Results 1 to 6 of 6
Thread: best way to clean glass screen of a monitor
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    Default best way to clean glass screen of a monitor
    does anyone know any way to clean a glass monitor screen without leaving any scratch or spot?
    if its glass, you can safely use mr. Brasso. But if it is an LCD/LED, you should use pure water with a soft cloth (no tissue paper.) you may mix some vinegar in water if you want. Only water is enough in most cases.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    its a glass led screen. Water generally leaves spot isnt it. Sometimes i use hexisol but that also leaves spot.
    shoe polish দিয়া মুছেন monitor চক চক করবে।
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    Quote Originally Posted by blood stain child View Post
    lol ha ha ha
    • Ustad's Gadgets
      • Biostar TA990FXE
      • AMD Phenom II X6 1055T 2.80Ghz. Running on 3.50~4.0Ghz. Cooled by CM Hyper 212EVO Push/Pull
      • Corsair Dominator 4*4GB 1866Mhz CL9. Running on 2000Mhz CL9
      • Samsung 320GB SATA II
      • XFX HD5850 Black Edition cooled by Zalman CNPS5X Performa
      • Fujitsu 18.5 inch
      • On-Board
      • Altec Lansing ACS 45.1 and Creative Gigaworks T20. JVC HA RX-300
      • A4tech KR-83 (Custom)
      • Razer Lachesis 3G 4000dpi, E-Blue Cobra Jr
      • Gigabyte Superb E720
      • pqi 8GB 2.0, Transcend 4GB 2.0, Twinmos 4GB 2.0
      • Microsoft Windows 7 (64-Bit) SP-01
      • I am Happy!! Always work in progress...
      • BanglaLion
      • 62KB/s
      • 6-8KB/s
    Ustad's Avatar
    Jun 2010
    I use body lotion on my case side panel plexi. Works nice! You could try that. And it also works as a shiner too. I usually use it wiping my matte surfaced monitor display panel. Works like a charm!
    Another day inside my world.
    I'm married to you and this road.
    A road that never let's me sleep.
    There's no way to escape these demons I am forced to keep...
  1. How to clean LCD screen?
    By Extreme Noob in forum Technical Support
    Last Post: January 15th, 2012, 23:18
  2. Replies: 0
    Last Post: November 2nd, 2011, 18:15
  3. 3d Glass Buying Help
    By Arman_360 in forum Help - PC Buying
    Last Post: November 2nd, 2011, 01:06
  4. 3d glass buying help
    By TaherTheRetard in forum Help - General Shopping
    Last Post: October 5th, 2011, 16:26
  5. Closed Samsung SyncMaster 753DFX White 17" CRT Monitor Flat Screen
    By Codename-Scorpion in forum Shop - Gadgets
    Last Post: March 31st, 2010, 08:18
Page generated in 0.18400 seconds with 14 queries.
