7 Laser 3600DPI gaming mouse with Razer Goliathus Speed Edition
      • Xbox 360 Controller ; DIGI USB Joystick
      • Corsair TX650w V2
      • Asus SATA 24x DVD R/W Dual Layer
      • Twinmos USB Flash Disk 4 GB
      • Micro 1000VA
      • Windows 7 Ultimate 64Bit
      • 3D Mark Vantage- P24529; 3D Mark 11- P5642
      • Housed in a Cooler Master HAF 912 Advanced
      • IsPros
      • 30KBPS
      • Do not Know
    Extreme Noob's Avatar
    Sep 2009
    Mohammadpur, Dhaka, Bangladesh,
    Asole sudhu 4GB er upor ram utilize korar jonnoi 64bit OS dorkar.echara onnano dik chinta korle 32 bit e valo.karon ete software support beshi
    Quote Originally Posted by dramaviewer View Post
    in terms of software support...64bit variants of Vista can perfect emulate the old 32bit ones that are still not supported by the x64 platform
    you guys are forgetting about one thing...64bit is optimized towards speed...& drivers are also making out just like the x86 variants...if not more optimized...granted that it still has a long way to go, but x64 bit is truely a remarkable platform...I m using 64bit for about a year now...& I find it a tad faster than it x86 counterpart
    if you guys have a hefty 3-4GB RAM...go straight for x64...you will not regret it...even XP x64 is also much more stable than it used, & XP users are also not neglected
    & if you are a Vista/7 user...x64 of these variants is far by the best OS build till today
    And where i will get that x64 (pirated) OS disc? (vista/7)
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Ami always 64bit er use korte chai but HDD kom hoyar karone 32bit use korte hoy
    How much disc space is needed?
    • Muradd9's Gadgets
      • Msi B75MA-P45
      • Core i5 3470
      • 8GB 1600MHz Twinmos Twister
      • WD 2TB + Toshiba 2TB +Samsung 1TB
      • Msi GTX660Ti Oc 2GB DDR5
      • Samsung P2250 21.5
      • Realtek
      • Creative I-Trigue L-3500 2.1
      • Logitech K375s
      • Logitech M235 Wireless
      • Gigabyte Superb 550P 450W
      • Asus DRW-24B3ST
      • Creative muvo TX
      • RA Luminous ion 1500va(1200W) sine-wave ips
      • Windows 10 pro
      • 9007B server case
    Muradd9's Avatar
    Bogura
    Quote Originally Posted by xeon View Post
    IDB/ECS er onek shop e disc ase. R na pele amake janate paren.
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    download kore neai valo.
    Quote Originally Posted by Muradd9 View Post
    i was wodering... How will i be so sure that itz 64bit? Should i ask them? Most of them looks stupid.
    • Muradd9's Gadgets
      • Msi B75MA-P45
      • Core i5 3470
      • Realtek
      • Logitech K375s
      • Asus DRW-24B3ST
      • Creative muvo TX
      • Windows 10 pro
      • 9007B server case
    Muradd9's Avatar
    Bogura
    Win 7 64bit Setup er pore bluetooth,gpu,sound,physX,ms gameslive, audio video kodec,player, browser etc install korle 13~14gb lage amar.
    ---------- Post added at 23:59 ---------- Previous post was at 23:50 ----------
    Quote Originally Posted by Sumon Datta View Post
    jodi valo internet speed thake ba smile\bdcom er line thake. Karon win7 er iso 3gb.
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • 500W TT TR2
      • 10/10
      • 64kBps/128kBps
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Download korlei best.Specially if u can download it from Daruchini
    • Ridoy's Gadgets
      • Asus
      • AMD FX(TM)6100 3.30GHz
      • 16GB DDR3 RAM
      • 500 GB
      • EVGA GEFORCE GTX 960 SuperSC 4GB
      • Acer 21.5'
      • Creative 2.0
      • Trust
      • a4tech
      • PS4 Controller
      • Corsair VS550
      • Windows7
      • i m happy with dat..!
      • Telecom
      • 7mbps
    Ridoy's Avatar
    Munich,Germany
    keo XP er 64bit er CD ta dao vai.........
    "Football For Hope"
    http://banglagamer.com/forums/image.php?type=sigpic&userid=353&dateline=1241285141
  1. Garena EXP system
    By CvP in forum Garena Central
    Last Post: February 21st, 2010, 23:07
  2. Which Operating System Are You Using??
    By Deep -xCross- in forum Software
    Last Post: December 23rd, 2009, 17:14
  3. New Web Chat System
    By CvP in forum Announcements
    Last Post: October 27th, 2009, 23:34
  4. Trade REF system
    By TAW_LegendaryHero in forum Feedback
    Last Post: June 4th, 2008, 13:50
  5. Chatting system
    By ЯV●@spret in forum Feedback
    Last Post: May 30th, 2008, 12:53
Page generated in 0.31957 seconds with 14 queries.
