Results 1 to 18 of 18
Thread: Too Strange! Need help with my exe files :(
    • TE.Ruff's Gadgets
      • Abit IP35i / nforce 650i sli
      • Core2Quad Q6600
      • Twinmos 2GB DDR2 x2
      • Samsung 500GB SATA2
      • MSi GTX 460 768MB
      • Samsung 17" SyncMaster 743
      • built-in
      • Foul Microlab 2:1
      • Genius Gaming Keyboard
      • Microsoft Intelli Explorer 3.0
      • Logitech Ramblepad 2
      • Nonbrand FAST 700W
      • Windows 7 Ultimate 64bit
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    Exclamation Too Strange! Need help with my exe files :(
    I am using windows 7 Ultimate 32bit RTM 7600 Build 16399.
    Problem is, I can't delete/move a exe file immediately after it appears. When I delete/move a exe file it returns. No error message shows during deletion/moving. I delete/move a exe files very grammatically then i refresh my windows/desktop and I see, that exe file returns in its location. BUT, a few minutes later that file delete/move automatically (I mean, you can do anything you wish to do with that exe). First few minutes exe files show this problem then it's ok).
    Example: After I install a game when i have tried to copy crack I can't. Because exe file is using by someone. I need to wait at least 5 min to overwrite the crack.
    Again i can't compile a programming code twice in a minutes in visual studio because debugger can't overwrite the code exe file that created by compilation.
    Info:
    1. Safe mode ei problem hoina.
    2. I checked every startup files and found nothing.
    3. My virus scanner Norton 2009 16.7.0.135.
    4. UAC is turned off.
    5. Processes also explored.
    So, anyone got any experience with this type of problem???
    [Progress isn't made by early risers. It's made by lazy men trying to find easier ways to do something.]
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    Default Re: Too Strange! Need help with my exe files :(
    usually caused by a virus (or an antivirus).
    try disabling your antivirus and then try.
    keep note that in safemode, antivirus doesn't run.
    • SinEater's Gadgets
      • ASUS P5K-VM
      • Pentium E 2200
      • 6 GB DDR2, 800 MHz
      • Samsung 500 GB + 500 GB
      • 450 GTX
      • Samsung 933SN LCD
      • Realtek, integrated
      • T6200 5.1
      • Razer Lycosa, Razer Arctosa
      • Razer Lachesis, Razer Death Adder L/H
      • Microsoft SideWinder
      • Corsair 650 W
      • Asus Combo Drive
      • Qubee 1mbps
      • 20
    SinEater's Avatar
    Mogbazar, Dhaka
    I think it is being done by your AntiVirus or similar kind of protection system enabled in your computer. It is scanning and locking up any new exe file for a certain period of time.
    Click here to find out how a noob plays the Anti Mage
    Honesty and Modesty were the best policy...they still are.
    A single stupid man can ask more questions than a thousand wise men can answer
    <nfs>.......for life..
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17&quot; LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Yeah ei problem ta amaro hoisilo coz of Virus..Pore Nod32 diye virus check korlam dekhi koyekta worm and trojan horse ase.Ogula delete hoyna karon system 32 folder er bhitore chilo..So amake C drive ta format korte hoisilo..Format korar por thik hoye gese
    Every time I turned off UAC in Vista, there was always problems. So i just learnt to live with it. Turn it on, its not as annoying in 7.
    • TE.Ruff's Gadgets
      • Core2Quad Q6600
      • MSi GTX 460 768MB
      • Samsung 17&quot; SyncMaster 743
      • built-in
      • Foul Microlab 2:1
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    It's a virus/worm problem, not antivirus.
    I scanned with Norton, Nod32, Kaspersky to find that virus but they all failed. Anything else I should try? Onno ki antivirus die scan korbo?
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5&quot; Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    maybe you are attacked with win32 Sality virus.
    download this small antivirus and check your exe files:
    http://www.softpedia.com/get/Antivir...-Remover.shtml
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • SAMSUNG SA300B 21.5&quot; 1080p Monitor For PC and LG 2043T 20&quot; for PlayStaion 3
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    USE AVG.
    it has biggest virus vault built ever.
