Results 1 to 20 of 28
Thread: A Bootable USB: Easiest way to create bootable USB Drive..
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://www.speedtest.net/result/7506335550.png)
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    Arrow A Bootable USB: Easiest way to create bootable USB Drive..
    Prerequisites:
    • A USB Drive (4 GB or more)
    • Windows Vista, Server 2008 or 7 ISO image or DVD
    • Host OS: Windows XP (SP2 or SP3), Vista (SP1 or SP2), Server 2008 or 7
    How to Use:
    Once you meet the requirements, run the utility. Its a portable utility so doesn't need installation. Simply run it and check the option "I have read and accepted the following License Agreement". Now click on OK button and it'll launch the main application.
    It also shows a Help window so that you can use the utility easily. The utility requires only 4 easy steps to follow:
    • Check USB drive (To check whether your USB drive is attached or not)
    • Format USB drive
    • Choose DVD or ISO image (To copy the required files to USB drive)
    • Start the process to create bootable USB drive
    Its very easy and useful utility.
    PS: It also works in 64-bit Windows versions.
    [DOWNLOAD]
    [Virus Scan Report]
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Default Re: A Bootable USB: Easiest way to create bootable USB Drive..
    A just made my pendrive bootable xp for my epc a few hour ago.... with a huge lenghly and complicated dos process.
    Ess ei post ta er age dekhle valo hoito..
    • HolySlayer's Gadgets
      • Asus B85 Pro Gamer
      • Intel i5 4570
      • 12GB DDR3
      • 320GB + 250GB SSD +250GB SSD
      • Zotac NVIDIA Geforce RTX 2070
      • Builtin High Definition Audio with SPDIF Output
      • Microlab 5.1
      • A4 Tech Bloody
      • Almost kono naam nai
      • Xbox360,CreativeCOBRA2
      • Thermaltake LightPower Key 3
      • ASUS 52x CD-ROM Drive (Baki shob noshto)
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    does it really work? vista x64 er iso image file tai to 4GB plus... 4GB pen drive diye ki taile hobe na?
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    Quote Originally Posted by HolySlayer View Post
    Well, 4gb plus hoile 4gb plus pen drive lagbe..
      • Intel i5 4570
      • 12GB DDR3
      • Microlab 5.1
      • A4 Tech Bloody
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    dhusss
    ar win7 er iso to shalar aro boro ...
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    dhusss
    "ar win7 er iso to shalar aro boro ..." What do u mean by that??? more then 4GB?!?!?! O_o
    Win7 RC1 32bit er iso 2.35GB & 64bit er iso 3.04GB.. & amar vista er iso less then 4GB..
      • Intel i5 4570
      • 12GB DDR3
      • Microlab 5.1
      • A4 Tech Bloody
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    Quote Originally Posted by [TH7][coldfire7] View Post
    OUCH... well i've checked it out... well win 7 will fit in... I was thinking win 7 aro boro...
    definitely um gonna give it a try...
    kotha hochhe.. I have another p4 pc. Ar oitar gigabyte motherboard e usb theke boot kore kina I dunno. Any ideas how can i make it work there? and also, I want to use XP on that instead of the operating systems u mentioned... possible?
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    Well I haven't tryed installing Windows XP with it yet but it should work as it mentioned in the post.
    How old is ur mbo??!! if ur mbo doesn't support booting form a USB drive then I can't help u.. But I'm guessing it'll work as u mentioned it's p4 mbo (in my Intel 865PERL it does perfectly..). Make sure your Legacy USB is turned on in BIOS & also make sure to choose USB-HDD in boot drive selection..
    • desertfox's Gadgets
      • Intel DG31PR
      • Intel Core 2 Duo E7200
      • Kingston 1 GB x 2 DDRII 800 MHz
      • Intel SSD X25-M 80GB & Samsung HD502IJ
      • Asus Nvidia GeForce GTX460 1GB DDR5
      • Asus MM17DE
      • Creative Live Digital 5.1
      • Creative Inspire 2400/Logitech Digital Precision Gaming Headset/Logitech G330/Logitech G35 (Broken)
      • Logitech G15 Gaming
      • Razer Deathadder 3.5G
      • Logitech Dual Action
      • Thermaltake Toughpower XT 675 Watt
      • Asus E818A
      • ADATA 8 GB Pen Drive & Transcend 16 GB Pen Drive
      • Vanstab 500 VA/Mercury 600 VA
      • P13790 (3D Mark Vantage)
      • I am damn Satisfied
      • LINK 3
      • 125
      • 1267.5
    desertfox's Avatar
    Chittagong
    কি দুঃখ আমার USB Flash Drive টা মোটে 256 MB.
    Designed by Eaglewatch1337
    See, Which Game I'm Playing & to be Played
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    Quote Originally Posted by desertfox View Post
    Amar ta 512mb xD
      • Intel i5 4570
      • 12GB DDR3
      • Microlab 5.1
      • A4 Tech Bloody
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    amar ta 4GB
    Win7 ekhon jei version ta ase is this better than WinVista 64bit Sp1? thats the one um using now.. of so then um gona give win7 a try with this bootable method..
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    I found virus in it [kis8] tons of IE tried to open at a time..
    can some one confirm it?
