Thread: Need help with a script
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    Default Need help with a script
    I was wondering if anyone can write up a BAT file which will do a couple of things in order. This is to help the CSS scene and I'm sure many people will appreciate it.
    Things that need to be done (in order):
    1) Exit Steam.exe
    2) Disable LAN connection
    3) Launch CSS exe
    4) Some delay
    5) Enable LAN connection
    I have no idea how to do this and when I tried, I just managed to close Steam and minimize it in the background rather than exiting it completely. Don't know what's the command for a graceful exit.
    Any help would be appreciated
    • ShouravBR's Gadgets
      • Gigabyte B150M-D3H
      • Intel i3-6100
      • 2x DDR4 4GB
      • Transcend 128GB; Toshiba 1TB
      • Sapphire R7 260x 2GB
      • Samsung SyncMaster (1920x1080)
      • A4Tech Wireless
      • A4Tech Wireless
      • Gigabyte Hercules x580
      • Minecraftable.
      • ICC 2Mbps
    ShouravBR's Avatar
    Apr 2013
    Writing batch files may be daunting but the net is packed with resources waiting to be googled.
    And you should run this batch file as admin.
    Code:
    taskkill /f /im Steam.exe
    ipconfig/release
    path/to/css.exe
    sleep 10s
    ipconfig/renew
    Ref/footnote:
    1. http://www.neowin.net/forum/topic/32...on-with-a-cmd/
    2. It doesnt actually disable the network adapter, but makes your network show up as "unidentified". (don't know if it will work for you)
    3. From past experience
    4. Sleep x (any integer followed with s = seconds, m = minutes, h = hours or d = day)
    5. (we all know what this does)
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    Thanks for the start, but it isn't working as expected. Link3 users have static IP, and I guess the release-renew will work only when it's meant to get an IP automatically.
    Secondly, I changed the css exe to the actual name but it isn't launching. Am I supposed to include the whole path like D\games\css\css.exe? Any quotation marks?
    Lastly, is it possible to have Steam shut down gracefully instead of what it is right now (same as end process from task manager)?
      • Intel i3-6100
      • 2x DDR4 4GB
      • A4Tech Wireless
      • A4Tech Wireless
      • Minecraftable.
      • ICC 2Mbps
    ShouravBR's Avatar
    Apr 2013
    Code:
    taskkill /IM program.exe /T
    /F specifies terminated forcefully
    /T specifies close child process
    taskkill /? for more info
    Look here for network ON/OFF -> http://cmdknowledge.wordpress.com/20...ommand-prompt/
    Does D\games\css\css.exe in cmd starts the program then "yes". (try snippets in CMD before you save it to bat file)
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS Crosshair HERO VIII
      • AMD Ryzen 3950x
      • GSkill Trident Z Neo 4x16GB DDR4 @3733MHz
      • Lots of SSD
      • EVGA 980Ti 6GB
      • ASUS ROG 4k + 2x 1080p
      • Internal
      • Logitech Z906
      • Razer BlackWidow Ultimate
      • Logitech G903 x2
      • XBOX Gears of War Editions
      • Seasonic X 850W 80Plus Gold
      • Logitech C920; Blue Yeti
      • Emerson 3000KVA Online
      • Link3/Dot
      • 300000+
      • 100000+
    CvP's Avatar
    Here you go.
    I am not entirely sure if this will work on Windows 7 or not as Windows 7 has PowerShell v2 and Windows 8 has v3.
    How to use:
    extract.
    open.
    put necessary path/options in CONFIG.
    save
    run.
    - Updated to make it work in Windows 7.
    - Alternatively, you can install powershell v3 (latest) from here.
    Attached Files Attached Files
  1. Torrentbd Seedbox & rapidleech script
    By virus_bd in forum Features of TorrentBD
    Last Post: June 9th, 2011, 02:00
  2. Server2Server Transloader Script
    By somik in forum Programming
    Last Post: August 6th, 2010, 14:22
Page generated in 0.18257 seconds with 15 queries.
