Results 1 to 12 of 12
Thread: Cpu Temp Problem
    • hemal77's Gadgets
      • Gigabyte Z87 Sniper & Intel Dg31pr
      • Intel Core I7 4770k With TT Frio Adv & Intel Core 2 Quad 2.33GHz with Thermaltake frio advanced
      • Gskill TridenX 2400mhz 8Gb & 4 GB DDr2(2gb Twinmos+2gb Dynet 800 mhz)
      • 3TB internal(2tb Hitachi+1 tb Samsung) & 3tb Wd My Book & 160 Gb Samsung
      • ECS Geforge GTX 550ti
      • 32' Sony Bravia-KLV-32BX300 & Philips 22"-224EL2SB
      • Creative
      • A4tech-KBS8
      • HAVIC Gaming Mouse
      • XBOX-360
      • Cooler Master 80+ Silver M2 1000W Silver & Thermaltake TR2 RX-450 With Armor A60 AMD Edition Chasis
      • Asus Prtable DVD Writter & Asus Internal DVD Writer
      • Canon Lide 110 Scanner & Epson Me-10 Printer With Drum
      • apollo 800va
      • WIN-7-64 Bit Dark Deluxe
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Default Cpu Temp Problem
    First Amar Pc Er Description:
    Operating System : Windows 7 xDark™ v4.3 RG Deluxe 64-bit
    Motherboard : Intel DG31pr
    Processor : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4 CPUs), ~2.3GHz
    Memory : 4096MB RAM,DDR-2 800bus
    GPU : ECS Geforce GTX 550ti
    Casing : Thermaltake Armor A60 Red & Black
    PSU : Thermaltake TR-2 Rx 450Wt
    HDD&DVD : 1tb Hitachi + 1 Tb Samsung Sata,Asus DVDrw
    i m Using Stock Cooler using Tt TG2 Thermal Grease & My Cpu Temp(Core Temp) Goes 70-83+ While Gaming.At Idle Mode its 48-55 And
    using prime 95 4 15 min temp goes as below pic:
    Is It Ok? Or I Have To Buy Aftermarket Cooler pls Give Me Some Sug...
    i have cheap budget 4 cooler around 3-3.5k..
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by hemal77 View Post
    mone hoy ok c2quad beshi gorom hoy ...... if ur looking for a cooler u can take one from me
    check pm
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    Cm Hyper 212 Ta Ki Market E Ase Thakle Price Koto Ektu Keo Janan??
    check the cooling fan & clean the heat sink. make sure the heat sink is placed properly. you can try changing the thermal paste. Hyper 212 was not available(last time i checked), & its 2800BDT.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    bro thanks 4 reply,ami onekbar thermal paste change o clean korsi but temp same dekhay
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Since when you are facing such temp? Recently/for a long time now? Check if you have put the cooler tightly on the mobo or not. This often happens if you don't. Nonetheless, your temp seems high, even for a quad core on stock cooler.
    check if the cooler is putting enough pressure on the cpu. & if everything is okay but still cpu running at high temp... well it could be a problem.
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    bro amar shob kisu ok ase fitting ok paste ok..bro akhon ki kora jete pare.aftermarket cooler nile ki prb solve hobe??
    u can try...
    u got 82degree on no load? sure abt that?
    • hemal77's Gadgets
      • Creative
      • A4tech-KBS8
      • XBOX-360
      • apollo 800va
      • Smile-Silver
      • 40-50
      • In Local 500-600
    u can try...
    No bro,On Prime 95 Test 4 15 minutes i get 82+ temp
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    prime 95 is for stablity
    normal usage nd load e koto ashe seta dekhen ... prime 95 e to onek beshi ei dekhai
    maybe ur ok ... with it ...
    and pmed u .....
    just check no load temperature. on full load with a stock cooler 82 degree should be ok.
  1. XFX HD 5850 vrm Temp problem
    By Foxtrol in forum GPU
    Last Post: August 8th, 2013, 17:13
  2. temp monitoring software problem!
    By saadbillah in forum CPU
    Last Post: September 7th, 2012, 14:40
  3. [HELP!!!] GPU temp problem
    By OoAIDoO in forum Technical Support
    Last Post: July 3rd, 2012, 00:30
  4. Problem with CPU core temp.
    By salmanshah in forum CPU
    Last Post: January 14th, 2011, 19:11
  5. core i5 high temp problem
    Last Post: January 12th, 2011, 04:34
Page generated in 0.23178 seconds with 15 queries.
