Thread: Will a Delux Delux DLP-34A power supply support a GTX 550ti?
    Question Will a Delux Delux DLP-34A power supply support a GTX 550ti?
    Can you please tell me if its safe to run a GTX 550 Ti off a Delux DLP-34A( Delux 450 watt ones that come with their server cases). Im running an Intel E7500 with two HDDs and the usual other components. I dont have any extra pci cards running and all my case fans are powered from a separate source(hudai, but i feel it puts less strain on my aging psu....).
    Quote Originally Posted by rabjohn View Post
    if the psu is quite old then it will be a bit tight for your setup. by tight i meant risky. I am guessing a reliable power output range of 240 to 260watt from the 12V rail or even lower. sticker spec is pretty much useless fyi. But if u r a casual gamer or have A/C in your room u just might be able to get away.
    If u intend to keep this psu, open up the psu and clean all the dust with a blower. that helps it to get rid of excess heat. sometimes psu manufacturer mentions actual wattage in the pcb. u should be able to find it if u have the patience.
    The PSU has been running for 3 years. And yes, I did just clean the dust in the psu and all other components, a few a days ago. Ended up creating a sandstorm in my room.. Ill see if i can find any mention of watts or amps on the pcb. thanks
    Do you think it will be able to handle a HD7770?
    HD 7770 requires less power than GTX 550 Ti . You should be able to run it fine but if possible buy a new PSU just to make sure you have good headroom in terms of power output from the psu.
    Thanks. Ill try to score a 7770 then. Im saving up for a psu.
    Apr 2013
    If it has any 6pin pcie cable, it can run gtx... My students run hd6770(108w) on that PSU .. Gtzx550 is 116w
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by Dna Mex View Post
    550ti's tdp is underrated. Its somewhat near 140w in real life. You'll find a tons of discussions about Fermi'r tdp in the old threads
    Quote Originally Posted by Reznov View Post
    That is what i read as well. Wont risk it with a 550Ti then. Do you think running a HD 7770 off this psu will be safe?
  1. Replies: 10
    Last Post: March 31st, 2013, 20:08
  2. can a delux DLP-388A power supply handle a 5670.
    By @bhi in forum Help - PC Buying
    Last Post: June 7th, 2011, 14:55
  3. Replies: 21
  4. Closed Delux ATX 450W Power Supply
    By rafaat in forum Shop - Gadgets
    Last Post: September 22nd, 2010, 11:20
  5. Help about Delux 450 W PSU?
    By AmareX in forum Others PC Hardware
    Last Post: February 13th, 2009, 14:52
Page generated in 0.20825 seconds with 14 queries.