    • towhidabid's Gadgets
      • abit ix38 quad gt
      • intel quad core q9550. 2.83 ghz
      • 4gb transend 800bus
      • 250+250+120 GBs
      • ati radeon HD 4870 1GB
      • 19" asus splended lcd
      • microlab x10D home theater system
      • A4TECH multimedia
      • delux normal
      • thermaltake 750W
      • Asus DVD+liteon DVD writer.
      • windows vista
      • smile
      • 18
      • 15
    cant i make it work wid a 2GB PD for windows XP bootable???
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Quote Originally Posted by towhidabid View Post
    I dont know if its possible with this software..
    but its possible to make a bootable xp flash drive with a 1 gb pendrive. works fine..
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Schiit Fulla 2
      • Windows NT 6.1
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    It should work, though I haven't tested it with XP yet...
    • krishok_vai's Gadgets
      • GIGABYTE GA-EP35C-DS3R
      • Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz 2.67GHz
      • Transcend 2 X 2GB (800 FSB)
      • Samsung F3 1TB SATA(7200RPM)
      • Sapphire Radeon 4850 512MB (TOXIC)
      • Samsung SyncMaster 2233sw (21.5") 1080p SOLID
      • Realtek Builtin Audio (HD)
      • Creative Inspire 4.1 l A4tech Portable
      • A4Tech Anti RSI
      • Microsoft Habu Gaming Mouse (Powered by Razer)
      • Thermaltake 400w Lite Power
      • Windows se7en 64 bit
      • ZOOM Ultra 150 kbps
      • 50
      • 35
    krishok_vai's Avatar
    Niketon, Gulshan 1
    dont work with xp....
    thanks Colfire7 it worked for me
    i did it on win 7 64bit RTM build 7600
    Thanks it worked for me aswell win 7 64bit build 7600. Any OS that fits in 1 DVD should fit in 4GB pendrive aswell. The installation speed from the USB was amazing compared to a normal DVD.
    • cRush's Gadgets
      • Abit IP35P
      • Core 2 Quad Q6600 2.4Ghz (Oc @ 3.11Ghz ) 2*4MB Cache
      • 2*2GB Transcend DDR2 Ram @800Mhz (Oc @840 Mhz)
      • 320GB Hitachi HDD + 500 GB Samsung F3 HDD
      • Palit GTX560 Ti Sonic 1GB
      • Samsung SyncMaster932B 19" LCD Monitor
      • RealTek HD 7.1 Soundcard
      • A4Tech Headphones+ Creative 5:1 Surround Sound
      • A4Tech Anti-RSI Keyboard
      • Genius G500 Laser 2500dpi
      • Sony Sixaxis
      • ThermalTek 420W
      • Asus SATA DVDRW drive + Asus IDE DVD-combo Drive
      • Windows 7 RTM 64Bit
      • IT RAWKS :D
      • Local (STAR ISP)
      • 32 - 40
      • 40 - 60
      • 144
    cRush's Avatar
    it didnt work for me. So I wrote a script for it. Just run it and give the drive letter of you pendrive. Then give the address for windows 7 setup files (extracted) . And it does other job for you
    bootmaker_rush.rar
    Just extract the file and run bootmaker_rush.bat.
    Enter you pendrive letter :
    for example: h
    Enter where your windows 7 setup files are:
    for example: d:\win7\7600.16385 (avoid spaces in folder names)
    (This folder will have all the setup files, boot,efi,sources etc folder )
    then copy will start and it'll make it bootable.
    Let me know if you face any problems.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    Thanks Rush and Coldfire for that.
    I have another way.
    Code:
    Requirement----4GB or more space USB and Windows 7 ISO or DVD
     Procedure-----
    1.Plug your USB in port.
    2.Open CMD in admin mode.
    3.Type DISKPART
    4.then LIST DISK
    5.now if your USB is showed in DISK 1 then write --- SELECT DISK 1
    6.then CLEAN
    CREATE PARTITION PRIMARY
     SELECT PARTITION 1
     ACTIVE
     FORMAT FS=NTFS
     write them one by one.
    7.type ASSIGN and hit enter and EXIT.
    now enter windows 7 DVD into your rom and then know the drive letter.
    8.if your dvd drive is H, then first type H:
    then another disk process starts and then you type CD BOOT
    then type BOOTSECT.EXE /NT60 G:   [think your USB drive is G]
    then you have created succesfully USB bootable.
    It doesn't work in XP.in XP you will have to use Windows PE for that.
  1. Test Drive Unlimited
    By Asif in forum Racing
    Last Post: May 17th, 2009, 14:32
  2. game in same drive
    By йЦммєя³¹ in forum Gaming Topics
    Last Post: April 21st, 2009, 01:21
  3. CoD 5 how 2 create multiple profile?
    By pollob.codename13 in forum Call of Duty
    Last Post: March 30th, 2009, 16:48
  4. Buying a new DVD drive need advice
    By TAHMID in forum Technical Support
    Last Post: March 12th, 2009, 22:46
  5. How can I create .ini files?
    By Tian in forum Software
    Last Post: September 6th, 2008, 00:27
Page generated in 0.32836 seconds with 15 queries.
