Results 1 to 15 of 15
Thread: Need help with i7 build
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • 3TB Samsung (3 HDDs)
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • Generic Headset | Microlab FC550
      • A4Tech Generic
      • Logitech MX 518
      • Genius Speed Wheel 3 Vibration & MaxFighter F-23U
      • Thermaltake Toughpower 650W
      • Samsung
      • Transcend 16GiB USB3
      • None atm
      • Windows 7 | Arch Linux
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    Question Need help with i7 build
    well guys, im buyin an i7 rig this week and i've got the specs all sorted out....wht i need help with is the price of the items and whether they're available in BD or not...see specs below:
    CPU: Intel Core i7 920
    CPU HSF: Stock (since i wont be OCing) + Arctic Silver 5
    Mobo: ASUS P6T Deluxe
    Memory: ............................................
    GFX Card: XFX Radeon 4890 1GB
    PSU: Thermaltake Toughpower 650W
    Case: Thermaltake Element G
    HDD: Will use the one i have currently
    ODD: ASUS DRW-2014L1T (already have it bought and boxed)
    so could anyone list the price, and the availability of the parts in BD? also, i need help with the memory cuz it seems transcend doesnt have high perf. triple channel kits for i7 yet so im kinda confused wht to buy....
    i'll be buying from IDB so plz dont suggest anything from e-tailers like newegg
    thx
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    Default Re: Need help with i7 build
    Quote Originally Posted by hiei-warrior View Post
    GFX Card: XFX GTX 260 Black Edition
    PSU: Thermaltake Toughpower 650W Modular
    thx
    You can find product prices ||HERE|| ( http://banglagamer.com/forums/showthread.php?t=5916 ).
    And I'll suggest you to buy the XFX HD4890 1GB instead of XFX GTX260 Black Edition, it will not only perform better but also will cost less. HD4890 performs some what similar to GTX275 & even better in some games.
    You can only find normal (non oc-able) Transcend Triple Channle DDR3-1333Mhz CL9 2GB DIMM Ram. Just buy 3 DIMM for Triple Channel. 2GB DIMM costs about ~3000TK.
    Arctic Silver 5 & Thermaltake Element G is not available in BD. But if you want to buy Arctic Silver 5 then you can talk to Mazhar vai in this thread, ||HERE||. And Thermaltake Toughpower 650W costs 11500TK.
    BTW, Welcome to BG! =)
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    thx for the quick reply (and also for the welcome )
    about the AS5, i already have it so i wont need to buy it....so the 4890 is cheaper than GTX260? i didnt know that....thx for the advice
    actually i think i read in a magazine not too long ago that UCC has the Element G in stock so guys, could u give me some suggestions for a good case with plenty of airflow?
    btw, the price guide rocks
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    How much is your budget?? If it's about 15K then you can buy the Thermaltake Spedo Advanced Package. If it's lower then that then I'll suggest you to go to UCC take a look at all the available cases & choose the one you like.
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    If you need a high performance triple channel DDR3 kit designed for i7 motherboards, let me know and i can bring it for you. However, do keep in mind the warranty issues since you need to ship it to UK for RMA
    About the PSU, I can bring one as well, and warranty is not much of a problem with PSU's. But of course if its not working ill give a full refund immediately
    There are much better PSU's than thermaltake available here, and thermaltake is way overpriced in BD. Corsair, OCZ, Enermax and Antec have much better 650-750W PSU's that will be cheaper, more reliable and will provide cleaner power than the Thermaltake PSU's. Also, I dont know if modular PSU's are available in BD. Let me know if youre interested, and i can let you know of available models and their prices
    Get the HD4890 over the GTX275, since the 4890 is much cheaper than the 275 in BD. They perform about the same, some games favour the 4890 while others favour the 275. The CPU and motherboard are fine, but if that exceeds your budget, get the regular P6T and not the Deluxe version.
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    does global brand have the deluxe P6T, last time i checked they only had vanilla P6T :closedeyes:
    regarding the PSU, could u list the available models and the price....i only need 650W models, either modular or non-modular will do as long as its efficient and delivers clean power
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Antec Earthwatts 650W : 9500
    OCZ Steath Xstream 700W: 10,000
    Corsair TX650W : 10,300
    OCZ Mod Xstream 700W [Modular] : 11,500
    Enermax Pro82+ : 11,800
    Alternatively, you can buy my Corsair TX650W. Its used for one year, and will come with the manuals, documents and the carrying case. Price would be 1k less than the new one, hence 9,300
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Quote Originally Posted by Mazhar View Post
    From these OCZ stealthxtreme is the best at its price. 72amp on +12v rail!!! Plus its reviews are also good.
    U can buy Mazhar bros also. 52amp on single +12v rail!!!
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    that OCZ StealthXStream seems great for the price....now where to buy it?
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    I will buy it and be in Dhaka by 6th September. The PSU will be unopened and boxed, and you can pay and pick it up from my house. Ill PM u the address, but are u confirmed?
    |THIS| is the exact PSU that i mentioned.
    The Mod Xstream is the modular version of this PSU. Let me know if u want that
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    darn....i was hoping to buy it within saturday...sept 6th is a bit late
    wont be in Dhaka for the next 2 weeks :S
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Let me know by today if you need it or not
    Sept 6th is a little more than a week later.
    edit: Its ok if you want to buy it 2 weeks later as well, as long as its before the 17th of sept. Let me know
    @Mazhar bhai is helping us a lot...
    Thank you brother or being with us....
    • Dissent's Gadgets
      • Asus P6T
      • Intel i7-920
      • A-Data DDR3 6GB
      • XFX HD 4890
      • Asus VH222D
      • Asus Xonar DX
      • A4Tech Generic
      • Logitech MX 518
      • Samsung
      • None atm
      • 62 KiB
      • 16 KiB
    Dissent's Avatar
    thank u guys for helping me out....i've got all the parts and just have to assemble
    thx mazhar bhai for ur co-operation
    and also sorry for not being able to wait till next week :S
    unless they introduce PoP/Mirror Edge styles with lara croft in bikini (gfx on par or better than AniMatrix), this game is hopeless =,='
    Happy rig building bro....
    Let us know the final result.....
  1. FreeRapid Downloader 0.83 Build 451 [1 link]
    By sadi_warhead in forum Software
    Last Post: August 17th, 2009, 21:11
  2. Windows 7 RC1 Build 7100 (leaked)
    By coldfire7 in forum Software
    Last Post: June 19th, 2009, 00:12
  3. i need IDM 5.15 Build 6
    By CHR.Satiator in forum Software
    Last Post: February 25th, 2009, 03:56
  4. Internet Download MAnager 5.15 build 5
    By Codex in forum Software
    Last Post: December 27th, 2008, 13:42
  5. Internet Download Manager v5.14 build 5
    Last Post: September 26th, 2008, 13:12
Page generated in 0.27061 seconds with 14 queries.
