Results 1 to 6 of 6
Thread: E5200 temperature problem
    • shahriar's Gadgets
      • Gigabyte MA78LMT-S2 (760G)
      • AMD Athlon IIX4 640 3.0 GHZ
      • 2X2 GB TeamElite DDR3 1333
      • Samsung spinpoint 320GB 16M + Hitachi 160GB
      • Sapphire AMD Radeon 5770
      • Asus VH192D 18.5 inch
      • Creative Sound Blaster Audigy Value
      • AltecLansing Octane7/Cosonic
      • Logitech Glossy
      • A4TECH Q3-310
      • Something non branded
      • Gigabyte Superb 550P 450W
      • Asus DRW-1814BLT & DVD-E818A7T
      • transcend V70 4GB
      • Apollo 650VA
      • Windows Se7en Ultimate 64Bit
      • More than i need :P :P
      • Banglalion SafariKing 512
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    Default E5200 temperature problem
    Atleast 5of my friends are using e5200.but all of them are facing heating issues.their idle temp is 50' & at 100% load it stays at 64'-68'.even my idle temp is 38' and at load its 62' after overclocking.anyone knows what's the problem.i used core temp & hw monitor temp monitoring and prime 95 for stress testing.
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Default Re: E5200 temperature problem
    my suggestion is look bios for temp.and use thermal paste.
    onek somoy room temp. ar jonno temp. basi thake .
      • Logitech Glossy
      • A4TECH Q3-310
      • transcend V70 4GB
      • Apollo 650VA
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    nope these r not the problems......
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Quote Originally Posted by shahriar123456 View Post
    so what is ur problem?
    Have you checked the airflow? Is it as strong as yours?
      • Logitech Glossy
      • A4TECH Q3-310
      • transcend V70 4GB
      • Apollo 650VA
      • ~55 kB/s
      • ~18 kB/s
    shahriar's Avatar
    Feb 2009
    Dhanmondi
    yap there airflow is ok.even better than me.though i'm using an original P4 heatsink(the bigger one) but with the older heatsink that came with the processor i had max temp of 56' & ofcourse with the stock clock.
    if only 1of my friend had the problem i would'nt bother.but every1 is having the same problem.these r the 45nm cpu so is it supposed to have lower temperatures than e2XXX series or e5200 just acts like this?any e5200 owner plz tell me ur idle & load temp
    ---------- Post added at 11:00 ---------- Previous post was at 10:55 ----------
    Quote Originally Posted by anik View Post
    thermal paste is used.bios temps are also high.room temps r ok
  1. PSU Problem
    Last Post: May 13th, 2009, 03:57
  2. Intel E5200 (Dual COre 2.50 GHz)
    By Cyber_Shot in forum CPU
    Last Post: February 20th, 2009, 17:02
  3. Want A Pentium Dual Core E5200!
    By GiDDY_SOUL in forum Shop - Gadgets
    Last Post: October 13th, 2008, 22:39
  4. dl problem in RS
  5. problem - cd-key, Plz Help
    By saadbillah in forum CS 1.6
    Last Post: July 24th, 2008, 17:37
Page generated in 0.18675 seconds with 14 queries.
