Results 1 to 16 of 16
Thread: HELP! - PSU for HD4670?
    Exclamation HELP! - PSU for HD4670?
    Guys, need ur help badly. Notun Sapphire HD 4670 kinlam, ekhon khali PC off hoye jay while playing games . Plz recommend me a power supply for my PC. I used the power calculator thingy but cudnt solely rely on that. So plz help...
    Amar PCr current config motamuti ei:
    Mainboard: ASUS P5K-V
    Processor: Pentium D 3.0 GHz
    RAM: 2x1024 MB
    Hard Drive :250 GB SATA
    Graphics Card: Sapphire Radeon 4670
    Display: AMSUNG 17" LCD
    Optical drive :ASUS DVDRW, LiteOn DVD-ROM
    Are there any PSUs available under Tk 2000 to run my PC? Amar current generic PSU e lekha 500W(!) :S
    Default Re: HELP! - PSU for HD4670?
    Guess you can get the tk1200 delux psu's. My friend had a generic psu and that fried along with the card after it was connected.
    • cRush's Gadgets
      • Abit IP35P
      • Core 2 Quad Q6600 2.4Ghz (Oc @ 3.11Ghz ) 2*4MB Cache
      • 2*2GB Transcend DDR2 Ram @800Mhz (Oc @840 Mhz)
      • 320GB Hitachi HDD + 500 GB Samsung F3 HDD
      • Palit GTX560 Ti Sonic 1GB
      • Samsung SyncMaster932B 19" LCD Monitor
      • RealTek HD 7.1 Soundcard
      • A4Tech Headphones+ Creative 5:1 Surround Sound
      • A4Tech Anti-RSI Keyboard
      • Genius G500 Laser 2500dpi
      • Sony Sixaxis
      • ThermalTek 420W
      • Asus SATA DVDRW drive + Asus IDE DVD-combo Drive
      • Windows 7 RTM 64Bit
      • IT RAWKS :D
      • Local (STAR ISP)
      • 32 - 40
      • 40 - 60
      • 144
    cRush's Avatar
    Your psu should be enough to cope with it. but my guess is that your generic psu isnt really outputting 350w or above... Not sure about PSU under 2000 taka. but PSUs inside Delux Casings should be enough for this. See if you can buy one of them separately. they should be cheap.
    edit: looks like aayman beat me to it sucks for your friend though... xD
    ajkei DELUX er 3000 takar casing ta dekhsi. otay ki cholbe? i was planning to change my casing anyway, tahole otai kintam...
    notun card kine ekhon game khelte partesina, kemon je lagtese... kalkei kinbo PSU/casing, so plz help me out!
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    A 400 Watt PSU is recommended by AMD so any good 400W PSU will be OK.. So I think a Delta 400W or a Deluxe 400W will be just fine..
    Quote Originally Posted by [TH7][coldfire7] View Post
    Delta/Deluxe 400W separate PSU er price koto? Ar jodi oi deluxe 3000 takar er casing ta kini tahole ki otar PSU diei cholbe? naki abar 400W alada kinte hobe?
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    I'm not sure about Delta er PSU's price.. ar Deluxe er casing er shate jodi 400W PSU thake then that'll be fine.
    I'm not sure about Delta er PSU's price.. ar Deluxe er casing er shate jodi 400W PSU thake the that'll be fine.
    thnx man... oitay 400W PSU i ase as fas as i remember, kalke kine felbo tahole.
    Let's see if it works or not...
    Quote Originally Posted by dhUro View Post
    Dont think that 3K delux casing will come with a good 400 watt psu. Ask me why????
    caz now a days delux 3k casing dosent come with a good 400 watt psu like before. It comes with a much
    cheap quality psu now. The last time( 3 months bak) i bought a delux casing came with a original 400 watt
    psu.... ( i had to roam around whole IDB for that).Cannot recall the name but i can remeber its the one
    beside Rishit computers. Your best bet is to go for Thermaltake lite power 400 watt/delux 500 watt with
    active PFC(3600-3800) .... both of em will do for ur setup...but i prefer the later one. using it myself.
    good luck.
    ur total watt (max) req should be roughly within 280watt
    good luck.
    how do u differentiate between good quality PSU from the bad ones? mane ami kivabe bujhbo ashol Delux psu konta? ar je psu gular nam bollen ogular dam kemon hobe?
    • HeLL]deathknight's Gadgets
      • Gigabyte HA-65-UD3H-B3
      • Core i5 2.91 Ghz Gen-2
      • Twinmoss DDR3 1333mhz 4GB
      • Samsung 500GB
      • ASUS GTX550 Ti
      • Philips CRT 17inch
      • Realtek HD 7.1 Channel,SteelSeries
      • Suntec Headphones/SteelSeries Siberia V2
      • A4Tech Slim Black
      • SteelSeries Sensei
      • Gigabyte 550Watt
      • Windows 7
      • Enough for me !
      • FusionBD/Link3 Technologies
      • 120KBps/196KBps
      • 50KBps/200KBps
    HeLL]deathknight's Avatar
    hey i bought the delux case.my old 6800XT had power probs,but akhon with everything my GPU runs just fine
    Quote Originally Posted by deathknight View Post
    kintu HD 4670 to mone hoy 6800 er cheye beshi power khay... :S
    original ones usually comes with a bottom mounted 120 mm fan and much heavier compared to cheap 1
    ....read my post properly. i mentioned the price over there already.
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    আমার ফ্রেন্ডকে ৪৬৭০ কিনে দিলাম, জেনেরিক ৪০০ওয়াট পিএসইউ দিয়ে সুন্দর চলতেসে
    ডিলাক্সএর ৪০০/৪২০/৪৫০ওয়াট দিয়েও চলার কথা, নরম্যালের চেয়ে ভাল সেগুলো..
    I bleed red, Man Utd 4ever..
    at max 75W from the pci-e slot of the mobo...& that u'd be at peak loads since the 4670s dont require additional pci-e power from the PSU
    now u do the math
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    get the Delux dlp34 450w . if dont see in market get the thermaltake light power 400w.
    i run 9600GSo, HD 4850 on that psu. so get that gpu & play the game.
  1. Sale (Used) HIS IceQ HD4670 512MB
    By dipanzan in forum Shop - Gadgets
    Last Post: July 14th, 2009, 10:38
Page generated in 0.27404 seconds with 14 queries.
