Results 1 to 20 of 20
Thread: Help regarding Primo H2
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    Lightbulb Help regarding Primo H2
    Recently i bought the Walton Primo H2. Its serving me well. But i wanna update the driver, so went to the walton forum where they showed a description about driver installation.HERE.
    The problem is "MT65xx preloader" doesn't show up in the "Other devices" submenu.So i can't continue the installation process.
    Guyz help me out a bit, im in a real fix.
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    try again...if cant find you could post this in "android kothon" group of fb.. @maheer.dhruba
    • Robin Rayhan's Gadgets
      • Gigabyte B85-D3H
      • Intel Core i5 4570
      • Avexir 8GB DDR3 1600MHz
      • 120 + 240 GB ADATA SSD
      • (N/A)
      • AOC 20 INCH LED 1600x900
      • WinnerIT 3.5Mbps
      • 200-500 KB/s International | 12Mbps Local
    Robin Rayhan's Avatar
    Dec 2011
    Quote Originally Posted by maheer.dhruba View Post
    MTK Preloader doesn't show up? When you connect the phone is there a notification saying USB device installing then the installation fails? Or does that not happen at all? If it doesn't happen at all, try a different data cable. If same result, check with other USB ports of your computer. If nothing changes, then send your phone to RMA since it might have a micro USB input port problem. And if the driver installation is failing then don't worry. Its perfectly normal. You have to install the driver manually. By going to device manager > right click to properties > update driver > select folder which is called driver. My G1 updated on first try.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    Quote Originally Posted by rrayhan77 View Post
    ur first assumption is right...driver installation failed at my first attempt..but when i downloaded the firmware nd driver..nd wanted to install manually..my device manager shows "MT 65xx" at other devices for about 5-6 seconds..then it disappears..so manually update diteo partesi na...
    No android user here to help me???
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Intel Core i7 4770K @ 3.5GHz
      • 2 x 4096 MB Apogee DDR3 @1333 MHz
      • Crucial M4 64GB, 1TB Hitachi HDD
      • XFX Radeon HD 4830
      • Philips 190CW Brilliance
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Thermaltake TR2-RX 450W
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    Try enabling USB Debugging. Then Shut Down your phone and connect it to PC. It should work. If it doesn't, then there might be a problem with the connection between Your PC to Mobile or the Mobile itself.
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    Right, good thing that your phone is ok. Are you trying it with it turned on and with battery? Its supposed to be off and with no battery. Then try it on another USB port. Update the driver manually. There is a folder called driver in the "H2-firmware" folder that you downloaded from Walton site. Selecting the folder is enough even thought when you double click the folder might be empty. But it will still update the driver, because the computer auto detects the files. You just need to select the folder. After installation, it should show "MTK Android Phone" installed.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    @Buddy ...usb debugging is switched on...
    ya i tried with both switchd on and off(with the battery inside)...lets see what happens when i remove the battery...
    @rrayhan77 ...Nope...MT 65xx shows all right(the MT65xx in the other device section disappears nd appears again in 2sec)...but the computer doesnt detect any drivers at all...
    HELP!!!!
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    HELP!!!!
    Very weird issue. But I am guessing something is up with your PC. Try it on a friends PC. See if the same thing remains.
    HELP!!!!
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    @rrayhan77 ....oh yeah...one thing...i downloaded a driver with same device ID as my H2 frm driver identifier.com...it was installed...but the problem of "constant disappearance of driver after 2-3sec" still remains...wat to do????
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    Its better to use the driver that Walton provided, since, they tested it. Even though you might use the same MTK 6577 driver, it might not work. The issue seems like, its of your PC. Doesn't seem like your phone is at fault. Try a different DATA cable on a different PC.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    alr8...will try it on a diffrnt pc..thnx fr the help man...
    P.S.=I Will be disturbing u more if that doesn't work out..hope u dont mind..
    i am also facing the same problem......................let me know if there are any solutions
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    Remove your Battery. Connect Phone to PC. Now it should work.
    i removed the battery and connect phone to pc.......but the problem still exists
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    sakib2212 You should probably check with customer service. It could be a hardware fault.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    @Buddy ....dhakae oder customer service ta kothae???
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    maheer.dhruba
    Walton Central Service Management System
    224/B, Khilgaon Chowdhury Para,
    Khilgaon, Dhaka 1219.
    Phone : +88-02-7213293, 7215313.
    E-mail : [email protected]
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    thanks @Buddy ...
    btw B.city te ora kaj korte parbe???
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    maheer.dhruba
    They should, if it is a small problem.
    But if the problem is not repairable by them, then they will send it to Walton Servicing Center.
    You should try B.City first. It might save your time.
  1. Symphony W70 or Walton Primo G1?
    By Robin Rayhan in forum Help - General Shopping
    Last Post: September 6th, 2013, 02:35
  2. Want to Buy WTB : Samsung Galaxy Note II and Walton Primo (ICS)
    By Robin Rayhan in forum Shop - Gadgets
    Last Post: July 12th, 2013, 20:13
  3. Walton Primo G1 - First impression
    Last Post: June 21st, 2013, 21:06
  4. Micromax Canvas HD or Walton Primo X1
    By Zimmer™ in forum Help - General Shopping
    Last Post: June 11th, 2013, 01:44
  5. Want to Buy WTB : Walton Primo F1/G1/R1
    Last Post: March 30th, 2013, 18:48
Page generated in 0.30187 seconds with 14 queries.
