Thread: USB port problem
    Default USB port problem
    Having this strange problem with USB ports in my desktop. If i try to connect more than one USB device into the front or back port, the devices already connected to the other ports lose their connection and do not get recognized until I remove the new device or restart the PC altogether. Can anyone shed some light on why this might be happening?
    I suspect the PSU might be behind this (my GPU got fried recently and the internal DVD rom does not work properly if i connect it ), but all the other component are working fine. Thanks in advance
    • Metal's Gadgets
      • GIGABYTE [ GA-EP43-UD3L ]
      • INTEL(R) Core(TM)2 Quad CPU Q9505 @ 2.83Ghz
      • APACER 4GB DDR2
      • SAMSUNG 750GB
      • NVDIA GeForce 9500 GT
      • Dell E178WFP
      • CREATIVE Sound Blaster 5:1
      • COSONIC CD-779MV
      • A4Tech KR-83 USB [Black]
      • A4Tech OP-620D
      • ASUS P-50GA
      • ASUS DRW 24B1ST
      • Windows 7 Ultimate
      • ISPROS Limited
    Metal's Avatar
    Feb 2012
    Chittagong
    Sounds Like your motherboard circuit caught some problem. You sure with the driver issue have you installed chip-set inf utility and check if there is any unknown device showing in your driver manager of windows.
    You better take your PC to the doctor ask for a full checkup.
    Disconnect the front USB wire from mobo and try USB of your CPU back panel, if problem remains try with mulit-port active USB HUB.
    Power is not only what you have but what the enemy thinks you have.
    Quote Originally Posted by Metal View Post
    Motherboard circuit? Mane kothao short ase?!?! The other components work fine though, except of course the failing gpus....
    I dunno chipset drive install kora ase ki na, but i do see two unknown devices in Dev Manager. One of them is for the external drive, the other I'm not sure. Here's a screenshot for the unknown devices in dev manager.
    The external drive is connected to the back port, and yes, oitar o connection chole jai but I can see the folders inside but not any files
    • Metal's Gadgets
      • APACER 4GB DDR2
      • SAMSUNG 750GB
      • Dell E178WFP
      • COSONIC CD-779MV
      • A4Tech OP-620D
      • ASUS P-50GA
      • ASUS DRW 24B1ST
      • ISPROS Limited
    Metal's Avatar
    Feb 2012
    Chittagong
    @MrKronix if your motherboard is of intel chip go to this site http://www.intel.com/p/en_US/support/detect and check for latest drivers.
    also install western digital driver from here http://support.wdc.com/product/download.asp?lang=en
    yes motherboard e short thakthe pare. Go check one by one
    GPU the fault ache hmm oita khule rakho apathotho jodi slot e lagano thake.
    and offcourse front panel usb connection khule rakho from mobo. use back panel only
    @Metal Like i mentioned earlier, my GPU is fried already, so obviously i removed it.
    So far i switched the front USB connection to an alternative port, but after I did that the computer does not pass POST. Onekkhon ATX power cable niye tanatani korar por it sprang back to life. However the problem still remains though :/
  1. Banglalion port forading problem
    By niloy320 in forum Member Central
    Last Post: March 31st, 2013, 05:33
  2. Replies: 19
    Last Post: November 4th, 2012, 21:51
  3. Want to Buy Monitor with dvi port
    By Mohiuddin in forum Shop - Gadgets
    Last Post: September 19th, 2012, 12:49
  4. Port-forward
    By Finix in forum ISPros
    Last Post: May 5th, 2012, 20:56
  5. Usb 3.0 rear port Problem
    By Salmaan in forum Technical Support
    Last Post: January 16th, 2012, 23:27
Page generated in 0.19075 seconds with 15 queries.
