Results 1 to 10 of 10
Thread: water cooler buying help
    • hemal77's Gadgets
      • Gigabyte Z87 Sniper & Intel Dg31pr
      • Intel Core I7 4770k With TT Frio Adv & Intel Core 2 Quad 2.33GHz with Thermaltake frio advanced
      • Gskill TridenX 2400mhz 8Gb & 4 GB DDr2(2gb Twinmos+2gb Dynet 800 mhz)
      • 3TB internal(2tb Hitachi+1 tb Samsung) & 3tb Wd My Book & 160 Gb Samsung
      • ECS Geforge GTX 550ti
      • 32' Sony Bravia-KLV-32BX300 & Philips 22"-224EL2SB
      • Creative
      • A4tech-KBS8
      • HAVIC Gaming Mouse
      • XBOX-360
      • Cooler Master 80+ Silver M2 1000W Silver & Thermaltake TR2 RX-450 With Armor A60 AMD Edition Chasis
      • Asus Prtable DVD Writter & Asus Internal DVD Writer
      • Canon Lide 110 Scanner & Epson Me-10 Printer With Drum
      • apollo 800va
      • WIN-7-64 Bit Dark Deluxe
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Default water cooler buying help
    I Want To Buy cooler for my intel core 2 quad q8200 2.33 ghz,
    my choice listed below::
    TT Frio Ock-1 year Warranty
    TT Frio Extreme-1 year warranty
    TT Big Water a80-1 year warranty
    Coler Master Seidon 120m-No warranty
    Antec H20 620-1 Year Warranty But Market Out
    Corsair Water Cooler H60-1 year warranty But market Out
    Pls Give Me Some Advice Which Should I Take??
    Note I Know My Cpu Is Not Good Enough To Use Such As Cooler,But Now I dont have Such Money To Change my proc,mb & Ram.I Will change my config next year.so now i want to buy a decent cooler for future pupose.
    None of the ones listed above are proper water coolers, and for your case, I'd say the Tt Frio Extreme would be the best. If you plan of installing tall memory modules (RAM) then you might want to consider the Closed loop systems, all of them will perform the similar with the Frio Extreme a bit better than the others.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Quote Originally Posted by Rakin7 View Post
    bro thanx for ur opinion.but amar mb holo inteldg31pr,eto small mb te ki frio extreme lagano jabe??
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    I have a frio ock used no warranty.
    if u can access private shop area then price 2.9k
    if u can't then the price is 1/0 u do the math.
    Quote Originally Posted by hemal77 View Post
    Yes it can be mounted, but it will not be practical. Swapping out memory modules would require dismounting the cooler.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Ami Jodi Tt Frio extreme ta Nei Tahole Ki Amar North Bridge Er Shathe Kono Prb Hobe Na,Bcs My Dg31pr North Bridge Is too Big & Motherboard Is Too Short
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    ai mobo te frio extreme lagaye ki luv hobe? age mobo change koren.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Quote Originally Posted by Raziel View Post
    bro shobe change hobe but akhon shudhu ekta bhalo cooler er dorkar 3-4 months por shob change korbo without cooler,,
    bhai prb ta jante chai extreme ta ki apatoto ai mobo te lagano jabe????
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    i think frio extreme will be way bigger for a MicroATX (9.60 inches by 8.60 inches [243.84 millimeters by 218.44 millimeters]). Frio extreme itself is 148.2(L) x 151(W) x 160(H) mm. You can try to use H60 if u want.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    acha thak tahole extreme baad frio & Frio Advanced er modhe konta bhalo hobe??
    bump***
    Tt Fri Advanced Ta Nia Nisi Motherboard Niya Gesilam Setup koira Niya Aisi..now everything ok & i m Fine With My Temp
  1. Fully Custom Made Water cooler in BD
    By minitt in forum CPU
    Last Post: July 31st, 2015, 21:04
  2. help buying cpu cooler
    By hemal77 in forum Help - PC Buying
    Last Post: August 23rd, 2013, 19:42
  3. Need Help for Choosing Water Cooler
    By Buddy in forum CPU
    Last Post: June 15th, 2013, 04:22
  4. closed loop gpu water cooler
    By colt.58 in forum Help - PC Buying
    Last Post: June 2nd, 2013, 23:22
  5. CPU cooler buying help.
    By redwan hasan in forum Technical Support
    Last Post: June 2nd, 2013, 01:15
Page generated in 0.22163 seconds with 15 queries.
