Results 1 to 18 of 18
Thread: COD 4 Offline LAN multilplayer help !
    • Menace Slinger's Gadgets
      • Gigabyte B75
      • Intel Core i5 3470
      • Twinmos 2 X 4GB 1600 mhz
      • WD 2 X 1 TB + Hitachi 1 TB + Samsung 320 GB
      • Nvidia GeForce GTX 650
      • Samsung LED 18.5 Inch X 2
      • M-Audio Fast track
      • Just Beats ( Beats by Dr. Dre)
      • A4 Tech KD 800L
      • Logitech B100
      • Generic USB Gamepad
      • Thermaltake Litepower 450 WT
      • SAMSUNG
      • Audio technica AT 2020 Microphone
      • Ideal 5308B 800VA 7Ah
      • Windows 7 Ultimate
      • Casing : InWin MANA 136
      • Earth Telecommunication
      • 4 MB
      • 4 MB
    Menace Slinger's Avatar
    Jan 2013
    Question COD 4 Offline LAN multilplayer help !
    Hi,
    I want to make a offline multiplayer connection between my two PCS. I have set up the network with a crossover cable and it is running fine. Googling did not help me much :/ Does anyone have any tutorial ?
    • areek's Gadgets
      • ASRock Z87 Extreme4
      • Intel Core i5-4670k CPU 3.4GHz
      • G.SKILL Ripjaw DDR3 1600MHz 2x4gb
      • Corsair Force LX 256gb + 500gb WD caviar green + 2TB WD caviar green + Kingston 500gb USB
      • Gigabyte ATI Radeon R9 280X Windforce 3X
      • Dell S2240L
      • Altec Lansing 2.1 speakers|| HIFIMAN HE400
      • Razer Blackwidow Ultimate Dragon Age II edition
      • Logitech G402 on QCK+ NaVi Splash
      • logitech drivefx axial feedback wheel
      • Thermaltake Toughpower gold 750W
      • Asus 24B1ST
      • Samsung ML-1666 laser printer, CanoScan Lide 25
      • yes
      • Windows 7 Ultimate SP1 64-bit
    বাংলাগেমার.কম
    Quote Originally Posted by Menace Slinger View Post
    Hi,
    I am not sure about this, but afaik the pc's need to be assigned ip's for that. I guess that is why you need a router. Then you gotta host from one server & join in from the other. You should be able to find the server under local tag.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Quote Originally Posted by areek View Post
    I have succesfully started a new server in my host pc and found it form the other. But the problem is that a console comes up and nothing happens. Do I need to write any command on colsole ? Any ideas ?
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    did you set the IP address of the two pc....
    i am also trying to connect two PCs with Cat-6 cable(for both game and internet sharing)....so i'm also trying to figure out.....
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    console comes up? You mean the COD4 console? give a screenshot.
    first of all make sure ur pc is connected with the other pc.
    im using a router so i dont have to worry about the ip. just kept that in auto. & used the router's DHCP server. if u use direct cable (CAT5/5E/6) make sure to provide IP. u can use 192.168.0.1 in one machine & 192.168.0.2 in the other. (make sure ethernet's driver is installed).use 255.255.255.0 for subnet mask. then try pinging the other.
    go to command prompt & type ping<space>other machines IP.
    then start cod4mp. make sure it starts properly. & first time windows firewall will ask for permission. give it everything
    then start server from one machine. & join the game from the other machine.
    make sure to check filter of other machine.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Problem solved and already played for 6 hours
    Anyways, Thanks Everyone
    Quote Originally Posted by giant View Post
    Ip on pc1 :192.168.0.1
    ip onpc 2: 192.168.0.2
    subnet on both : 255.255.255.0
    Dns on both : 192.168.0.1
    If using windows 7, make sure the network is home network and Filesharing in on for home networks
    Solved bro. I was trying to run a dedicated server thats why the problem happened . Thanks anyways
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • F&amp;D A520 2.1ch || Xiaomi Mi Basic
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    where did you set the IP.....ipv6 or ipv4??
    if u play cod regularly & if u r a nOOb player & if u use garena "wanna join"
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Always ipv4
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Always ipv4
    does it conflict, if one of the two pc is 64bit, and the other 32bit......both win7........
    why ! on the same network iv even used Ubuntu 64 bit. win 8 32 bit, & two win7 64 bit. no problem at all!
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    No ! Tell me where u are having trouble
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    i've been trying connecting two pc(also tried another lappy with my pc) with cat-6 cable.....
    in the network and sharing centre, it shows 'unidentified network', or like this with the public logo.....
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Click on where it says public network and change it to home network. Have you set Static ips for you systems ?
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    do you mean the ipv4 ip??
    ipv4 yes
    dont touch ipv6
    thanks for share !
  1. lan/offline co op games
    By mr_08 in forum General Discussion
    Last Post: March 12th, 2012, 20:41
  2. Attention: Ipt offline
    By Speed in forum File Sharing and Torrents
    Last Post: January 14th, 2010, 20:06
Page generated in 0.28339 seconds with 15 queries.
