Thread: External TV card problem
    • s.a_rocky's Gadgets
      • Gigabyte 970 A- DS3p
      • AMD PHENOM II X6 2.8Ghz [6Cores]
      • 4GB + 4GB +8GB TWINMOS 1600M DDR3
      • 1TB WD EZEX +1TB WD EZEX + 750GB Hitachi
      • Sapphire Radeon R7 260x OC 2GB DDR5
      • Dell FHD 22"
      • Built-in REALTECH HD
      • Delux DLX X501: 60W 2:1
      • A4tech A-Shaped Multimedia
      • NewMan 5x
      • Micro Kingdom Xbox Like Dualshok Gamepad
      • Thermaltech Lite Power 450W
      • Asus DVD RW 24X/Hp DVD rw
      • USB MULTI HUB+ Apacher 32GB USB 3 Flash Drive
      • PCPOWER 1200VA
      • Windows 10 Pro X64Bit
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Default External TV card problem
    i got a tv card from my friend for few days. i connected it with my LCD.
    the LCD is 19" pure wide.
    the problem is. when i tune channels it show every channel and tunes everything. But when i get to check them the channels gone DARK. the Audio is on but theres nothing to see. exept few channels comes up. and all other are only AUDIO. sometimes they shows up and disappear.
    ANy Cure to this problem?
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Quote Originally Posted by San_sa_rocky View Post
    May be Ur TV card not support LCD Monitor or some HW problem ..
      • Asus P5K PRO
      • Intel Q8400 OC @ 3.66 w/ Xigmatek Dark Knight
      • Transcend 2*2gb DDR2 OC @ 901Mhz
      • Samsung 500GB F1 + 1TB F3 HDD
      • Sapphire Radeon HD5850 1GB GDDR5 OC @ 850/1200
      • Samsung SyncMaster T200 20" LCD (1680*1050)
      • Realtek ALC 883, 8 -Channel High-Definition Audio
      • Altec Lansing VS4121 - 2.1 / SteelSeries Siberia
      • A4tech Multimedia KBS-8
      • SteelSeries Xai w/ SteelSeries QCK Heavy
      • Logic USB Dual Shock
      • Thermaltake TR2 500w w/ Thermaltake M5 Casing
      • Asus SATA 18xMax DR
      • Canon Pixma ip1000 (printer) | Transceed 8gb Pendive
      • N/A Sad Case T_T
      • Windows 7 RTM 64Bit
      • 3DMarkVantage (P 15427) (GPU 16717) (CPU 12528)
      • <3 iT !
      • Dhaka Fiber Net & ISpros
      • 512kbps
      • 256kbps
    SHTN's Avatar
    Kallyanpur
    Default Re: External TV card problem
    Oi amr o ekta problem ase ...
    Tv card : Avermedia Joy External
    Monitor: Samsung T200
    Problem :: Monitor shows "Not optimum mode" in the middle of screen jeta auto adjustment dile chole jai but abr ektu por ashe... Tv card e kono option pai nai so set resolution .. My tv card may not support LCD or high resolution monitors but specification e show kore it does SUPPORT LCD!! PLZ HELP!! -_-"
    ~It is better to keep your mouth shut and let people think you are stupid than to open it and remove all doubt.
  1. Best external TV Tuner for Xbox 360
    By H.O.S in forum XBOX
    Last Post: October 19th, 2010, 03:35
  2. Want to Buy External TV Card
    By SHTN in forum Shop - Gadgets
    Last Post: June 20th, 2009, 06:54
  3. Tv Card problem
    By outragedhuman in forum Others PC Hardware
    Last Post: April 19th, 2009, 02:40
  4. Replies: 1
    Last Post: February 1st, 2009, 16:34
  5. Replies: 0
    Last Post: February 1st, 2009, 16:15
Page generated in 0.16368 seconds with 14 queries.
