Results 1 to 19 of 19
Thread: Formatting PEN DRIVE/USB FLASH DRIVE
    • s.a_rocky's Gadgets
      • Gigabyte 970 A- DS3p
      • AMD PHENOM II X6 2.8Ghz [6Cores]
      • 4GB + 4GB +8GB TWINMOS 1600M DDR3
      • 1TB WD EZEX +1TB WD EZEX + 750GB Hitachi
      • Sapphire Radeon R7 260x OC 2GB DDR5
      • Dell FHD 22"
      • Built-in REALTECH HD
      • Delux DLX X501: 60W 2:1
      • A4tech A-Shaped Multimedia
      • NewMan 5x
      • Micro Kingdom Xbox Like Dualshok Gamepad
      • Thermaltech Lite Power 450W
      • Asus DVD RW 24X/Hp DVD rw
      • USB MULTI HUB+ Apacher 32GB USB 3 Flash Drive
      • PCPOWER 1200VA
      • Windows 10 Pro X64Bit
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Default Formatting PEN DRIVE/USB FLASH DRIVE
    Friends i am using win 7.
    u may notice that you can format NTFS your pen derive in WIN VISTA & WIN 7.
    what i do is
    and i have
    Default Re: Formatting PEN DRIVE/USB FLASH DRIVE
    wow...what pendrive is that bro???
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    speed to amar HDD o day na
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    an USB 1 device can achieve max 1.5MBps
    and USB 2.0 device 60MBps.
    in reality, USB 2.0 can't achieve more than 40MBps.
    unless you are using USB 3.0, it's surely windows' miscalculation.
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    its 95% accurate. and i noticed u are using windows xp sp2. and i am using windows 7.
    windows vista/7 has this NTFS FEATURE added.
    weather u can use alternate way to format penderive @ntfs @ XP.
    i used NFTS & 64 KB allocation unite.
    ---------- Post added at 21:35 ---------- Previous post was at 21:34 ----------
    its PATRIOT MEMORY. 4GB
    ---------- Post added at 21:36 ---------- Previous post was at 21:35 ----------
    Quote Originally Posted by MiG^SyeD_SuNnY View Post
    carfully look at the first picture.
    the allocation size is 64KB
    thats the main point.
    and HDD new format korle ALLOCATION 64KB the chane kore deo dekhaba result ki hoi.
    bro can u check...what speeds u get with TeraCopy
    http://www.codesector.com/teracopy.php
    it boosts my speeds...but nothing like those that u v shown
    bro...what pendriver did u use???
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    i do use PATRIOT MEMORY. 4GB. its USA manufactured. bought it from IDB
    Quote Originally Posted by San_sa_rocky View Post
    how much did it cost bro???
    my Transcend 4GB is too slow....4-6MB/s...I mean it's too slow
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    so you are telling me that by using windows vista/7, you can break usb 2.0's PHYSICAL limitations?
    btw, just go to your usb drives properties > hardware > properties > policies > enable optimize for performance.
    then you can format using NTFS.
    or you can try
    format X: /FS:NTFS /Q
    where x is your usb drive.
    I used ntfs usb pen drives even before vista came out. it's nice. but when you have to
    plugin it on Domain Controlled Computers (like the ones in university), it is a PITA.
    ofc, larger allocation unit size is better for usb based devices (performance wise at the cost of space).
    but exceeding physical limitations?
    or you can try
    miscalculation perhaps...but he timed it with a stopwatch
    • cRush's Gadgets
      • Abit IP35P
      • Core 2 Quad Q6600 2.4Ghz (Oc @ 3.11Ghz ) 2*4MB Cache
      • 2*2GB Transcend DDR2 Ram @800Mhz (Oc @840 Mhz)
      • 320GB Hitachi HDD + 500 GB Samsung F3 HDD
      • Palit GTX560 Ti Sonic 1GB
      • Samsung SyncMaster932B 19" LCD Monitor
      • RealTek HD 7.1 Soundcard
      • A4Tech Headphones+ Creative 5:1 Surround Sound
      • A4Tech Anti-RSI Keyboard
      • Genius G500 Laser 2500dpi
      • Sony Sixaxis
      • ThermalTek 420W
      • Asus SATA DVDRW drive + Asus IDE DVD-combo Drive
      • Windows 7 RTM 64Bit
      • IT RAWKS :D
      • Local (STAR ISP)
      • 32 - 40
      • 40 - 60
      • 144
    cRush's Avatar
    95% accurate ? :S Where exactly did you get that probability ? Stop throwing around random percentages NTFS format can be done is WinXP sp2 too. And the performance gain is not what you are seeing in the dialog. Did you notice that It starts copying really fast but slows down at the end ? Figure out why it does that
    Thumbs down Re: Formatting PEN DRIVE/USB FLASH DRIVE
    miscalculation perhaps...but her timed it with a stopwatch
    Simply impossible.USB 2.0 Can't break the speed barrier at 60.00MB/s
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    Quote Originally Posted by Wintereise View Post
    and that's theoretical. practically, 40MBps is natural.
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Quote Originally Posted by [TH7][cRu$h] View Post
    when i sent that file to pendrive. it sent in 7 sec
    the file was 349MB
    so its avg was 49 MB
    and did i said 75MB was always?
    hmm i think i should mention the speed first. the screen shot was taken when it was sending.
    now time it in Xp with same allocation size
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    it doesnt matter of trancend or manufacturer.
    you should try the steps.
    when formatting ur pen drive follow the steps of the first picture. that will increase ur speed up.
    or if u use xp follow CvP's rules.
    or you can try
    and mine took 750 tk
    allocation unit size komale ki speed barbe...karon amr allocation unit size always default e deoya thake
    ishh...Transcender ta na kinlei partam
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    komale na barale
    default thake 4 K er moto
    but tumi 64K porjonto allocate korte paro using NTFS
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    im going to post this again:
    btw, allocation unit size is cluster size. in other words, this is minimum PHYSICAL file size.
    setting allocation size 64KB means if you have <64KB files,
    it will take 64KB space anyways (yes, even 1kb file will take 64KB space).
    but this also means less writing in the MFT and journals per file. thus, a speed gain (but not too much).
  1. Can not find drive in windows 7
    By WoH[AMON]~Lord SMS in forum Technical Support
    Last Post: June 9th, 2009, 18:55
  2. Replies: 1
    Last Post: May 19th, 2009, 22:18
  3. Test Drive Unlimited
    By Asif in forum Racing
    Last Post: May 17th, 2009, 14:32
  4. game in same drive
    By йЦммєя³¹ in forum Gaming Topics
    Last Post: April 21st, 2009, 01:21
  5. Buying a new DVD drive need advice
    By TAHMID in forum Technical Support
    Last Post: March 12th, 2009, 22:46
Page generated in 0.32282 seconds with 14 queries.
