Results 1 to 8 of 8
Thread: Need advice about a new power supply.
    • Xero Fatal1ty's Gadgets
      • ASUS ROG Strix B250F
      • Intel Pentium G4620 (Kaby Lake)
      • Corsair Vengeance LPX 8GB DDR4 2400Mhz Single-Channel
      • 2x Western Digital Caviar Blue 1TB
      • Sapphire Radeon RX 580 8GB Nitro+ Limited Edition
      • Samsung SyncMaster 2433LW (23.6inch 1080p)
      • SupremeFX (S1220A)
      • Creative Inspire T6200 5.1 and SOL Republic Tracks HD
      • Logitech MK250 (Wireless)
      • Logitech B100
      • Logitech Dual Action
      • Antec NeoEco 550M Semi-Modular
      • Windows 10 Home x64
      • Triangle
    Xero Fatal1ty's Avatar
    CBA
    Default Need advice about a new power supply.
    Hi guys.I'm recently thinking of buying a good power supply.Something that is reliable and optimal for my pc spec.I was wondering if someone could help me advising any good power supply around.My Budget shouldn't exceed 4k.I was thinking of Thermaltake Lite Power 400W one .If you have any alternatives to that, please help me here with price and product details.Thank you.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Default Re: Need advice about a new power supply.
    within ur budget TT 400W lite power is the only one
    second will be asus 500W costing around 4.5k
    if u can find delux 500W then it would be within ur budget
    but it's hard to get
    other like Valuetop, Fortex or FEEL will exceed the budget
      • Logitech B100
      • Triangle
    CBA
    Could you please specify the model number of Asus one? I think i can spend another 500 bucks if it's worth it
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by Xero-Fatal1ty View Post
    here u go man: http://usa.asus.com/products.aspx?l1...11&modelmenu=1
    everything about the product is above in the link
    by the way i heard it wasn't in stock
    u better check before getting ur hopes up
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    go for asus 500w
    without getting into too much technical details...simply go for a particular brand
    Thermaltake(except lite power 400) / Delux 500 watt (model DLP-50A with active PFC) costs 3600 taka gives out 300 watt in real.
    Asus will be certainly better if u can afford.
    Ur total system watt will never ever exceed 290 watt if u dun overclock dat is. (monitor dosent count).
    personally i prefer the 2nd brand (delux) for its good price/perfromance ratio.
    hope i helped.
    • Muradd9's Gadgets
      • Msi B75MA-P45
      • Core i5 3470
      • 8GB 1600MHz Twinmos Twister
      • WD 2TB + Toshiba 2TB +Samsung 1TB
      • Msi GTX660Ti Oc 2GB DDR5
      • Samsung P2250 21.5
      • Realtek
      • Creative I-Trigue L-3500 2.1
      • Logitech K375s
      • Logitech M235 Wireless
      • Gigabyte Superb 550P 450W
      • Asus DRW-24B3ST
      • Creative muvo TX
      • RA Luminous ion 1500va(1200W) sine-wave ips
      • Windows 10 pro
      • 9007B server case
    Muradd9's Avatar
    Bogura
    DELUX DLP 388A is ok for ur pc configaration. Price is less then 2000 Taka, May be 1500taka. No pci-e 6pin connector.
    DELUX DLP 34A 1st Recommended for ur pc configaration. Price is less then 2500taka. *note: Boxed. Pci-e 6pin connector.
    Delta GPS-300AB-xx 2nd Recommended . Price is less then 2000taka. No pci-e 6 pin connector.
    Asus P-50GA active pfc .Yes it worth. Recommended for HD4770 crossfire or HD4850 crossfire with Quad core( mild oc)+ 2HDD, 2 ODD type configaration.
    Quote Originally Posted by йЦммєя³¹ View Post
    Wrong model. Model: A-50GA +12v combined 27A , 1 pci-e power connector, OEM: AcBel Polytech
    Bangladesh e je model pawya jai oita P-50GA, +12v combined 30A , 2 pci-e power connector, OEM: Delta
      • Logitech B100
      • Triangle
    CBA
    Thank you all for your kind help.Today i spoke to Global and they said it's currently not in stock
  1. Replies: 21
  2. GPU Dedicated power supply
    By minitt in forum Others PC Hardware
    Last Post: April 14th, 2009, 19:07
  3. Sale (New) FEEL4 700watt Power Supply
    By Tian in forum Shop - Gadgets
    Last Post: March 25th, 2009, 17:33
  4. Two 700watt Power Supply for sell! HURRY UP!
    Last Post: September 10th, 2008, 01:25
  5. True Power Supply measurer Software needed
    By Tian in forum Software
    Last Post: July 6th, 2008, 04:20
Page generated in 0.21553 seconds with 14 queries.
