Thread: Repeatedly restarting my pc...need help
    Default Repeatedly restarting my pc...need help
    Bro when i turn on pc, after 1 second it restart...and restart again and again...and pc restarts 4 times quickly within 2 seconds...what shd i do...i know i have to go service centre...bt what is the actual pro...
    Is it ram prob?
    Or psu?
    Or cpu fan damaged?
    first of all check ur psu.
    check all the connector (including power button connectors and all)
    check whether all the fans are spinning.
    check if cpu gets overheated
    MB or ram has the issue more likely. lets try first to clear CMOS (resetting bios),
    sometimes it solved this kind of issues.
    Quote Originally Posted by sobuj7354 View Post
    delete chaple bios ase...then r keyboard kaj kore na
    no cpu is fine
    Apr 2013
    Motherboard power failure, I faced it few days ago and got new board after warranty placement, mobo powerfail cannot be solved
    This can be the psu or the mobo and also can be the ram as well , use this 3 parts separately and hope you will detect the problem by yourself
    Quote Originally Posted by Dna Mex View Post
    oh God
  1. CMOS error repeatedly after Plugging Out
    By Trave160 in forum Technical Support
    Last Post: July 12th, 2013, 16:01
  2. PC restarting problem!!
    By QuadStorm in forum Technical Support
    Last Post: June 6th, 2013, 00:49
  3. Replies: 17
    Last Post: March 10th, 2013, 15:34
  4. PC Restarting Problem
    By anik_lc in forum Technical Support
    Last Post: July 10th, 2011, 02:42
Page generated in 0.19046 seconds with 14 queries.
