Results 1 to 6 of 6
Thread: Strange Problem!!!
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Default Strange Problem!!!
    It is happening for couple of months. When I press the power switch my comp turns on and immediatley turns off! It happens for sometimes then my pc turns on. I checked every connections. After joining all connections it turned on with the first attempt. after shutting it down againg after sometime I pressed the power switch and it worked. But after 6-8 hour when I again tried to turn it on it happened again! Now it is happening every time I am trying to turn on my pc. Anyone knows how to solve it?
    Btw I checked the power button. It is ok as my mobo has a dedicated power button on it. When I pressed that button that sh*t happened!
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    Your psu is screwed. change it. Mobo short-circuit may happen as well.
    Are you running stock clocks? It might be due to low vcore at startup causing the system to force restart. If it's at stock it shouldn't happen, try increasing the vcore and check your DRAMs.
    Quote Originally Posted by shaikh_imtiaj View Post
    I had this prob at the beginning of this year. And guess what? I had an ASUS mobo, the x58 Sabertooth. I did wide-scale research, but not too many answers were there. Little hints I got off hours of trolling boards was that ASUS boards may have some sort of conflict with certain PSUs. If u r using an ASUS board, the best bet would be to change the board and see.
    I stripped the PC and sold the components save the board.
    you could try wtih one ram installed, if you have two
      • Asus MS228H LED
      • 60-70 | 100
      • 60-70 | 8
    Jan 2009
    Greenroad,Dhaka
    I also saw in net that some asus mobos has that issue. One rmad that and other one changed the screw that secured the board! I brought the asus mobo from austrealia so I dont have any option to change! PSU also has no warrenty so ultimately I think I have to stay with this prob until I change the system
  1. Strange problem in win 7
    By Speed in forum Technical Support
    Last Post: December 8th, 2014, 01:39
  2. Strange problem
    By Cpt.Mactavish in forum Technical Support
    Last Post: January 20th, 2012, 20:46
  3. Strange Problem in Nfs the run ! ! !
    Last Post: December 15th, 2011, 11:22
  4. Strange problem!!!!!
    By shaikh_imtiaj in forum Technical Support
    Last Post: December 10th, 2010, 02:51
  5. Strange Pc Problem
    By D3FC0N in forum Technical Support
    Last Post: October 11th, 2010, 18:12
Page generated in 0.20173 seconds with 14 queries.
