Thread: Portable HDD te serious PROB...Need HELP
    • MWApocalypse's Gadgets
      • GIGABYTE G31M-ES2C
      • Intel Pentium Dual Core E5200 @ 3 GHz
      • Apacer 3 GB (2 GB+ 1 GB @800 BUS)
      • Samsung 320 GB
      • XFX HD4850 512 MB Standard
      • Samsung 20" widescreen LCD
      • Microlab 2:1
      • A4 Tech Multimedia
      • A4 tech
      • Thermaltake Litepower 400W
      • ASUS 24X DVD-RW
      • Windows 7 Ultimate 32-bit edition Build 7600
      • I fell in love with it...
      • Deltasoft
      • 20-35 KB/s
      • 35
    MWApocalypse's Avatar
    Shewraphara, Dhaka
    Default Portable HDD te serious PROB...Need HELP
    Vai amare pls keo help koren. 2 din hoisei amar samsung er 80 gb hdd ta pc te lagaile 3 ta drive e dhukte pari na. "J" drive e dhukte gele bole
    "J:\ is not accessible
    The file or directory is corrupt and unreadable"
    ami command prompt e giya "chkdsk j: /r" likhle lekha ute
    "The type of the file system is NTFS
    Unable to determine volume version and state. CHKDSK aborted"
    ami eta likhsi karon ageo 2 bar ei jamela hoisilo kintu tokhon chkdsk chalaiya thik korte parsilam. Kintu eibar r thik hoitesana. Gotokal amar ek bondhur bashai giya hdd ta laganur por theke ei jamela. Othocho oidin shokaleo HDD ta kaj korse khub valo vabei. Vai ami ekhon chokhe ondhokar dekhtasi, 1 bochor dhoira gaan, chobi, anime jomaiya hdd te rakhsilam ei ashai je notun pc kinle shobgulare rite korum. Vul hoise, onno karo kas theke agei rite koraiya rakha uchit chilo. Vai pls keo upai den oi file gula re recover korar. Prai 70 GB r moto file, khub koste asi. R ekta kotha jodi kuno software download korte hoi pls emon link diyen jekhan theke oi software tar full version free te dwnload dite parum. Onek kotha likhsi....kintu kuno upai jodi bair hoi sharajibon rini thakum.......tai pls help koren.
      • Samsung 970 EVO 1TB+ 830 (128GB)+2TB mech HDD
      • Evga 1080 TI Sc 11GB
      • TELUS optical
      • 75Mbps
      • 30mbps
    Default Re: Portable HDD te serious PROB...Need HELP
    U have to re partition the whole drive. but be warned dat all data will be lost.
    taking backup @ this situation is a real pain. ppl who do it usually charge somwhere around 500 taka.
    If its just a viral infection then u r safe. but if its somthin physical then ...good luck ull need it.
    • WoH[AMON]~Lord SMS's Gadgets
      • Gigabyte EP45DSELR
      • Intel Core 2 Duo E8600
      • 2 GB Transcend DDR 2 800 (for the time being)
      • Samsung 500 GB
      • Sapphire HD 4870 1 GB
      • 17" CRT Samsung
      • XBOX 360 Controller for Windows, PS2 controller with adapter
      • Thermaltake ToughPower 600 W
      • Good Enough for DotA and FIFA
      • Bracnet
    WoH[AMON]~Lord SMS's Avatar
    Buet, Dhaka, Bangladesh
    arekta reason hote pare... amar windows 7 a main hdd nia hoisilo.. drive chintesilo na... pore drive name and location identify korate kaj hoise... ei forum ei koi jano likhsi oita nia
    Some qoutes that have helped me passing the 'moments' of my life:
    1. Accept your limitations, then go beyond them.
    2. Dont think old man. Sail on this course and take it when it comes
    3. I am who i am, not what i am.
    4. Life is too short to be pissed of all the time.
    5. Theists and atheists think alike while they face the real BAD of life
    6. You can never really know a man unless you walk in his shoes.
    7. Forgive thee, who bring upon hatred on you.
      • Asus P5K PRO
      • Intel Q8400 OC @ 3.66 w/ Xigmatek Dark Knight
      • Transcend 2*2gb DDR2 OC @ 901Mhz
      • Samsung 500GB F1 + 1TB F3 HDD
      • Sapphire Radeon HD5850 1GB GDDR5 OC @ 850/1200
      • Samsung SyncMaster T200 20" LCD (1680*1050)
      • Realtek ALC 883, 8 -Channel High-Definition Audio
      • Altec Lansing VS4121 - 2.1 / SteelSeries Siberia
      • A4tech Multimedia KBS-8
      • SteelSeries Xai w/ SteelSeries QCK Heavy
      • Logic USB Dual Shock
      • Thermaltake TR2 500w w/ Thermaltake M5 Casing
      • Asus SATA 18xMax DR
      • Canon Pixma ip1000 (printer) | Transceed 8gb Pendive
      • N/A Sad Case T_T
      • Windows 7 RTM 64Bit
      • 3DMarkVantage (P 15427) (GPU 16717) (CPU 12528)
      • <3 iT !
      • Dhaka Fiber Net & ISpros
      • 512kbps
      • 256kbps
    SHTN's Avatar
    Kallyanpur
    Right click on MY COMPUTER >> MANAGE >> DISK MANAGEMENT >> and then try to format, delete drive, cr8 again .. try watever u lyk .. JUST try to cr8 a backup of ur files .. ami nijeo samsung er 80 gb portable use kortese, more than a year .. so far no problem .. gL
    ~It is better to keep your mouth shut and let people think you are stupid than to open it and remove all doubt.
  1. portable HDD
    By йЦммєя in forum Technical Support
    Last Post: June 8th, 2009, 14:35
  2. KIS Prob
    Last Post: May 17th, 2009, 18:37
  3. Want to Buy want to buy a portable hdd
    Last Post: January 9th, 2009, 21:23
  4. 1.3 Lan PROB
    By Ic3_STrik3R in forum Older NFS Games
    Last Post: September 17th, 2008, 18:12
Page generated in 0.17696 seconds with 14 queries.
