Results 1 to 20 of 23
Thread: Help me buying a pen drive!
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Default Help me buying a pen drive!
    bros, uv lost my pd some days ago...it was an apacer AH325 16gb pd...now uv to buy another one...what would be best in 1.2k...i want usb 3.0.
    help me..thnx
    Corsair Flash Voyager 8gb i guess
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    isnt 8 gb being lil?
    • Metal's Gadgets
      • GIGABYTE [ GA-EP43-UD3L ]
      • INTEL(R) Core(TM)2 Quad CPU Q9505 @ 2.83Ghz
      • APACER 4GB DDR2
      • SAMSUNG 750GB
      • NVDIA GeForce 9500 GT
      • Dell E178WFP
      • CREATIVE Sound Blaster 5:1
      • COSONIC CD-779MV
      • A4Tech KR-83 USB [Black]
      • A4Tech OP-620D
      • ASUS P-50GA
      • ASUS DRW 24B1ST
      • Windows 7 Ultimate
      • ISPROS Limited
    Metal's Avatar
    Feb 2012
    Chittagong
    @QuadStorm buy Transcend JetFlash®810 in one word I found the design is beautiful within budget price.
    http://www.ucc-bd.com/transcend-jetflashr810-1.html
    Power is not only what you have but what the enemy thinks you have.
    Quote Originally Posted by QuadStorm View Post
    i am not sure though its 8gb or 16gb but its write and read speed is faster than any other pen drives which are available in bangladesh till now
    Quote Originally Posted by blood stain child View Post
    --bro i want to buy a cheap 8 gb pen drive..how about Toshiba 8gb ..price 400tk..can it be reliable? if not, then which brand will be cheap & better then?
    Quote Originally Posted by [email protected] View Post
    apacer has a pendrive at 550 taka and that toshiba might be a replica so in my opinion you should avoid it unless transcend pen drives are also good
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    you sure about dat?
    you sure about dat?
    http://usb-flash-drive-review.topten...er-review.html
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    can you give me any link with price bdt
    can you give me any link providing the pricing? @blood stain child
    i cant say the proper price of it so sorry for that even computer source removed the link may be the stock is finished or may be they forgot to update it , so better you go to IDB and multiplan and search it yourself
    note that: all the corsair pendrives in the market are factory refurbished.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    now um looking at usb 3.0. coz the files are bigger now. i can get help for quicker transfers with usb 3.0.
    the model metal showed is a good model with specs...Now uv heard bad things bout transcend things.
    wad does it mean? @Vanguard
    wait, someone would answer that eventually. Because to me, typing is too mainstream......................
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    ok um gonna google it
    nope, i was wrong...transcends r good...um willing to collect a usb 3.0 16gb or 32gb.
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    I say Transcend 780 model has good reviews, but it wasn't in stock. Next choice should be the 810 model.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Sapphire HD 7950 3GB DDR5 Vapor-X || [email protected] [email protected]1750MHz [email protected]
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    so, are they reliable?
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Quote Originally Posted by giant View Post
    they are like "by chance"...sometime they are faulty...if have warranty you get em...otherwise step away as they say..dats wad i found
    Quote Originally Posted by radeef View Post
    780 is costy...i would take 810 instead..
    is there any differences between colors?
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    The only difference is between read/write speed
    for a budget/avg user transend thumb drives are not bad. kaaj chalanor jonno quite ok. Im also looking for usb pen drive preferably with steel casing and usb 3.0 pls let me know if an1 finds such.
  1. help on using R-Drive!!
    By giant in forum Technical Support
    Last Post: March 13th, 2013, 01:30
  2. Urgent help buying a hard drive
    By vergil007 in forum Help - General Shopping
    Last Post: August 21st, 2011, 22:10
  3. Sale (New) pen drive
    By chainsaw in forum Shop - Gadgets
    Last Post: March 1st, 2010, 20:00
  4. Formatting PEN DRIVE/USB FLASH DRIVE
    By s.a_rocky in forum Miscellaneous Topics
    Last Post: July 25th, 2009, 00:10
  5. Buying a new DVD drive need advice
    By TAHMID in forum Technical Support
    Last Post: March 12th, 2009, 22:46
Page generated in 0.29244 seconds with 15 queries.
