Results 1 to 10 of 10
Thread: XFX HD 5850 vrm Temp problem
    Default XFX HD 5850 vrm Temp problem
    my 5850 vrm temp is close to water boiling point. today while playing BFBC2 the vrm temp was 94.5 C . although the gpu itself was cool at 62 C.
    the problem started after i remove the heatsink to clean it. the vrm is only covered with some sort of thermal pad/tape. anyway after i put together everything back properly gpu temp reading was ok but for some reason the vrm was not cooling properly. so i unscrewed everything and reseat them but no change. i am not inexperienced about pc but now i have no clue about what to do .
    my idle temp is gpu 38.5 C vrm 44 C and on load well gpu is warm and vrm is getting cooked. so i need your help guys as i cannot play games.
    and anyone knows where can i buy thermal pad/ tape or heatsink for vrm cooling. i am thinking about changing that.
    here is my card http://www.newegg.com/Product/Produc...82E16814150477.
    i forgot to add the card is not oc'd it is running at 725/1000 Mhz and fan speed 60% of max.
    • neorage's Gadgets
      • Gigabyte GA-P55M-UD2
      • Intel Core i7 860 @ 2.93Ghz
      • Corsair Vengeance 2x4GB DDR3 1600MHz (9-9-9-24)
      • Samsung 830 128GB SSD (Boot Drive) & Samsung F3 1TB
      • ECS GTX560 1GB
      • View Sonic VA703m 17" LCD
      • Realtek ALC888B
      • Havit HV-H611d
      • A4Tech Bloody V3
      • Thermaltake TR2 550W || Antec One S3
      • Asus DRW-24B1ST
      • Corsair Flash Voyager 16GB USB 3.0
      • Prolink 650VA
      • Windows 7 x64 SP1
      • IS Pros
      • 1.25 Mbps
      • 512 kbps
    neorage's Avatar
    last time, i checked at elephant road but could not find any thermal pads.......you can try your luck at laptop repair shops as thermal pads are often used on laptops for cooling.
    @neorage thnx man for your reply.
    hmm then i am in trouble. so any idea how i can drop the temp at least below 80 C ?
    May be when you was cleaning the gpu then somehow you removed the thermal paste or you didnt fit the cooler properly, just get a thermalpaste (cm or tt thermal pastes cost might be 500 to 1k) and apply it in your gpu , for better understanding watch the video in youtube about how to apply thermalpaste on gpu and that might help you
    Quote Originally Posted by hyder711 View Post
    It's perfectly normal for AMD 58xx VRMs to reach 80+ when under load, they are designed to go as high as 120C and still operate normally. Check wether you are properly aligning the thermal pad over the VRM area and your cooler mounts. They need to have sufficient pressure to stick to the heatsink if you have opened them recently, such as yours. I cleaned my 460s cooler numerous times and the thermal pads without any issue.
    He's talking about VRMs, not the GPU core. They are usually cooled using thermal pads and not liquid TIM paste.
    Thanks bro for the reply.
    but problem is(you might have seen the pcb ) the pad is fixed with the pcb with 2 screws which are not part of the heatsink and i have tightened them as far as possible(ofcourse with alignment as the screw won't fit w/o it). but okay i will try again.
    another thing how did you clean the pad? it is really dirty and lost stickiness so i am thinking about changing them. you know where can i find them ?
    @sensei bhai gpu temp to normal ami vrm nie jhamelai asi . anyway thanks for your suggestion.
    ami vabsilam pura gpu er temperature vram er ta kheyal kori nai, jai howk dipanjan vya er kotha tai thik eita normal temperature e ghabranor kisu nai
    The thermal pad on my 460 was attached using to bolt-up screws, much like the ones that are used in heatsinks on motherboards. I just cleaned them with water and re-used it again. I don't know where to get pads here in BD, but if you don't find them here. Order them from overseas, should be cheap enough from FB services like amazon.com.bd. Btw the temperatures are fine, but if it still bothers you directly a fan over the VRM area and hopefully it'll cool down a bit.
    vhai temp to aro bartese ajke shokale 103.5 C hoise. tarporo dekhi ki kora jai. ar fan kemne lagabo kono idea ase ? ar pad pani die wash korle problem naito ? running water or cloth soaked in water ?
    I used running water. As for the fan, what I meant was to direct a 80-120mm fan over the VRM area. You have to think of something in your case, like using zip ties, etc.
  1. temp monitoring software problem!
    By saadbillah in forum CPU
    Last Post: September 7th, 2012, 14:40
  2. [HELP!!!] GPU temp problem
    By OoAIDoO in forum Technical Support
    Last Post: July 3rd, 2012, 00:30
  3. Problem with CPU core temp.
    By salmanshah in forum CPU
    Last Post: January 14th, 2011, 19:11
  4. core i5 high temp problem
    Last Post: January 12th, 2011, 04:34
  5. Replies: 7
    Last Post: April 11th, 2010, 23:58
Page generated in 0.22340 seconds with 14 queries.
