Results 1 to 6 of 6
Thread: Need Help on E5200 Overclocking
    Default Need Help on E5200 Overclocking
    Hello there,
    I am using a pentium dual core e5200 with a gigabyte G31M-ES2C mobo.I know the e5200 is a overclocking monster and when overclocked it can nearly beat stock core2 line-ups.I read in many Pages and forums that 3.3ghz clock(266x12.5) is super stable for it and it can be achieved with stock voltage and stock cooler.So i have tried to overclock it today using gigabyte easytune 5 Pro.I increased the bus to 266mhz and when i press the GO button then the PC hangs and the screen became garbaged.I restarted my PC again and tried with different values,but same thing is happening.
    Is the processor oveclockable on that mobo?I use 2gb 667bus DDR2 transcend ram.Anyone please help me overclocking my e5200.
    • shahriar's Gadgets
      • Gigabyte MA78LMT-S2 (760G)
      • AMD Athlon IIX4 640 3.0 GHZ
      • 2X2 GB TeamElite DDR3 1333
      • Samsung spinpoint 320GB 16M + Hitachi 160GB
      • Sapphire AMD Radeon 5770
      • Asus VH192D 18.5 inch
      • Creative Sound Blaster Audigy Value
      • AltecLansing Octane7/Cosonic
      • Logitech Glossy
      • A4TECH Q3-310
      • Something non branded
      • Gigabyte Superb 550P 450W
      • Asus DRW-1814BLT & DVD-E818A7T
      • transcend V70 4GB
      • Apollo 650VA
      • Windows Se7en Ultimate 64Bit
      • More than i need :P :P
      • Banglalion SafariKing 512
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    Default Re: Need Help on E5200 Overclocking
    for overclocking BIOS is always the best choice.change ur values from bios.u can easily overclock it to 3ghz with the stock voltage.but with the stock cooler dont go over 3.2 as the ambient temperature is already to hot.disable smart fan,c1e,enhanced halt,eist or every power saving options.check ur stability with prime 95 or with orthos & also check ur temp with core temp.these r the basic idea
    Thats it.I managed to oc it to 3.3Ghz(266x12.5).CPU is stable on stock cooler and the temp is allright.It also passed Prime95 and Orthos test.Thanks Shahriar Bro
      • Logitech Glossy
      • A4TECH Q3-310
      • transcend V70 4GB
      • Apollo 650VA
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    U r always welcome bro.stress test ur cpu for atleast 2hours.look for temperatures carefully.dont let it get past 65'
    I ran stress test for about 6hours and no error or overheating happened.
      • Logitech Glossy
      • A4TECH Q3-310
      • transcend V70 4GB
      • Apollo 650VA
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    Congrats bro......
  1. Is my e5200 temperature allright?
    By poison in forum CPU
    Last Post: June 22nd, 2009, 20:53
  2. E5200 temperature problem
    By shahriar in forum CPU
    Last Post: June 8th, 2009, 12:00
  3. factory overclocking vs. own overclocking ?
    By Leaving BG in forum GPU
    Last Post: April 20th, 2009, 01:45
  4. Intel E5200 (Dual COre 2.50 GHz)
    By Cyber_Shot in forum CPU
    Last Post: February 20th, 2009, 17:02
  5. Want A Pentium Dual Core E5200!
    By GiDDY_SOUL in forum Shop - Gadgets
    Last Post: October 13th, 2008, 22:39
Page generated in 0.18424 seconds with 14 queries.
