Results 1 to 12 of 12
Thread: Need help with a torrent:it's stuck!!:'(:'(
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default Need help with a torrent:it's stuck!!:'(:'(
    I was dling me1.(3.96gb).using [email protected]% it stopped progressing.but still it's downloading data.dled 50mb+ but even the progress bar didn't increase a little.bitcomet made the file xtension .bc! .so i can't even dl it with another client.please advice ASAP
    @SadmanBD
    @blood stain child
    Thats horrible indeed, first of all stop your download from bitcomet and now open utorrent and the tracker file (the torrent file from where the download starts) and then set the location where bitcomet downloaded and now right click and tick on force to check , if this doesnt work then give me the link i will download it myself and after i finish you can come at my place with a pen drive and take the file
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by blood stain child View Post
    i could do that but that dumbass bitcomet changes the extension of the files to .bc! Something like this"data.bin.bc!"that's why utorret/tixati can't find it.is there any other way?
    try this not sure though http://filetonic.com/file-extension/results/bc!
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Download cholte thakuk. Hash mismatch hoise prolly so 50mb download holeo progress bar bare nai. R onno torrent client use korte chaile file rename kore .bc! extension ta delete korlei hobe, then force recheck dite hobe.
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by SadmanBD View Post
    r u sure about this?
    Member HAWX's Avatar
    Jul 2011
    it worked for me once ..try it and see the result ..if it doesn't work then change the extension to the previous one ..and what do you use for torrent ???bittorrent or utorrent???
    if you use utorrent this might help you
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Bit torrent e ami speed e pai na.tixati ar bit comet e mutamuti pai.shobcheye best konta?
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Settings tweak kore nilei hoi, sob e same at least for me.
    • hasan_1223's Gadgets
      • intel DG41RQ__
      • intel core 2 quad Q8200
      • 2*2GB=4GB
      • samsung 500GB SATA
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Micro Kingdom 670S
      • Samsund DVD-RW
      • Appolo 800VA
      • windows XP SP2 / Backtrack 5r3
      • Uttara cable Network
      • 23
    hasan_1223's Avatar
    Oct 2012
    check that torrent tracker, does it has any has seed?
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Just completed the dl.one ot question:why tixati only finds russian seed?or its kickass torrent?
    it is the port which actually prefaring the russian peer, like for my side everytime i get better speed from indian and usa peer when i download from kat.ph or tpb and for utorrent settings, i will give you that tomorrow
  1. Stuck at 800MHz
    By Flame in forum Technical Support
    Last Post: May 22nd, 2012, 19:31
  2. Help:got stuck somewhere in black ops
    By Source code in forum Gaming Topics
    Last Post: November 2nd, 2011, 19:15
  3. Stuck in a Puzzle!! Can anyone help me in solving it?
    By adnan.alvee in forum Miscellaneous Topics
    Last Post: August 9th, 2011, 21:42
  4. Stuck In Metro 2033
    By Hamilton in forum FPS
    Last Post: June 5th, 2010, 17:06
  5. my DVD rom is stuck
    By Mad Monk in forum Technical Support
    Last Post: June 5th, 2009, 13:01
Page generated in 0.23804 seconds with 14 queries.
