Thread: Running dual monitor using both External and Internal Graphics card
    • Menace Slinger's Gadgets
      • Gigabyte B75
      • Intel Core i5 3470
      • Twinmos 2 X 4GB 1600 mhz
      • WD 2 X 1 TB + Hitachi 1 TB + Samsung 320 GB
      • Nvidia GeForce GTX 650
      • Samsung LED 18.5 Inch X 2
      • M-Audio Fast track
      • Just Beats ( Beats by Dr. Dre)
      • A4 Tech KD 800L
      • Logitech B100
      • Generic USB Gamepad
      • Thermaltake Litepower 450 WT
      • SAMSUNG
      • Audio technica AT 2020 Microphone
      • Ideal 5308B 800VA 7Ah
      • Windows 7 Ultimate
      • Casing : InWin MANA 136
      • Earth Telecommunication
      • 4 MB
      • 4 MB
    Menace Slinger's Avatar
    Jan 2013
    Default Running dual monitor using both External and Internal Graphics card
    My external card is GTX 650 and I have a Gigabyte B75M motherboard. Is it possible to run both the cards at same time? I am not intending to play games. just normal work. I dont know if my mobo will allow me to do so. Any ideas ?
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    You should be able to run two monitor using GTX 650...
    Anyways, go to bois and make sure internal card is always on. Then just plugin the monitor in there and it will just work.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Yeah bro. But I am fade up of that. Amar GTX 650 te Dvi-Dsub converter diye 2nd monitor chalaite chaisilam. BUT 2 bar converter change koreo lav hoinai. Amar monitor nvidia control panel show i kore nah :/
    anyways there is only Auto,Enabled and disabled option. Should I check on enabled ?
    Noblesse Oblige
    • CvP's Gadgets
      • EVGA 980Ti 6GB
      • G7
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    enabled.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    enabled.
    did NOT work for some reason :/ My System doesnt even detects the Monitor. I checked monitor/cables and all are working fine
  1. Replies: 3
    Last Post: November 2nd, 2011, 16:39
  2. Want to Buy External/Internal HDD
    By йЦммєя³¹ in forum Shop - Gadgets
    Last Post: September 12th, 2011, 18:02
  3. KFA2 plans dual GTX 560 Ti graphics card
    By codename5302 in forum GPU
    Last Post: March 16th, 2011, 01:52
  4. Replies: 40
    Last Post: March 8th, 2011, 16:12
  5. Converting Internal HDD to External / Portable HDD
    By ABDmaster in forum Technical Support
    Last Post: February 20th, 2010, 21:27
Page generated in 0.17481 seconds with 14 queries.
