Thread: Phenom ii X2 560 Unlocking Problem,help
    • mhasib3's Gadgets
      • MSI 990FXA GD 65
      • AMD FX-8350
      • Apacer ARES 2400MHz
      • Toshiba 1TB 7200RPM
      • Sapphire R9 280x 3GB DDR5 Vapor x
      • Asus VX229 21.5"
      • Realtech HD Audio
      • A4tech HS-30
      • Chicony KB-2961
      • Razer Hex Naga
      • Corsair CX 750
      • Asus 24x DVD\RW
      • Local 650
      • Windows 8 64 bit
      • Sunny Go
    Aug 2013
    Default Phenom ii X2 560 Unlocking Problem,help
    I Cant unlock my phenom ii x2 560 Black edition on my Gigabyte 78LMT-USB3 motherboard,when i turn on "core unlock" option on my bios,after saving,pc takes restart,it doesnt boot and shows black screen,then ive to clear cmos and turn on again my pc ,then i see that bois has been reset,
    when i install easy tune on my pc and turn on 'turbo boost' option to unlock hidden core,then pc wants to take restart,and if i choose restart,pc shut down nicely nd doesnt boot and keeps showing black screen,again ive to clear cmos and then bios got reset and pc start up
    please help me how to unlock it ,previously i unlocked this type of processor on msi 880GM-E41 and perform as a true quadcore processor,but in gigabyte mobo i failed again and again,anyone have personal experience about this?
    Because your motherboard dont support unlocking the core
    This core unlock feature is a hit or miss thing, in your case it's a miss. Nothing is wrong with your motherboard, nor your processor, you're just unlucky. You do understand that you're trying to enable a core or cores that were disabled by the manufacturers themselves, because of failure to produce satisfactory yield.
    Quote Originally Posted by BFG9000 View Post
    actually i had that board before and it couldnt able to unlock the cores, for x2 560be or other unlockable processor you need to have 880 series or greater motherboard
    • mhasib3's Gadgets
      • MSI 990FXA GD 65
      • AMD FX-8350
      • Asus VX229 21.5"
      • Realtech HD Audio
      • A4tech HS-30
      • Chicony KB-2961
      • Razer Hex Naga
      • Corsair CX 750
      • Asus 24x DVD\RW
      • Local 650
      • Windows 8 64 bit
      • Sunny Go
    Aug 2013
    Found the way to solve this problem
    actually processor ei problem silo,ucc te diyechi replace er jonno,within 2 days,amake processor replace kore dise,new jei processor dise oita unlock korar por tdp hoy 185 watt
    ashole oita processor er issue chilo bro
    yes bro,some problem has unlocking issue , some processor can be unlocked to 3 core,this kind of issue are common.but i didnt face any of this
  1. Phenom II X6 1090T bluescreen problem.
    By salmanshah in forum Hardware Modding
    Last Post: July 9th, 2012, 19:14
  2. Replies: 8
    Last Post: March 9th, 2012, 02:12
  3. Replies: 23
    Last Post: October 20th, 2011, 06:00
  4. xbla unlocking full game problem
    By Hellblazer1971 in forum XBOX
    Last Post: May 25th, 2011, 16:33
Page generated in 0.17126 seconds with 14 queries.
