Results 1 to 12 of 12
Thread: help with IDM
    Member HAWX's Avatar
    Jul 2011
    Default help with IDM
    i installed the 6.15 version of IDM ..naturally whenever i open a link to a video a option appears like this ""Download this video""
    but now when i open a video link sometime ""Download this video"" appears and sometime doesn't .i am in a pain with problem .please help .i uninstalled and installed the program at least five times but it happens all over again
    • Single Player's Gadgets
      • Foxconn H55MXV
      • Core i3 540
      • 2+2 GB DDR3 (1333 MHz)
      • 400 GB Samsung(320+80 @ 7200RPM)
      • 1 GB HD5570 DDR3
      • Samsung 793DF
      • Realtek HD Audio | Creative Sound Blaster Live!
      • Creative 4400 4:1
      • A4Tech KRS-86 Multimedia
      • Havit HV-MS686
      • TT Lite Power W0316
      • 24x ASUS DVD RW
      • 16GB + 8GB Tanscend
      • Windows7 (x64)
      • Not gonna upgrade
      • DFN BD
      • 600-650 Kb/s
    Single Player's Avatar
    Dec 2011
    চেয়ারের উপর
    Re-installing won't help you. Are you using Firefox? If yes then it may help you -
    Click Tools >Add-ons>Click "Extensions" and check whether IDM CC 6/7.XXX is enabled or disabled. If disabled, then enable it and restart your browser.
    Jul 2011
    Quote Originally Posted by Single Player View Post
    no i am using Google chrome ..and i tried those steps many times with chrome and firefox but it doesn't help
      • Foxconn H55MXV
      • Core i3 540
      • 1 GB HD5570 DDR3
      • Samsung 793DF
      • Creative 4400 4:1
      • Havit HV-MS686
      • 24x ASUS DVD RW
      • Windows7 (x64)
      • Not gonna upgrade
      • DFN BD
      • 600-650 Kb/s
    Dec 2011
    চেয়ারের উপর
    Try updating that Extension for you Chrome/FFox from IDM official site. Do you see any message like "You have an obsolete integration...." or sth like that?
    Jul 2011
    no ..no message like that but will try to update the extension
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    reload the page...
    Jul 2011
    @giant did that so many times that i couldn't count anymore
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Intel Core i7 4770K @ 3.5GHz
      • 2 x 4096 MB Apogee DDR3 @1333 MHz
      • Crucial M4 64GB, 1TB Hitachi HDD
      • XFX Radeon HD 4830
      • Philips 190CW Brilliance
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Thermaltake TR2-RX 450W
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    Remove the IDM CC from Firefox/Chrome.
    Download new IDM CC Extension from:
    1. For Firefox: https://data.internetdownloadmanager...cc/idmmzcc.xpi
    2. For Chrome: https://chrome.google.com/webstore/d...ngancncm?hl=en
    Open a new Tab. And Drag & Drop the file into browser. It should start the installation for the extension.
    If it still doesn't work, I will help you through Teamviewer.
    Jul 2011
    now i can download from firefox but chrome has the same problem @Buddy ..now i have open firefox whenever i need to download any video
    chrome diye download korte parle valo hoto
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    Quote Originally Posted by HAWX View Post
    A. Check Settings from IDM Options
    1. For Chrome you have to enable "Use advanced browser integration" option in "Options->General" IDM dialog (arrow 1 on the image). Then check that integration into Chrome is also enabled (arrow 2 on the image).
    2. If IDM shows some error when you try to enable advanced browser integration.
    B. And Please check below image to configure IDM Integration for Chrome.
    ***Only try the option C if option A and B doesn't fix the issue.
    C. Delete the IDM CC from Chrome Extensions and Re-install it.
    IDM CC Extension for Chrome: http://www.mediafire.com/?z7pcjh1b4axcirm
    Download and paste it into:
    64 Bit Windows:
    C:\Program Files (x86)\Internet Download Manager\
    32 Bit Windows
    C:\Program Files\Internet Download Manager\
    Then follow the steps given in this image:
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    @Buddy
    thats a great job there ... thanks for taking the time nd pain to post such
    @HAWX
    ^^^^^ that
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    @genocide_cutter
    Thnx Bro. I will help people as long as I know the answer.
    And by helping people I also gather knowledge and happiness.
Page generated in 0.22900 seconds with 14 queries.
