Results 1 to 6 of 6
Thread: Need help with my first PC build
    Default Need help with my first PC build
    Hello Everyone, this is my first attempt to build a pc from scratch, so here
    is the inputs that I should've provide.
    1. What is your budget? around 70k
    2.
    What is your existing hardware configuration? n/a
    3.
    Which hardware will you be keeping? mouse, keyboard, speaker, monitor
    4.
    Which hardware component are you looking to buy?
    intel i5-3470 cpu
    asus p8b75-v mobo
    gigabyte gtx650 2GB gpu
    Twinmos 2 x 8GB 1333Mhz ram
    WD 1TB cavier blue hdd
    asus dvd burner
    in-win buc casing
    antec VP450p NC
    5. Is this going to be your final configuration
    I will add another 16GB ram soon, and a cpu-cooler may be.
    6. From where will you buy these hardwares? Bangladesh/IDB
    7.
    What is your intended use for this PC/hardware?
    computer graphics, mainly (3d package)houdini,
    a lot of photoshop, after effects and maya also.
    8. Do you have any brand preference or dislike?
    NO brand preference, but my chosen software, houdini prefers nvidia
    cards, so no amd card.
    9. If you will be playing games then which type of games will you be playing? n/a
    10.
    What is your preferred monitor resolution for gaming and normal usage? 1920 x 1080
    11.
    Are you looking to overclock? I am not sure !
    12. Which operating system do you intend to use with this configuration?
    a. window 7
    b. ubuntu 12.04
    Thank you in advance -- Aasif
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    Monitor=Asus VS228H 21.5 Inch...14.2k
    Cpu=Core i5 4570....18.4k
    Mobo=gigabyte H87 HD3...11.5k
    Gpu=u can wait for the gtx 700 series to come...otherwise u can go for the 650
    Ram=(2x4GB)twinmos 1600mhz...6k (is 16GB really needed???)
    HDD=WD 1TB CB...6.1k
    ODD=Samsung DVD writer...1.5k
    Casing=of ur choice...~6k(price includes fans too)
    TOTAL=76.7k
    Increase ur budget a bit...u'll get a good config imo..nd there's also room for bargaining..
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    Quote Originally Posted by maheer.dhruba View Post
    TOTAL=76.7k
    since u don't need a monitor u can invest that 14k towards a better gpu (like a GTX 660) or maybe an i7...
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    Hmm...didnt notice that he didn't need a monitor...then u can go for 660 combined with a CM gx550w psu..
    intel core i7 3770 28k
    gigabyte b75 6.2k
    4gb ddr3 3.2k
    hdd wd 1tb 6k
    tt gs2 3.8k
    tt litepower 500w 4.8k
    4gb ddr3 ram 3.2k
    samsung odd 1.5k
    gtx 650ti 15k
    total:71k
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Intel Core i5 2310 (2.9 Ghz)--Stock Clock--Stock Fan
      • PQI-4gb-1333 Bus-single stick.
      • SAMSUNG Sata-2 (320gb)
      • Gigabyte 660-OC-2GB-Windforce2..
      • Samsung B1930-LCD-18.5 inch :(
      • Built in.
      • Creative Inspire T3200 (2:1)
      • Value Top-normal (multimedia)
      • A4tech X7..
      • Thermaltake Smart 550w- Modular
      • Samsung Writemaster-- Not using currently -_-
      • Apacer 8gb Pendrive-usb2-_-
      • Prolink-650VA
      • Windows 7-Ultimate-64bit
      • Gaming is fun, but Acquiring a Satisfactory setup for it is not -_-
      • 190kpbs
      • Havn't checked yet!
    -RAKIB-'s Avatar
    Jan 2013
    Well, a little edit.. Don't buy samsung odd.. They s****.. Try Asus instead!
    Why so Serious!
  1. How to build a PC: Step-by-step instructions for a custom build
    By emroz_2272 in forum Technical Support
    Last Post: December 19th, 2012, 15:52
  2. Help me to build my pc
    By bioshock in forum Help - PC Buying
    Last Post: March 22nd, 2012, 00:28
  3. Help me to build a new rig, please. :)
    By Nahid in forum Technical Support
    Last Post: October 7th, 2009, 20:33
  4. Need help with i7 build
    By Dissent in forum CPU
    Last Post: August 27th, 2009, 21:06
  5. i need IDM 5.15 Build 6
    By CHR.Satiator in forum Software
    Last Post: February 25th, 2009, 03:56
Page generated in 0.24326 seconds with 14 queries.