    • TE.Ruff's Gadgets
      • Core2Quad Q6600
      • MSi GTX 460 768MB
      • built-in
      • Foul Microlab 2:1
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    AVG failed. I guess I need to reinstall my windows (
      • 1TB+1TB+80GB
      • 17&quot; LCD
      • Realtek built-in
      • Logitech G19
      • 500W TT TR2
      • 10/10
      • 64kBps/128kBps
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Man.I cant belive Nod32 n Kaspersky failed :O
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • Samsung 17&quot;+22&quot;+22&quot;
      • Realtek HD Audio &lt;internal&gt;
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    and how they all failed?
    • TE.Ruff's Gadgets
      • Core2Quad Q6600
      • MSi GTX 460 768MB
      • built-in
      • Foul Microlab 2:1
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    Quote Originally Posted by ►Sy3D|^|SuNnY• View Post
    Man I was shocked too. I guess I need to reinstall my os . Echara ar upai passi na. 4ta virus scanner fail korlo. I think there is no virus. Its left my os by changing some internal settings.
    • cRush's Gadgets
      • Abit IP35P
      • Core 2 Quad Q6600 2.4Ghz (Oc @ 3.11Ghz ) 2*4MB Cache
      • 2*2GB Transcend DDR2 Ram @800Mhz (Oc @840 Mhz)
      • 320GB Hitachi HDD + 500 GB Samsung F3 HDD
      • Palit GTX560 Ti Sonic 1GB
      • Samsung SyncMaster932B 19&quot; LCD Monitor
      • RealTek HD 7.1 Soundcard
      • A4Tech Headphones+ Creative 5:1 Surround Sound
      • A4Tech Anti-RSI Keyboard
      • Genius G500 Laser 2500dpi
      • Sony Sixaxis
      • ThermalTek 420W
      • Asus SATA DVDRW drive + Asus IDE DVD-combo Drive
      • Windows 7 RTM 64Bit
      • IT RAWKS :D
      • Local (STAR ISP)
      • 32 - 40
      • 40 - 60
      • 144
    cRush's Avatar
    the problem is that ruff treats his pc like a slave.
    • TE.Ruff's Gadgets
      • Core2Quad Q6600
      • MSi GTX 460 768MB
      • built-in
      • Foul Microlab 2:1
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    Quote Originally Posted by [TH7][cRu$h] View Post
    Yap. PC is definitely a slave. Btw, I'm asking for help here. So, don't write craps.
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    to me, your asking help doesnt seem to be of any use.
    you keep saying "antiviruses failed" like you know the reason behind this (virus).
    and if you know the reason, you dont need to ask here for help, right?
    instead try something that others suggested and post the outcome.
    esp, try disabling all antivirus. and all startup programs.
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    Do what CvP says.
    To disable startup use msconfig for best result.
    • TE.Ruff's Gadgets
      • Core2Quad Q6600
      • MSi GTX 460 768MB
      • built-in
      • Foul Microlab 2:1
      • 1/0
    TE.Ruff's Avatar
    Uttara, Dhaka
    1st. ekon porjonto keu kono diff. suggestion dei nai.
    2nd. I already mentioned, ami sob startup file chk korsi. Mean, startup file disable kore chk korsi.
    3rd. Ami 4-5br anti virus change korsi and chk korsi and disable korsi. No result.
    Thnx.
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    you have to mention that you tried, right?
    since you said, "1. Safe mode ei problem hoina.",
    it ONLY means some of your startup/regular program/service is cracked up.
    with the help of msconfig (better if autoruns), disable/enable them, restart, isolate the process
    that is causing this. dont forget services (hide microsoft services first).
    if this doesn't solve it, some hook is attached with regserver which is causing this behavior.
    if that's the case, it'll be a PITA to isolate that.
  1. What to do with .mdf and .mds files?
    By Necray in forum Technical Support
    Last Post: April 12th, 2009, 23:03
  2. Strange Occurances is Bdgaming server :/
    By LynAs in forum CS: Source
    Last Post: December 13th, 2008, 23:38
  3. strange problem....any solution?
    By saadbillah in forum Older NFS Games
    Last Post: November 16th, 2008, 22:38
  4. How can I create .ini files?
    By Tian in forum Software
    Last Post: September 6th, 2008, 00:27
  5. Search Rapidshare files...anything
    By Mad Monk in forum Technical Support
    Last Post: March 31st, 2008, 01:33
Page generated in 0.29259 seconds with 14 queries.
