Results 1 to 8 of 8
Thread: Need experts help for UPGRADING RIG & Gfx Card... :)
    • Sazzad_ag's Gadgets
      • Asus x58 sabertooth
      • Inlel core i7 950 @4.2 GHz
      • G.SKILL Ripjaws-X Series 8GB (2x4GB) 1866 Bus CL9
      • 2x Corsair Neutron GTX 240GB SSD [RAID-0] & WD-500GB-Caviar Blue & WD-1TB-Caviar Blue [SATA3]
      • EVGA GeForce GTX 780 SC w/ EVGA ACX Cooler
      • BenQ GW2255 22" LED Full HD 1080p
      • Build-In
      • Skullcandy 50/50 Rasta Earphones
      • Tt ToughpowerST-750w-80plus Gold Edition
      • Liteon DVD-Multi
      • Power Gard 1200VA UPS
      • Windows 7 64bit
      • 3DMark 11 Basic Score: P11560
      • 2048
    Sazzad_ag's Avatar
    Apr 2013
    Chittagong, Bangladesh
    Default Need experts help for UPGRADING RIG & Gfx Card... :)
    Hi guys,
    assalamualikum, hope all are fine today, i'm new in here....
    Need experts help for buying new Gfx Card & UPGRADEING my current Gaming RIG....
    [MY TARGET ONLY GAMING]
    My current RIG:
    1. Intel core i7 950 3.07GHz
    2. Tt Frio Advanced CPU cooler
    3. Asus x58 Sabertooth [rev:1]
    4. 4x4GB Viper-III 2133bus RAM
    5. HDD: WD Blue 500GB SATA3
    6. SSD: *** No [last is Adata-XPG-900 128GB]
    7. GPU: *** No [last is 660ti]
    8. Sound Card: No
    9. PSU: Tt Smart-POWER 550w Modular 80pluse Bronze
    10. Case: china normal
    Now, i want to know
    1. My mobo&processor is ok for gaming for next 5yeast?
    2. Which GPU (used) is batter for my RIG @ 31-35k?
    3. RAM is not fully support. I only ocing @ 1825MHz. So can i sell those & get 2x4GB 1600 CL:8? Are 8GB enough for gaming?
    4. Can my PSU full support the Gtx-770?
    5. Sound Card is important for my RIG?
    Thanks.....
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    from my pov>>
    1. yes.
    2.7950HD
    3.even 4gb
    4. yes
    5. Helllllllll no.
    1. no or yes actually we cant say as we are not fortune teller afterall but upgrading in 4th generation at least can ensure your future support
    2.gtx 760 or 770 not sure how it will be priced in bangladesh after arrival though
    3. 8gb is fair enough even your recent rams are even more than enough
    4. yes
    5. depends on your choice, do you like surrounding gaming experience or not and also if you dont have a good speaker setup then there is no need of a sound card
    personal suggestion: 1. you should increase your hdd space by adding 1tb hdd
    2. change the casing which one have good airflow and good space for cable management
    3. not sure about your last ssd but its better to have one either its intel or samsung 128gb ssd's
      • Build-In
      • Liteon DVD-Multi
      • Windows 7 64bit
      • 2048
    Sazzad_ag's Avatar
    Apr 2013
    In nvidia web site, they recommend 600/650w PSU for 770, why?
    from my pov>>
    1. yes.
    2.7950HD
    3.even 4gb
    4. yes
    5. Helllllllll no.
    Thanks bro.
    I found a 7970 oc dual-x for 30k, 1.5y warranty still have with paper. Thats good or not?
    4. yes
    thanks bro.
    I don't have a good speaker. I've a 2:1 old1 & a headphone...
    Yes Adata is good enough is sell it for 660ti....
    Wait for 770 or go whit a msi-680-oc for 35k [1.5y warranty]
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^no. 27k around would be good i think.
    Quote Originally Posted by Sazzad_ag View Post
    thanks bro.
    just ignore nvidia's recommendation 550w is enough or if you are so confused then grab a 650w corsair tx or ax unite then. if you dont have a good speaker no point of buying a good sound card as well and gtx 770 is the overclocked version of 680 , so if you get a gtx 680 at 35k then i would say grab it afterall a little bit improved gtx 770 may cost you 40k+ so its upto you
    thanks bro.
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    @Sazzad_ag :
    Onix Computers Bd already brought Gigabyte 770 and 780: (don't know if this is real):
    http://www.onixcomputers.com/index.p...etail?Itemid=0
    My suggestion, if you are willing to spend 35K on a GFX card try to manage 2K more and buy a MSI 670:
    http://www.ucc-bd.com/msi-n670gtx-oc...hz-memory.html
      • Build-In
      • Liteon DVD-Multi
      • Windows 7 64bit
      • 2048
    Sazzad_ag's Avatar
    Apr 2013
    @Sazzad_ag
    WHY 670? I go with only 680/770/7970....
  1. Suggestion needed from Android experts!!
    By Badhon_raj in forum Help - General Shopping
    Last Post: August 2nd, 2013, 05:13
  2. Upgrading pc
    By Shetu in forum Help - General Shopping
    Last Post: June 1st, 2012, 23:10
  3. Emergency help needed from the BG Television Experts :| :/ :'(
    By Loners Persona -.- in forum Technical Support
    Last Post: February 2nd, 2012, 14:08
  4. PC upgrading help!
    By samgamer in forum Help - PC Buying
    Last Post: April 28th, 2011, 12:47
Page generated in 0.21008 seconds with 14 queries.
